1 - 1 of 1 Posts
Greetings! I would like help with this problem. With the car turned off there is a current drain in excess of 2 amps. I removed the cooling fan relays that brings it down to about 50 milliamps. The idle speed valve is vibrating because of this drain. When I disconnect the fuel pump control relay which is besides the cooling fan relays the problem seems to go away. However, If I don't have that relay in the circuit the car will not run. any help will be appreciated. Regards, Geoffrey,.Montreal
1 - 1 of 1 Posts
