> Starts When It Sits For 1 Day, 2days, But Not 4 Days Or 5 Days, 122s with weber conversion
poohbear's h...
post Aug 27 2015, 03:15 PM
Post #1
Newbie
Group: Members
Status: Offline
Drives: 68 volvo
1968 volvo Station wagon,122S
After installing a new weber conversion and it's manifold, I find two problems. One, there's a no start situation if the car sits for few days, even though there's still gas in the carburetor float bowl. Also, possibly unrelated... by the time we adjust this one to run well, we may be running a little rich.
Is there an easy way to check for leakage between the manifold and the engine block?
Could we have an issue with the vacuum from the cylinder? the valves, the pistons? Is there a way to check the vacuum?
Thanks in advance for any suggestions on figuring this one out. We miss our volvo...
Go to the top of the page
QuoteReply
danielm85948
post Aug 27 2015, 05:15 PM
Post #2
Expert Veteran
Group Icon
Group: Super Mod
Status: Offline
Drives: volvo 940 se turbo 1991
QUOTE (poohbear's helper @ Aug 27 2015, 04:15 PM)
first check you have a good spark from the coil,then at the leads at your spark plug. then take out and smell your spark plug if smell of fuel change the spark plugs,and be sure you have a good earth to your camshaft cover. check the output from your battery.
QuoteReply
poohbear's h...
post Aug 27 2015, 07:37 PM
Post #3
Newbie
Group: Members
Status: Offline
Drives: 68 volvo
Thanks for your feedback. We will check (or recheck again) the items listed, as time allows us to get to the shop and report back.
QuoteReply
poohbear's h...
post Aug 27 2015, 07:39 PM
Post #4
Newbie
Group: Members
Status: Offline
Drives: 68 volvo
QuoteReply
poohbear's h...
post Mar 28 2018, 10:06 PM
Post #5
Newbie
Group: Members
Status: Offline
Drives: 68 volvo
Volvo 122S
This volvo is my partner's but he's asked me to help him with computer conversations as he is not computer savvy.
Time has gone by, since our last post and we've worked intermittently to deal with this problem. In the end we realized our compression was so poor we had to get our engine rebuilt. At this point it also has a new weber carburetor, a new distributor, but old cap and rotor. Reasonably new plugs and wires. Compression is now 135-140 dry on all cylinders, 140-150 wet. He timed it, and we have an orange spark in the window of the little tester. We don't know how to test coil strength, if that might be marginal.
Problem: When he turns the engine over, it will not start. If he continues to try at intervals, it will finally start and run smoothly after about 2 or 3 minutes, but it may be running somewhat rich. He can see that there is gas coming to the carburetor, even during the very first turn of the key. He told me he checked fuel pressure and it's in the right range.
Lately we discover that if he does just One attempt at starting, and then lets it sit untouched for 2 or 3 minutes, it will start fine after the time period has elapsed, but no start possible untill that time has elapsed.
We have checked every way we know for air leaks, and have not found any.
Possibly related... and a little curious: We removed the tube leading from the manifold to the PCV valve (called "crank case breather" in our old manual). When we put a thumb over the tube, we feel the pull of a good vaccumm and the engine RPM slows significantly. When we release the thumb, engine speeds up significantly. When we place the tube back on the PCV valve the *increased* RPM remains, just like it does when we have no thumb on the tube. Should that happen? or do we have a failing PCV valve? He told me that he cleaned it, but there's nothing in the manual on how to check it's function. Instead we see the phrase.... "the remaining fitments call for no special instructions", which makes us laugh... can you guys help? We feel that we're so close.... but still this malingering problem.
QuoteReply
« Next Oldest Amazon P120, P130 & P220 Forum Next Newest »
  Advanced Search
0 Members:
Collapse
> Similar Topics
No New Posts Forum Virgin
8 [email protected] 9,521 13th April 2020 - 08:50 PM
Last post by: 3aplus63Embot
No New Posts When You Should Change Your Fuel Filter
this will apply to the volvo 940 but can apply to any car.
0 danielm85948 966 11th September 2019 - 11:03 PM
Last post by: danielm85948
No New Posts Topic has attachmentsFor Sale: 2013 Volvo S60 T5 – Black Stone/black – 53k Miles – San Francisco
0 CER237 13,623 8th July 2019 - 11:28 AM
Last post by: CER237
No New Posts Orange Emissions Light Stays On
Emission System Light
0 Anthony Putter 3,389 19th June 2019 - 12:57 PM
Last post by: Anthony Putter
No New Posts For Sale V60 T6 My14 Volvo
0 Global75 6,150 4th April 2018 - 06:09 AM
Last post by: Global75
> Link To Us
Time is now: 5th August 2020 - 08:17 AM
© 2004 Volvo-forums.com
