> 88 245dl Spark, Fuel, No Start!
240_BOI
post Dec 8 2019, 04:26 PM
Post #1
Newbie
Group: Members
Status: Offline
Drives: 1988 Volvo 245dl
So I got this 1988 245 about a 2 months ago, to be my winter car. When I got it, it was running fine, but only needed a few things for safety. I discovered the gas tank was rusted, so i replaced that. It sat in my driveway on jack stands for about a month, with no gas tank. After i installed the tank, I turned it over, and it fired right up. After that i had to bring it to the garage to get a manifold bolt drilled, as it is too cold outside to be messing around with that. The car made it to the shop with no issues, and made it back too. The only problem is that when I was pulling into the driveway, it died, and wouldn't start again.
Ever since then, with the little time I have, I had narrowed the issue down to the distributor and after. The rotor was giving we a silly reading of 100 000ohm, which is ridiculous. So assuming it was that, I replaced the rotor and cap. Still no start, not even the smallest ignition, just the started turning it over. I have verified strong spark, and plenty of fuel. At this point I have no idea what is going on, it is making zero sense.
Let me know what you've got for possible solutions, thanks, much appreciated!
Go to the top of the page
QuoteReply
grendel1960
post Dec 8 2019, 04:35 PM
Post #2
Veteran
Group Icon
Group: Super Mod
Status: Offline
Drives: 2002 Volvo V70 D5 S
although you say you have fuel, it might be worth checking the fuel pump relay, these are prone to weak solder joints, especially in cold weather. (when things contract and the gaps around the pins cracks the solder.
QuoteReply
240_BOI
post Dec 8 2019, 04:38 PM
Post #3
Newbie
Group: Members
Status: Offline
QUOTE (grendel1960 @ Dec 8 2019, 04:35 PM)
I had was thinking there was something up with the relay, because there seemed to be too much fuel in the cylinders. I pulled the relay and turned it over, and the car wouldn't start, yet it was back firing. This is more than it was doing with the relay attached. But I also used so quick start, and it didn't even fire up then,so its still a confusing situation.
This post has been edited by 240_BOI: Dec 8 2019, 04:59 PM
QuoteReply
grendel1960
post Dec 9 2019, 12:32 AM
Post #4
Veteran
Group Icon
Group: Super Mod
Status: Offline
it might be worth checking the timing marks to make sure the timing belt hasnt jumped a tooth, that could cause the symptoms you describe, or a stuck valve not closing properly
QuoteReply
240_BOI
post Dec 9 2019, 09:44 AM
Post #5
Newbie
Group: Members
Status: Offline
QUOTE (grendel1960 @ Dec 9 2019, 12:32 AM)
Would one tooth be enough to cause it not to start at all?
QuoteReply
grendel1960
post Dec 9 2019, 04:02 PM
Post #6
Veteran
Group Icon
Group: Super Mod
Status: Offline
i refitted one and got it one tooth out, it barely ran, when i then got it 2 teeth adrift it had no compression and wouldnt start, dont take it as gospel, but a check against the timing marks should at least verify they are ok.
QuoteReply
danielm85948
post Dec 9 2019, 06:23 PM
Post #7
Expert Veteran
Group Icon
Group: Super Mod
Status: Offline
Drives: volvo 940 se turbo 1991
QUOTE (240_BOI @ Dec 8 2019, 05:38 PM)
remove the spark plugs turn over the engine to pump it out.
QuoteReply
« Next Oldest Volvo 240, 242, 244 & 245 Forum Next Newest »
  Advanced Search
0 Members:
Collapse
> Similar Topics
No New Posts Fuel Pressure Sensor
Where in the world is the sensor?
4 Shutterspeed 4,527 1st August 2020 - 12:42 PM
Last post by: wallywilso
No New Posts Fuel System Strange Problems
2 henrijeret 586 4th July 2020 - 07:25 PM
Last post by: ssicarman
No New Posts Topic has attachmentsNo Mount For Slave Cylinder
0 ddininio 25,923 9th April 2020 - 06:45 PM
Last post by: ddininio
No New Posts No Start Just Clicks..
im sure this topic has been covered before , however??
1 jaimster 6,058 6th March 2020 - 02:00 AM
Last post by: Platypup
No New Posts Fuel Pump Access On 2006 V-50 Awd
0 hamver 7,766 5th January 2020 - 10:51 PM
Last post by: hamver
> Link To Us
Time is now: 5th August 2020 - 09:15 AM
© 2004 Volvo-forums.com
