> Turbocharger Unhappy, Spools up, but no boost
CGodfrey
post Sep 1 2005, 08:50 PM
Drives: 1997 Volvo 850 R Wagon
I noticed today that my turbo charger with 115k miles on it is sick, if not dead.
It will spool up to the point where it would kick in (white on the gauge) but then stops.
No woosh, no boost, no nothing
Does this sound like a dead turbo to the professional techs out there, or something less serious
post Sep 2 2005, 07:10 PM
Check the vaccum lines near the turbo.It might be going into overboost.
850Rarg
post Sep 26 2007, 07:45 AM
Drives: 855R ; 240 SW
Mine is doing the same trick.
In this case, the battery went drained because i left the trunk light on for the whole weekend. I did jump start and from then on the boost is gone all of a sudden.
Could it be some software issue?
post Oct 8 2007, 02:47 AM
How is it now?
850Rarg
post Oct 8 2007, 07:46 AM
Fine!
The problem was not software neither hardware.
Was a mouse! The damned rodent chew a pack of wires that go beneath the battery.
Fixed the roded wire my boost is back.
post Oct 13 2007, 08:07 AM
Hehe.
OK, thanks for the input.
850meister
post Oct 23 2007, 08:29 AM
Drives: 1996 Volvo 850 2.5 20valve, 1987 Volvo 360, 1994 Volvo 940 TD, 1989 Volvo 760 Turbo Intercooler
If not an air leak it may be a faulty boost sensor - That is cutting the boost before it really kicks in.
Usually when a turbo fails it either seizes - very limited performance results or the oil seals fail giving a serious amount of smoke out of the back! I'd check the intercooler pipe work for leaks too -
Probably not serious in terms of the turbo itself maybe resetting the ECU might help?
aquaVolvo
post Jan 14 2008, 09:15 AM
Drives: 1996 850 Turbo
I have the same/similar issue with my 1996 850 turbo. Some time back I blew an oil coolant line off, since then I have had no boost, gauge goes up to the point of boost and then just sticks there. I thought I had a bad turbo, because of the sudden loss of oil pressure. I bought a new 15g, when I went to put it in yesterday I pulled the intake side off of the turbo and just for kicks checked the turbo before doing major surgery, and the shaft is spinning freely and there seems to be no play in it. I don't have any oil burning issues either. I checked all the vacuum lines and they seem ok. Still no boost - any suggestions? What wire did you find chewed/corroded, how do you reset the ECU?
thanks
QUOTE(CGodfrey @ Sep 1 2005, 08:50 PM)
[right][snapback]14563[/snapback][/right]
post Jan 15 2008, 04:15 AM
QUOTE(aquaVolvo @ Jan 14 2008, 10:15 PM)
thanks
[right][snapback]69725[/snapback][/right]
Check ALL the vacuum lines to see if they are OK. Check for leaks especially. Since you 15G is new, i guess there is no point in asking you to check it.
To reset the ECU? Yours is OBD2, you'll need the code reader tool.
850Rarg
post Jan 16 2008, 11:59 AM
To find the pack of wires that control boost action you will have to remove the battery. There you should find it. Right in front of the battery shelf.
post Jan 20 2008, 03:12 AM
QUOTE(850Rarg @ Jan 17 2008, 12:59 AM)
[right][snapback]69878[/snapback][/right]
If you're referring to the TCV (Turbo Control Valve), it is originally attched to the air filter box, actually.
montegoodyk
post Jul 1 2008, 12:04 AM
Drives: Volvo 850 Turbo
I had the same problem. This afternoon I disconnected the wastegate vacuum line on the TCV. Worked like a charm. My boost is back. I hope this doesn't damage anything. Any ideas?
post Jul 1 2008, 05:08 AM
Well, i too have disconnected the TCV to all the vacuum hoses. Since i am using Daewes Device, the settings are like that. I dont know why, but it seem to work. I was able to increase the boost to 1.12 bar (recorded peak, but i suspect is a spike)
But if you disconnect the cable to the TCV, you will get a lambda error.
No New Posts Turbocharger S40
turbo
0 chobe 72 27th August 2008 - 02:33 PM
Last post by: chobe
Time is now: 3rd December 2008 - 07:04 PM
