> Volvo S60 Engine Noise In Heavy Rain
mgi
post Feb 7 2006, 08:29 AM
Drives: Volvo S60 2.5T
I own a 2004 Volvo S60 2.5T AWD. I have noticed that usually when I am driving and it starts to rain heavly, there is a loud siren sound coming from the engine area. This sound stays till it doesnt stop to rain. Also, if I dont step on the accelerator, the sound goes away.
I have taken it to the dealership a couple of times but havent been able to replicate the sound.
Is this something other Volvo owners are/were experiencing. I would appreciate it if I could get some insight on what could be wrong since it only happens sometimes.
post Feb 7 2006, 08:23 PM
:huh: :huh: :huh:
Like ... are you serious...???
:o
S60 R
post Feb 8 2006, 02:05 AM
Drives: 2005 S60 R
Ive heard of something kind of like this, but with slush and the noise coming from the driveshaft. Dont remember what the fix was though.
mgi
post Mar 22 2006, 07:01 PM
Could you please try and remember what the fix was? I was going to take the car to the dealership for 7K service and could ask them to check it.
Thanks in advance
Viper_7
post Mar 23 2006, 09:26 AM
Drives: 2005 S60 D5 SE
A 'siren' type noise. Like a squeal? Could be a belt slipping?
My old motor was the same when wet in the mornings.
As you state it only happens under acceleration when the belts spin up.
Usually the Alternator drive belt that is the culprit as the surface area contact between it and the belt is small.
They are usually notched these days to avoid this though, but not sure about our models...never looked!
Vipes
S60 R
post Mar 23 2006, 08:22 PM
Drives: 2005 S60 R
Its not the alternator or a belt. Ive heard of the same issue with, but with slush. Experienced it myself with slush. Has something to do with the driveshaft. And trust me, the sound needs no explination...you'll know it when u hear it.
If I find what the fix was, will post.
S60 R
post Mar 24 2006, 12:07 AM
Drives: 2005 S60 R
It looks like there are some various schools of thought about the fix, but seems to be cold water/slush causing driveline to exhaust contact.
http://forums.swedespeed.com/zerothread?id=50379
http://forums.swedespeed.com/zerothread?id...d=464700#464700
http://forums.swedespeed.com/zerothread?id=50210
http://forums.swedespeed.com/zerothread?id=50046
lbrockman
post Jul 20 2006, 05:28 PM
Drives: '02 Volvo S60 AWD, '94 850
Hi, MGI - I had the same issue on my 02 S60 AWD. It really freaked me out, and I ended up buying new tires to replace the unevenly-worn tires that the car came with when I bought it. Of course, then I found out about this TNN (tech net note). I have the factory bulletin that addresses the issue, and I just today bought the kit that will fix it. It is Volvo part # 30742265 - it replaces 2 related exhaust hangers near the area affected, and rubber hangers that go with them. Here's the text of the problem:
DESCRIPTION: Under certain conditions when driving through puddles of water, slush and or snow, the underside of exhaust system may cool down fast enough causing the exhaust to change shape and touch the propeller shaft, causing a very high pitched squealing noise. This noise will be noticed by the driver for only a short time, once the exhaust temperature equalizes the noise will disappear. If the customer should have this complaint a tell tale mark will be left on the propeller shaft.
This covers almost all AWD S60's and V70 AWD cars out there, except the R's from what I understand. If you want an e-mail copy of this, get me your e-mail address and I'll send it.
- Lynn
fishertheband
post Nov 13 2006, 10:31 AM
Drives: XC90/S60R
My 2006 R did this a few times driving in very very heavy rain.
Glad to know there is a fix now. Thanks for the info.
dkemmel
post Jun 29 2007, 12:26 PM
Drives: Chevrolet
If your car is experiencing problems, you should think about seeking legal help. The site I use when I have a problem is http://www.volvoproblems.com. They really helped me out with my S 60.
MichaelF
post Aug 1 2007, 11:41 AM
Drives: 2004 Volvo S60 2.5T AWD, 1987 Corvette, 2000 GMC Yukon XL
I had the same problem with my 2004 also. I took it back to the dealer and they had received notification of a fix. As someone has said it is caused by water up in the driveshaft area. As I recall they replaced/adjusted ( I don't remember exactly which) the shield that is in that area. I seem to recall that there is a shield between the cat converter and the driveshaft. Anyway, no problems since then and I have had ample opportunity to test this out the past couple of years.
jimik3567
post Dec 13 2007, 11:07 PM
Drives: Volvo S60 AWD 2.5 Turbo
lbrockman, Thank you for your informative post! We went to the dealer a million times and they didn't bother to research the problem or troubleshoot it. I will gladly print your post and stick it it the service manager's face!
02 S60 Transmission Interchange With Later Models
brian_d_clark 9 0 Today, 12:51 PM
By: brian_d_clark
S60 Aw55-50 Valve Body
brian_d_clark 21 1 Yesterday, 07:34 PM
By: S60 R
Volvo 850 Single Wiper Conversion
swedseed850 81 14 Yesterday, 02:44 PM
By: swedseed850
"check Engine" Light Vs. "service" Light
rosso75 18 0 Yesterday, 12:50 PM
By: rosso75
What Is The Best Engine Oil?
bigbird2008 585 9 Yesterday, 09:50 AM
By: bigbird2008
Time is now: 7th August 2008 - 02:59 PM
