2 Pages V   1 2 >
> Srs Airbag Service Urgent And Other Crazy Things!
Mitch Pelletier
post Sep 19 2012, 05:52 PM
Drives: 2004 Volvo XC70, 2005 Volvo T5 AWD
Hello all...
Ok, this one is crazy: was driving today and my dome light suddenly came on. Then I noticed a bunch of lights in the dash with the Traction Control Problem message in the display. Then immediately followed by the SRS AIRBAG SERVICE URGENT. Then my gas gauge drops to 0. Then my wipers are stuck on. Then my signal lights stop working. Then my key fob doesn't let me lock or unlock the car. Then my climate control temperature isn't working properly. Then my hatch doesn't open. (IMG:style_emoticons/default/haha.gif)
As much as I love this car, it's getting the best of me time wise for repairs and $$$ as well. Blah...
I am searching around on the forums, but would appreciate some help if anyone has seen this before.
Thanks!!
-Mitch
2005 V50 T5 AWD
danielm85948
post Sep 19 2012, 08:33 PM
Expert Veteran
QUOTE (Mitch Pelletier @ Sep 19 2012, 06:52 PM)
Hello all...
Thanks!!
-Mitch
2005 V50 T5 AWD
check the output for your alternator and the power in your battery may be low.
Mitch Pelletier
post Sep 19 2012, 08:56 PM
QUOTE (danielm85948 @ Sep 19 2012, 10:33 PM)
Thanks. I am getting 12.74V with the car not running and 13.74V with the car running. That should be fine I think?
danielm85948
post Sep 20 2012, 08:10 AM
Expert Veteran
QUOTE (Mitch Pelletier @ Sep 19 2012, 09:56 PM)
switch on your lights and heating and other things with the car running now check again as it can be two things,one being power is low,and the other is your ABS relay is failing,you will find that in a small black plastic box under your ABS module,the solder in the relay starts to crack and open up due to the heat.
Mitch Pelletier
post Sep 20 2012, 08:14 AM
QUOTE (danielm85948 @ Sep 20 2012, 10:10 AM)
Thanks Daniel, I will check that right away. Where is the ABS module located?
danielm85948
post Sep 20 2012, 08:23 AM
Expert Veteran
QUOTE (Mitch Pelletier @ Sep 20 2012, 09:14 AM)
your module has 4 brake pipes going to it ,look in your engine bay, it can be on the left or right hand side you at the front of the car, the pipes are on the top of the module, look down under that module to see the black box.in the box is your relay.
Mitch Pelletier
post Sep 20 2012, 08:38 AM
QUOTE (danielm85948 @ Sep 20 2012, 10:23 AM)
I juste cleaned all battery terminals, turned everything on the car and was getting 13.84V going to the battery.
I checked for the module and found 2 brake lines going underneight my battery, so looks like I would have to take the battery out and the battery tray to get at it.
danielm85948
post Sep 20 2012, 09:37 PM
Expert Veteran
QUOTE (Mitch Pelletier @ Sep 20 2012, 09:38 AM)
should be 4 brake lines, not two ,going to your module.
Mitch Pelletier
post Sep 26 2012, 07:25 PM
I had taken my DIM out from the dash and brought it over to a local electronics shop in order to have all of the connections resoldered. They did that and checked everything out. I reinstalled it today and unfortunately, all of the same symptoms are still there.
I made an appointment to the dealer for Friday morning. They are 2hrs away from me. We'll see how that goes!
danielm85948
post Sep 26 2012, 09:36 PM
Expert Veteran
QUOTE (Mitch Pelletier @ Sep 26 2012, 08:25 PM)
as i said i think the trouble is your ABS relay so get them look at that.
Mitch Pelletier
post Sep 27 2012, 08:58 PM
QUOTE (danielm85948 @ Sep 26 2012, 11:36 PM)
Thanks Daniel. It sits underneight my battery, so I took that out this evening. Took the battery box out and I saw where it was, although it does sit behind this plastic separator on the firewall, so I really couldn't get at it easily.
Can that relay be repaired? If not, what do you think the replacement cost would be?
We'll see what they say!
danielm85948
post Sep 28 2012, 05:16 AM
Expert Veteran
QUOTE (Mitch Pelletier @ Sep 27 2012, 09:58 PM)
you would be better to replace it,but to repair it,would mean to take off the cover on the relay,then resolder the contacts ,as they crack open due to the heat,think it would be cheaper to replace it,try this FCP Groton on this site,or on ebay.
Mitch Pelletier
post Sep 28 2012, 09:29 AM
QUOTE (danielm85948 @ Sep 28 2012, 07:16 AM)
I'm at the dealer now and the car has been in for about 1hr. They just brought me in the shop to see the tech and he told me that the entire low voltage network was down. There are 8 modules on that and he's going to unplug them 1 by 1 and see if he can find the one that is the issue.
He said if that doesn't work, then there is a short in the wiring harness somewhere, which I define as trying to find a needle in a haystack!
Mitch Pelletier
post Sep 28 2012, 03:12 PM
QUOTE (Mitch Pelletier @ Sep 28 2012, 11:29 AM)
Just got back from driving 2hrs to and from the dealer and spending about 4hrs there.
