2 Pages V  < 1 2
> C/v Axle Removing Instructions.
swedseed850
post Oct 24 2008, 04:08 PM
Post #21
Drives: 1994 volvo 850 turbo
retaining clip.
post Oct 28 2008, 08:29 PM
Post #22
Expert Veteran
Here're some photos of the 850 Turbo driveshaft i took last night.
I just wanted to highlight the size and also the teeth at the end of the driveshaft.
To show that it should be able to just be slid-out once all is disengaged.
Edit:
Argh. No i am told i cant post images.
Hmmm... Leeme see whats wrong.
This post has been edited by ampangbear: Oct 28 2008, 08:46 PM
Mushahidi
post Nov 1 2008, 10:44 AM
Post #23
Drives: 850 GLT Wagon 1997
Hi, I'm also hearing some rattling noise when turning right (when driving slow). How can I know if it's the CV and if it is, is it a serious problem or can I wait in fixing it until I have some cash at hand?
post Nov 1 2008, 10:12 PM
Post #24
Expert Veteran
QUOTE(Mushahidi @ Nov 1 2008, 11:44 PM)
[right][snapback]95474[/snapback][/right]
Usually, a problemmatic CV is triggered after the CV boot is torn. Though sometimes the inner wear is too much that you'd be able to feel the vibration from the tyres as you accelerate. The harder you accelerate, the more you feel it.
Under the car
If you can lift the car or get under the car without lifting it (use your imagination, dude - like curb parking, :haha: Hehe) try to see if the CV boot is torn. Look for traces of grease.
Inside the wheel well
Sometimes, without even removing the wheel, you'd be able to tell if the CV boot is torn. Sometimes, you may have to. Look for a circular trace of grease in the wheel-well's wall. (Hey, try to say that 10 times, fast!)
Wheel-well's wall!
Wheel-well's wall!
Wheel-well's wall!
Wheel-well's wall!
Wheel-well's wall!
OK,ok...sorry.
Good luck.
post Nov 12 2008, 08:21 PM
Post #25
Expert Veteran
OK, here's another try. I hope this one gets through.
Again, sorry for the long wait.
Hmmmph!
Darned it!
Message i received was
"Upload failed. The file was larger than the available space"
That cant be right. The file size is only 51kb, while the limit is supposed to be 2MB!
(IMG:style_emoticons/default/sad.gif)
Nadeeeeeeeeeeeeeem...
Help.
ampangbear2
post Nov 20 2008, 12:23 AM
Post #26
Group: Moderator
Drives: 1996 Volvo 855T5 FWD, 1989 Honda Civic 3-Door FWD
I got a little tired of waiting, so i signed is under a similar username, and am trying to upload the photos. Hopefully it works this time. (No reason not to, cos this is under a different username)
Cheers.
Edit:
Yeay! It got through!
Wooohooo!
Attached File  004_DriveShaft_Bracket___Nuts.JPG ( 25.77K ) Number of downloads: 30
Koziolek
post Dec 7 2008, 07:49 PM
Post #27
Drives: 1997 Volvo 850SE
Hi
Im having a problem to remove drive axle from hub I tried every thing even 3 jaws puller and nothing cant remove ,I have done this on so many cars in my live and have no problem.
It looks like hardly stock I use hammer hevy one an puller no suckces.
any sugestion?
post Dec 8 2008, 10:45 PM
Post #28
Expert Veteran
We used a flat, solid 90degree prybar to edge it out, bit by bit, if it is stuck. Try that.
Maxy
post Jun 22 2011, 01:26 AM
Post #29
Drives: Volvo V40
I want to hear pmohr and use a lever to remove the HP into the tranny. Slow and steady wins the race, if you know what I mean. Just put it in the box between transport and the body gradually resume and apply preasure. Be careful not to damage joints, although you really need to have an opportunity to leverage to do so. Just be careful and you should be fine.
mtd240
post Mar 11 2014, 07:46 AM
Post #30
Drives: 1990 Volvo 240 DL
Can anyone point me to a "how-to", or any advice, on pulling a rear CV axle? One of the axle seals on my '98 V70 XC is leaking.
Cold_Surfer
post Feb 22 2015, 07:42 AM
Post #31
Drives: 2000 Volvo V40
I left the lower ball joint alone and pulled the top two 18mm strut bolts and loosened the 15mm strut mounts in engine compartment. Did not remove the tie rod end. then allen wrench in the stabilizer and 15mm to pull the top nut off from the strut. removed 15mm caliper bracket bolts and calipers, suspended it with a bungy cord. 36MM impact to remove big nut with tire on the ground. 12mm cap bolts for passenger side.
torques on reassembly:
12mm cap bolts 18 ftlbs and lock tight
strut mount - top - 23 ftlbs
lower 18mm strut bolts - 58 ftlbs
main bolt 81 ft pounds and then another 90 degrees (could not turn to 120 like the other spec - it went to like 300 ft pounds suddenly at about 90 degrees) -- comments ???
sway bar link about 25 but that is all I could get on it without fear of stripping the allen
lug nuts 81 footpounds
caliper bracket bolts - 3' breaker bar - as tight as removal. probably 80 but not sure
orangeworx
post Jan 9 2016, 11:08 AM
Post #32
Drives: '01 S40 1.9T - '02 S40 1.9T
Hey guys,
I've found most of the information here useful for my axle overhaul, I have an '01 and an '02 S40 (manuals show slight differences in setup albeit none that I saw)
My only issue with the overhaul is on the outer side... When I took apart the joint, balls, cage and star shape thingie, I didn't notice how those things were placed (yes there's an up and down postition), partly because the last time I'd done an overhaul was too freakin long to remember and because the grease was so mucky, I couldn't see much.
I'm adding pics maybe someone has been there and seen this.
The star shape thing is what attaches to the shaft (has a clip on there), it has the clip notch which is not centered.
I tried checking for exploded views, mitchell ondemand and alldata, nowhere did I find the orientation of these parts for reassembly.
Hope someone's got some insight...
This post has been edited by orangeworx: Jan 9 2016, 12:08 PM
derekbrian
post Mar 21 2016, 06:03 AM
Post #33
Drives: BMW 2 Series
If you go thorough Hayne's manual you will step by step came to know about C/v Axle Removing Instructions.
3 User(s) are reading this topic (3 Guests and 0 Anonymous Users)
2 Pages V  < 1 2
No New Posts Removing 2016 Xc90 Tailight
Tailight
0 Steddy73 11 18th February 2017 - 01:21 AM
Last post by: Steddy73
No New Posts Removing The Fuse Panel
Getting access to lower fuse panel
2 Square Jack 919 31st August 2013 - 03:12 PM
Last post by: Kiss4aFrog
No New Posts Removing Kick Panels?
3 mememe 2,190 14th April 2013 - 01:37 AM
No New Posts Removing The Headlamps
5 willieli 1,003 9th March 2013 - 07:46 PM
Last post by: grendel1960
No New Posts Cvvt Solenoid
0 martigan 1,932 9th March 2013 - 06:34 PM
Last post by: martigan
Time is now: 20th February 2017 - 08:27 AM
