> Driving Lights, Help with wiring Driving Lights on 1989 240 DL
Surfechoes
post Aug 18 2016, 10:43 AM
Drives: 1989 240 DL, 1992 245, 1993 245
Hi everyone. I want to add driving lights to my 1989 240 DL. Where I live the driving lights must turn off when the high beams are off.
My plan was to run power from the high beam circuit through a rocker switch to energize a relay which pulls power from the battery for the headlights. I thought the cleanest install would be to pull the rocker switch power from the turn signal/headlight switch, so there would only be a single wire running from the rocker switch through the firewall. I checked the wiring schematics I had, but couldn't find a colour code to indicate which line to tap.
I thought I would just probe the wires coming off the switch, thinking that one wire would energize when the high beam cirucuit is on. That doesn't appear to be the case. None of the wires change state (hot to cold or cold to hot) when testing, so I'm a bit confused. Using the basic test probe.
I have four wires connected by spade terminals to the turn signal switch. They are Green, Blue, Brown and a double Yellow. All the wires except the yellow are either hot or cold and don't change state. If I probe the yellow, a repeating click occurs, almost like an emergency flasher relay.
I'm thinking of something like the Hella-500 series lights. So my questions..
1) Which wire do I tap to energize the rocker switch?
2) Better/Easier to tap at the turn signal switch or somewhere else?
3) In-line fuse between the tap point and the rocker switch? If so what size? I was thinking 10amp.
4) What size relay? At 12v, 55watt, I calculate about a 5amp draw/light. So would a 15w relay be appropriate?
5) What size feed wire for the lights? Battery to relay, then relay to lights. I was thinking #10 Battery to relay, a spliced #12 to each light. Overkill?
6) I was planning on mounting the lights slightly off the center on the bumper top. Does anyone have any experience on how this mounting might impact cooling/airflow for the radiator. I know theoretically it will impede cooling, but does anyone have any practical experience - like mount the lights as close to the headlights as possible. Upper Mid-Altantic here, so cooling demands aren't like the South-West.
7) Any mounting solutions other than drilling holes in the bumper?
I put a new dash in the 240, so its all torn apart, just waiting for the new wiring to be added. Thought I'd ask everything I could think of before installing and learning the hard way!
Thank
Flanne
post Jan 4 2017, 10:33 AM
Drives: 2001 Volvo
QUOTE (Surfechoes @ Aug 18 2016, 11:43 AM)
I put a new dash in the 240, so its all torn apart, just waiting for the new Crazy Bulk from https://www.tenderbuttons.com/crazy-bulk-review-results wiring to be added. Thought I'd ask everything I could think of before installing and learning the hard way!
Thank
Did you fix this yet?
This post has been edited by Flanne: May 2 2017, 01:54 AM
No New Posts Lights Won't Light But Sometimes Do?
problem with front passenger side marker lights xc70
4 MJay 1,642 19th December 2011 - 09:07 AM
Last post by: himinimalz
No New Posts Lights For Volvo S60
2 Oz1984 2,559 15th November 2011 - 12:32 PM
Last post by: Oz1984
No New Posts Driving Lights Options ?
2 sverige 1,207 28th October 2011 - 05:28 AM
Last post by: sverige
No New Posts Lights On Volvo 850 Se Estate (1995 - M Reg)
Press clutch and brake lights come on !
3 dj124 1,112 10th September 2011 - 01:21 AM
Last post by: Kiss4aFrog
No New Posts Lights On Dash Behind Heated Seats, And Heater.
2 daleb 473 19th January 2011 - 09:31 PM
Last post by: midnightS60T5
Time is now: 24th May 2017 - 09:58 PM
