> Low Oil Pressure Stop Asap, Intermittent Alarm
Rick Case
post May 22 2006, 11:28 PM
Drives: 2001 Volvo S60 T5 AW5
The LOW OIL PRESSURE STOP ASAP alert keeps popping up intermittently, my oil level is OK when I check and it only comes up when I slow down or come to a stop. Could it be a dirty sensor? I am due for a service this weekend (even though my service required indicator hasn't showed).
Let me know if you have seen this before and how to fix it.
S60 R
post May 22 2006, 11:56 PM
Expert Veteran
Drives: formerly 2005 S60R
No idea...hope its not expensive!!
jks2
post May 23 2006, 02:31 PM
Senior Veteran
Drives: 2007 Mercedes C230 Sport, 2007 Chevrolet Equinox (Daughter), 2003 Saab 9-3 (Son), 1996 Chevrolet Tahoe (Tow Vehicle), 2000 Ranger R83 Bass Boat
It might be the oil pump. When you are driving at normal spped their is enough pressure that the light doesn't come on. However, when you slow down the pressure drops and you get the warning light. It could be that you need a new oil pump.
Rick Case
post May 23 2006, 03:36 PM
QUOTE(S60 R @ May 22 2006, 11:56 PM)
[right][snapback]31484[/snapback][/right]
Even at low speeds it doesn't come on and only when stopping. When I am stationary (idle) it doesn't come on. It pops up during traffic driving (frequent stop and go). I have also seen it pop up during cornering (left turns only). It also doesn't result in
Can you have a low pressure with full volume of oil? Remember Boyle's Law?
How about the sensor? Isn't there a sensor that can be cleaned? I dread to think it can be the oil pump going. Would the VIDA or VARDIS be able to determine a faulty oil pump?
Viper_7
post May 23 2006, 04:24 PM
Drives: 2005 S60 D5 SE
There should be definitly a service code the guys can pull off which will help identify the problem
What's the running temperature like? still normal?
Rick Case
post May 24 2006, 08:49 PM
QUOTE(Viper_7 @ May 23 2006, 04:24 PM)
[right][snapback]31535[/snapback][/right]
Yeah Viper, the running temp is normal, no increases. Is there a sensor that sends the signal to the computer that may be cleaned.
Viper_7
post May 25 2006, 02:45 PM
There is an oil pressure sensor (sender) but I havn't a clue where it is. I also know there's oil pressure sender seal's and based on what it's doing, I don't think it's something that can just be taken out and given the once over.
As it's a sender though, it's going to have a conneciton of some type...quite possible it's this that could have corroded/causing false alarms.
I've been looking around and the sender is only like 8 sterling.
when was your last oil/filter change? normally a drop in oil pressure is caused by filter impairment or a problem with the pump...if it's a pump problem that's around 220 for the part.
I'd advise you get it checked out as if it's legit..then low oil pressure is not good for your engine and will cause damage.-- sticking more oil in won't do any good.
Vipes
also seen this in another post..may or may not be relevant here
http://www.volvo-forums.com/t7143-low-oil-pressure.htm
starfish
post May 25 2006, 09:59 PM
Drives: 2001 Volvo V70XC
The oil pan o-rings will need to be replaced pronto.
Rick Case
post May 27 2006, 07:34 AM
QUOTE(Viper_7 @ May 25 2006, 02:45 PM)
Vipes
[right][snapback]31695[/snapback][/right]
Viper, you are on the right track. I spoke to a Volvo Parts Seller here in Jamaica and he says there is usually a problem with a seal in the oil sump which becomes worn after a while that may contribute to the NO OIL PRESSURE STOP ENGINE ASAP Alarm. It costs J$200 and another J$200 for the gasket. Don't be alarmed that's about USD$3.50 the exchange rate in Jamaica is USD$1 = JMD$65.5
The car will be serviced today oil filter change etc., so I will monitor and update you guys.
Rick Case
post May 27 2006, 07:36 AM
QUOTE(starfish @ May 25 2006, 09:59 PM)
[right][snapback]31729[/snapback][/right]
Starfish, you seem to be on the right track too. I purchased an O ring for the oil pan and I plan to replace it today.
Rick Case
post May 29 2006, 07:54 PM
Just to update y'all, I had the service done on Saturday, Changed the Oil which was very dirty for 5000kms and the filter. Nothing else was done and the intermittent NO OIL PRESSURE STOP ENGINE ASAP has disappeared. Maybe I have to change my oil earlier like every 3000kms.
I haven't replaced the oil pan O rings as yet, the guy at the shop gave me the wrong part. So I will watch the situation and let you know.
I am still trying to figure in my mind whether dirty oil and filter could result in the alarm I was getting?
No New Posts Oil Loss Mystery Volvo?
1 qingqin 191 7th September 2016 - 09:57 PM
Last post by: highvoltj
No New Posts Low Coolant Warning Light
1 cpd1 150 11th August 2016 - 01:34 PM
Last post by: grendel1960
No New Posts Low Engine Performance Warning Displayed
help..just bought the car
2 tari 161 30th July 2016 - 06:55 AM
Last post by: Vermont
No New Posts Topic has attachmentsOil Leak
Where is it coming from?
0 Alex89 234 18th June 2016 - 04:28 PM
Last post by: Alex89
No New Posts Oil Pan Hanging - What Do I Need To Fix It?
5 Alisa 262 2nd May 2016 - 09:18 PM
Last post by: Platypup
Time is now: 19th January 2017 - 10:46 PM
