> Xenon Upgrade Low Beam Failure (2005 - V50), Installed HID's low beams get LBF
V50T5
post Jan 12 2006, 04:30 PM
Drives: 2005 - V50 T5
I installed a Xenon light kit for the low beams with separate fused power feed and relay switched from the factory lights. After the installation, the I got a low beam failure message in the message center and the lights went off. There was a buzzing in the dash but I could not locate it. I checked under the glove box but there is only a fuse tray, nothing under the drivers side that I could see.
Without starting the car, the lights come on and stay on. Only when the car is started do the low beam light go out and the buzzing starts. The relay pulls less amps than the factory halogen lamp and I think that is why the computer thinks that the light is burn't (failed). Any help with fixing this problem is appreciated.
Thanks!
S60 R
post Jan 15 2006, 01:52 PM
Drives: 2005 S60 R
Read throught the links in the below post for the technicals, but theres a mod u have to make to the ECU;
http://www.volvo-forums.com/t5735-hid-39-s.htm
V50T5
post Jan 30 2006, 01:21 PM
Hi S60R!
This fix is not possible for the V50 as it does not have the same setup as the S60, V70. The low beams are powered through the CEM (central electronic module) located under the glove box. This is different compared to the S60, V70. If you have info for the V50 that would be great!
Cheers....
S60 R
post Jan 30 2006, 02:39 PM
Drives: 2005 S60 R
QUOTE(V50T5 @ Jan 30 2006, 02:21 PM)
Hi S60R!
Cheers....
[right][snapback]23268[/snapback][/right]
The S60/V70/S80 are all powered through the CEM, and it sounds like yours is too. If they are all powered through the CEM, and the CEM's are similar, it should work even if on diff sides of the dash. Did u look at the shunt to see if it was similar? IF the CEM's and/or shunts are diff and it wont work, there was contact information on that website or call the manufacturer
V50T5
post Feb 2 2006, 02:09 AM
I will have to take a look at the CEM again but I remember it eing quite different from the S60/V70. The largest component on the CEM is the size of a relay (1"x1" approx). It is very difficult to get to, there is a tray that allow if to come out a bit but I will have to disconnect a few wires and completely remove it to get a good look.
As for contacting the manufacturer, good luck with that one. I tried a couple of times only to get the dear in the head lights to so speak. Either the dear or, bring the car in and I can have one of my techs try to figure it out....$100/hr bunny trail, no thanks....
I will consider using the contact info on the website once I have got a good look at the CEM and I cannot determine which resistor (if at all accessible) needs to be replaced with one of higher resistance.
Anymore tips, please send along.
Cheers....
No New Posts 2005 Xc90 T6
To purchase or not?
8 alikat 599 21st November 2008 - 10:49 AM
Last post by: ESO
No New Posts V50 T5 To Xc90 V8 Executive
Wabnting to Upgrade
1 students 20 19th November 2008 - 09:27 PM
Last post by: bikz
No New Posts V50 T5 To Xc70 2.5t
Wanting to upgrade
2 students 17 12th November 2008 - 11:43 AM
Last post by: students
No New Posts V50 1.6d Is Rubbish
0 AJ740 23 10th November 2008 - 03:51 PM
Last post by: AJ740
No New Posts V50 Pressure Valve
0 dadazuzu 24 6th November 2008 - 01:24 PM
Last post by: dadazuzu
Time is now: 23rd November 2008 - 06:14 AM
