> No Washer Fluid Action!
VanCityBoy
post Nov 20 2005, 12:57 AM
Drives: 85 Volvo 240 GL
Tonight it was foggy in our fair city and I went to wipe the mist off my window with the wipers and it was pretty dirty and messy, so I tried the washer fluid by pulling the wiper handle back towards me and nothing. The reservoir is full, so I not sure what the problem could be.
Any thoughts?
-Todd
I have a nut lef...
post Nov 20 2005, 05:41 AM
Hey Todd.
With the engine not running and key in the ignition position, you should be able to hear the pump buzzing when you pull the lever on the column.
If the pump runs, locate the blockage by getting someone to pull lever on while you get under the bonnet and pull the pipework off the pump, T-pieces, and where they join onto the nozzle. Start at the pump first so that you can isolate the problem as electrical or blockage.
Also, if you wax / T-cut your car, the little black squirter nozzles on the bonnet get blocked, you can clear with a thin needle.
Stu.
VanCityBoy
post Nov 20 2005, 07:50 PM
Thanks Stu. And if the pump doesn't run? I don't hear it so that may be the problem.
-Todd
volvo240-4-life
post Nov 20 2005, 09:17 PM
Drives: 1989 Volvo 240 Dl, 2001 Pontiac Grand Am
test the pump with a multimeter an see if its getting anypower. there is a good possibilty that the pump may have died becaues i had the same problem on my 89 240 an it turned out the windsheild wiper fluid motor needed replacing
-Travis
VanCityBoy
post Nov 21 2005, 12:05 AM
Cool. Thanks Travis. Will check that tomorrow.
-Todd
phork
post Dec 22 2005, 07:19 AM
Drives: 1990 Volvo 240 DL
How did this turn out? I had this problem but I deturmined that it was pumping (since water came out of the hose prior to the sprayer), I stuck a thick needle in the underside of the sprayer, and a wad of green slime came out. Same with both sides, but after cleaning it out, only one sprayer will work. I tried a thin needle on the topside of the sprayer, has had no effect on it so far...
I have a nut lef...
post Dec 22 2005, 10:57 AM
Phork,
You could try taking the spayer off, and soak in vinegar overnight.
Worked for me.
Stu.
volvo240-4-life
post Dec 23 2005, 09:50 PM
or phork u may need to replace the lines from the pump unit to the sprayer because there may be a object logged in the line
~Travis
No New Posts Norcal 2008 Charity Toy Drive & Exotic Rally
0 m3dragon 5 19th November 2008 - 02:54 PM
Last post by: m3dragon
5 elmwoodblues 23 18th November 2008 - 09:56 PM
Last post by: elmwoodblues
No New Posts Normal Temp Gauge Behaviour?
1 CJT156 255 10th November 2008 - 08:37 PM
Last post by: gobies
No New Posts No Blinkers Or Break Lights On My 1970 Volvo 142s
0 jittest1 8 10th November 2008 - 08:11 PM
Last post by: jittest1
No New Posts No Breaks, New Pads Rotors, No Leaks
4 stevet 31 10th November 2008 - 05:48 PM
Last post by: stevet
Time is now: 21st November 2008 - 04:01 PM
