> Wastegate Actuator Rod - Increase Pressure
jihan
post Jun 27 2006, 02:34 PM
Drives: Volvo 850 T5R, Renault 19 16V Cab
Hi, I just recently chiptuned my 850 T5R, but can't get enough turbo pressure. I have now read a lot about this and it seems that by turning the Wastegate Actuator Rod about 3 turns, may help.
The prssure is only about 0.7 barand should be up towards 1 bar.
Does anyone have any more info on this?
I also tried to find out if Volvo has a new Wastegate, in case this itself has become too loose in the spring inside. But no luck...
John Inge
the underlord
post Jun 27 2006, 03:07 PM
Drives: 98 V70 T5M
don't mess with your wastegate...
if you want to go cheap..
get a manual or electronic boost controller.
post Jun 29 2006, 02:04 AM
I'm more to say that disturbing the wastegate should only be done if you are a tuner.
jihan
post Jun 29 2006, 02:37 AM
Well, it will be the tuner that will perform the turning of the actuator rod, first one or two times. But I want to make sure that if I try to order a new Wastegate, that this is really necessary...
That being said, I still haven't found this Wastegate part in the Volvo system, found a part number, but it was not active anymore at Volvo dealers.
So I am now hoping that my tuner will be able to order this from somewhere in the UK, but I wonder if anyone knows what a Wastegate will cost?
I found my turbo in this list:
http://swededemon.com/turbo/turbolist.html
15G - B5234T 225hk/B5234T5 240hk 1996, straight outlet form turbine.
It's a Volvo 850 T5R 1996.
I have been reading a lot about different hoses that very often need to be checked or changed, but can't find any real How-To pages for checking this.
Lots of people with good knowledge, but few that are very detailed in explaing things :-) To us that are better behind a computer than in the engine room :-)
Even if doing changes should be up to professionals, we should be able to check simple things as hoses :-)
post Jun 29 2006, 03:37 AM
QUOTE(jihan @ Jun 29 2006, 03:37 PM)
[right][snapback]34855[/snapback][/right]
Well, then pray hard, your tuner won't screw it!
:grin:
post Jun 29 2006, 03:55 AM
Which hoses are you referring to?
Water-coolant hoses or air or vacuum-hoses?
For water-coolant hoses, go through all of them and look for signs of water/coolant stains that have dried up. Maybe difficult given that the rubber hoses are dark in colour, and the fact that the bottom radiator hose is well-hidden. The rule of thumb is that, if they are all still original, then if one gives way, replace ALL of them. As the others would also fail soon.
There are 5 water hoses in total:-
1) Small hose that connects the expansion tank to the back of the engine block.
2) A 5-inch hose at the back of the engine block.
3) A big bottom hose that goes to the radiator.
4) A relatively big hose from the top of the radiator to the thermostat.
5) Small hose from thermostat to the expansion tank again.
(SOMEONE PLEASE CORRECT ME IF I MISS ANY)
As for the vaccum-hose, well start from the vacuum tree... All hoses connected here are non-water hoses.
As for the air-hoses, start from the air-filter box.
Vacuum and air hoses are slightly more difficult to check for leaks. At this age, I have changed all my vacuum hoses into silicone for longer-lasting... Price is OK, as well. You could perform the normal water-leak checks, but then make sure you dry them properly before fitting them again. :)
the underlord
post Jun 29 2006, 11:03 AM
Drives: 98 V70 T5M
QUOTE(jihan @ Jun 29 2006, 12:37 AM)
you should check out the Turbo Performance Club. Pretty great site for the Western Euro Guys.
No New Posts Increase Of Horsepower In Volvos S40 Of 1.6 Chrono
1 stinger1 202 27th June 2008 - 03:48 PM
No New Posts Wastegate Actuation
3 SykO 369 23rd April 2008 - 04:09 AM
No New Posts Topic has attachmentsIncreased Diesel Performance
163bhp up to 185bhp
3 jmckernan 592 16th September 2005 - 03:55 PM
Last post by: stureg
does it increase?
1 snoboarder_mike 526 24th August 2005 - 07:23 PM
Last post by: impulse922
No New Posts Increase engine power
1 V50_Men 1,570 8th February 2005 - 04:04 AM
Last post by: kelen.balint
Time is now: 21st November 2008 - 05:54 PM
