> Help: Manual Shifter Binding When Moving Into Neutral, shifer problems
GP-s40-t5
post Jan 25 2020, 09:16 PM
Post #1
Newbie
Group: Members
Status: Offline
Drives: 2006 Volvo S40 T5
I have an issue with my manual shifter on my 2006 S40 T5.
When I move the shifter backwards from 1st gear, the shifter binds and requires some force to move it to the right, into neutral. Then is clunks into place.
When I move the shifter forwards from 2nd gear, the shifter binds and requires some force to move it to the right, into neutral. Then is clunks into place.
I have no problems moving the shifter any other direction.
Because of this when I try to shift from 2nd to 3rd it usually slips into 1st instead.
Go to the top of the page
QuoteReply
Platypup
post Jan 27 2020, 01:35 AM
Post #2
Senior
Group: Members
Status: Offline
Drives: Volvo V50 T5 AWD, Toyota RAV4, MG TC, Jaguar E-type
A similar problem has been reported on later models as can been seen by the following link. Most likely something has come loose in the cable/link connection for the manual shift lever. Possibly can be fixed easily if you can manage to access the cable links. Otherwise leave it to someone who knows what he (or she) is doing.
https://www.motorauthority.com/news/1046284...-shift-linkages
This post has been edited by Platypup: Jan 27 2020, 01:37 AM
QuoteReply
GP-s40-t5
post Jan 28 2020, 07:51 PM
Post #3
Newbie
Group: Members
Status: Offline
I disconnected the (left to right) shifter cable from the transmission and moved the selector lever on the transmission manually. The problem still happens (no shifter attached). So something is wrong in the transmission. The selector lever is attached to a cover plate. I'll open it and see if there is anything there that is easy to fix. Maybe I'll get lucky and find my long lost luck penny wedged in there. (IMG:style_emoticons/default/tongue.gif)
This post has been edited by GP-s40-t5: Jan 29 2020, 12:27 AM
QuoteReply
Platypup
post Jan 28 2020, 10:03 PM
Post #4
Senior
Group: Members
Status: Offline
Good luck. It is extremely unusual for a fault to develop with the selector mechanism inside the gearbox unless it has been abused. I cannot recall this problem coming up before in this forum so it would be appreciated if you could let us know your findings.
QuoteReply
GP-s40-t5
post Feb 1 2020, 12:21 PM
Post #5
Newbie
Group: Members
Status: Offline
Turns out the cover plate is an actually a module (Gear Selector) that slides out. I'm working on getting to it now. Has anyone ever removed one? Does it slide up and out?
QuoteReply
GP-s40-t5
post Feb 1 2020, 04:10 PM
Post #6
Newbie
Group: Members
Status: Offline
I've confirmed that the problem is in the Gear Selector module. I don't know what is causing the problem yet. The pin in the shift gate still won't move back to the neutral position unless it's bumped or hit. In the picture below, the pin is sitting on the side (bottom) of the shift gate when my hands off of the selectors on top.
Attached File(s)
QuoteReply
grendel1960
post Feb 2 2020, 02:42 AM
Post #7
Veteran
Group Icon
Group: Super Mod
Status: Offline
Drives: 2002 Volvo V70 D5 S
could the assembly just need additional lubrication to stop it binding, or maybe there is a spring or something thats not performing its task
QuoteReply
GP-s40-t5
post Feb 4 2020, 09:02 PM
Post #8
Newbie
Group: Members
Status: Offline
After beating, cleaning, fine-sanding and re-lubing every contact point I could find, decided it was just time to buy a replacement. Just when I was about to put it down, I hard tapped the lateral shift lever, 3 times with a hammer, where it enters the top of the gear select module. That did the trick. The module works now.
I'll finish putting everything back together tomorrow and go for a test drive.
QuoteReply
Platypup
post Feb 4 2020, 10:38 PM
Post #9
Senior
Group: Members
Status: Offline
You've shown how perseverance (& a good tap with a hammer) can sometimes get results. Puzzling though what caused the binding, especially as the gear change is normally so smooth and light. I wonder if brackish water managed to get in at some stage.
QuoteReply
GP-s40-t5
post Feb 5 2020, 09:06 AM
Post #10
Newbie
Group: Members
Status: Offline
QUOTE (Platypup @ Feb 4 2020, 10:38 PM)
That makes a lot of sense. Maybe I could have cleared it with brake clean and penetrating oil.
Tonight I'll change the fluid as a precaution. I'll also replace the lower engine torque mount as it's been clunking for a while.
QuoteReply
GP-s40-t5
post Feb 5 2020, 08:54 PM
Post #11
Newbie
Group: Members
Status: Offline
Ok. I took it for a test drive for a few miles and no problems shifting at all. I'll get back with you all in a few days.
QuoteReply
GP-s40-t5
post Jul 1 2020, 10:12 PM
Post #12
Newbie
Group: Members
Status: Offline
It's been a few months. All is fine.
QuoteReply
« Next Oldest 2G (2004.5+) S40 Forum Next Newest »
  Advanced Search
2 User(s) are reading this topic (2 Guests and 0 Anonymous Users)
0 Members:
Collapse
> Similar Topics
No New Posts Help! Snow Chains For New Xc90
XC90
0 Astro_boy 1,112 31st December 2019 - 06:42 PM
Last post by: Astro_boy
No New Posts Help With Volvo 240 Ignition Troubleshooting Flow Chart?
0 123tim 1,072 20th November 2019 - 02:30 PM
Last post by: 123tim
No New Posts When You Should Change Your Fuel Filter
this will apply to the volvo 940 but can apply to any car.
0 danielm85948 1,051 11th September 2019 - 11:03 PM
Last post by: danielm85948
No New Posts Help With Ac Issue
Vent on driver's left won't blow
1 CSam 2,993 7th July 2019 - 10:54 PM
Last post by: grendel1960
No New Posts Help
Loss of power
1 Clayworld 3,344 5th January 2019 - 11:39 AM
> Link To Us
Time is now: 15th August 2020 - 03:40 AM
© 2004 Volvo-forums.com