The tech seems to make sense and I can't fault him for his thinking as it is pretty methodical. After about 1hr, they came to get me and told me that basically all of my low voltage communication link was down. The main CEM is working fine.
In order to properly diagnose, he would have to check each of the 8 modules/computers in order to see if there was an issue with them. I told him to go ahead and then let me know how that went.
After about 1.5hrs, they came back and told me that all the modules tested fine. The next step would be that there is something in the wiring perhaps to them that isn't working. He advised me that sometimes there were issues with door connections and that was the first thing he checked and mine was fine.
At each of these steps, they would let me go in the shop and discuss directly with the tech.
Since I couldn't stay longer, I told him to just make the car direveable for me until I figure out that I wanted to do. He said that he would remove the rear seat to get at the main wiring harness going back there as well as start removing some of the carpeting at the driver's side seat/footweel and check that as well. I told him that I would remove the seat and the carpeting, etc. to save that for next time.
SO, good news is that it seems the CEM is fine as well as the modules (including my DIM and the ABS relay) tested out fine. Bad news is that it's all labour in trying to find what is going on.
I asked him if he had seen this before on these cars and he told me that was quite rare on this model, but others this had happened on.
The bill today was $311.50 plus taxes.
danielm85948
post Sep 28 2012, 10:49 PM
Expert Veteran
QUOTE (Mitch Pelletier @ Sep 28 2012, 04:12 PM)
so did they say what was wrong.
Mitch Pelletier
post Sep 30 2012, 07:48 AM
QUOTE (danielm85948 @ Sep 29 2012, 12:49 AM)
They mentioned probably a wire to one of the 8 modules, or a connector. A pain to trace and $$ on labour!
As of now, I still can't drive my car because my turn signals don't work.
danielm85948
post Sep 30 2012, 08:08 AM
Expert Veteran
QUOTE (Mitch Pelletier @ Sep 30 2012, 08:48 AM)
well that can be the switch,or the relay,or your fuse, but i would say check the connector.
Mitch Pelletier
post Oct 1 2012, 06:27 AM
Post #18
QUOTE (danielm85948 @ Sep 30 2012, 10:08 AM)
Yes, looks like the fun is only beginning. They are going to look at the line going to the rear of the car, if everything there is fine, then it will rule out the rear. Then they will focus on the front modules.
Mitch Pelletier
post Oct 3 2012, 06:45 PM
Post #19
QUOTE (Mitch Pelletier @ Oct 1 2012, 08:27 AM)
So apparently, perhaps someone (not me, honest) had played in there before (I've had the car for 2.5yrs) and got them messed up while closing the cam on the connector.
Crazy eh?????
With regards to my battery light being on for approx. 1 year (about a few days after I installed the Volvo alternator), they traced it back to a problem on the alternator and said that it need to be replaced. I told them I had bought an original Volvo alternator and asked when the warranty was. They said it was 2yrs/unlimited mileage on parts only as I had installed it myself. SO, as long as I can find my receipt, they will give me a $523 alternator! I don't mind putting it in myself.
Thanks to everyone for their help!
derbyshire007
post Oct 6 2012, 01:28 PM
Post #20
Drives: 2006 volvo v50 2.0d
Hi There
I have a 2006 v50 estate 2.0d, and just like yours mine came up with srs service urgent aswell as trailer service urgent and the electric windows, electric mirrors and the central locking all stopped working.
after looking on various forums and help sites today i thought it was going to me a main dealer fix at great expense, but after a quick chat with my brother he said it sounds like a BODY CONTROL MODULE issue, after further looking on the internet i found this to be located in the passenger footwell beneath the glove box.i took out all the relays cleaned and replaced all the fuses and some of the problems had dissappeared, i rechecked all the connections and wiggled the unit as i put it back and all of my issues have been fixed. sounds like you have a similar problem and you might be able to fix it like i did in 10 mins flat without any expensive garage bills its got to be worth a go. heres what faults my care came up with :-
srs airbag service urgent
trailer electric service urgent
electric windows not working
electric mirrors not working
central locking not working
its sorted out all my problems so id recommend checking this module in the passenger footwell good luck with your issues hopefully mine are now sorted cheers jon
« Next Oldest Volvo V50 Forum Next Newest »
2 Pages V   1 2 >
0 HRPOWER 257 19th October 2016 - 06:22 PM
Last post by: HRPOWER
No New Posts Urgent Help Required
limp mode? temp gauge/warning light
3 Chuttz 221 4th July 2016 - 10:43 PM
No New Posts Srs Airbag Light And Clock Reset After Battery Disconnect
battery disconnect
3 Edwin Yau 3,177 9th January 2016 - 08:16 PM
Last post by: Platypup
No New Posts Srs 0095 After Car Wash!?
4 sddynamix 404 11th November 2015 - 12:37 PM
Last post by: sddynamix
No New Posts Srs Module Location
where in console is it
1 secoug 786 21st April 2015 - 01:53 PM
Last post by: secoug
Time is now: 26th February 2017 - 09:34 AM
