> Fuel Issue? Possible Tps?
damnyak
post Dec 4 2011, 07:18 PM
Drives: 1988 volvo 240 DL
Hello everyone, I have been chasing a issue with my 88 244. I seems at random times (speed, rpm, and temp, different all the time), the car will bog, tach does not drop, just slowing coasts as the throttle does nothing. like its out of gas. I am a super amateur mech. But super low on funds (as we all are) so i have changing things by myself. learnng more about my car everyday.
Things I have changed
-Pre pump was not working, New put in, works now!
-New sending unit, wired backwards. (Art from Cleanflametrap help me huge)
-New MAF
-New Plugs, cap, rotor.
-New Filter and Man pump.
-Cleaned throttle body.
-Checked for vacuum leaks
-Tested Idle valve, all correct.
My question is After I got the pump in (runs great quiet as a lamb) However the idle is still rough, and you could here it wanted to bog a couple times, So i tried something, I pulled the Throttle position switch plug out of the TPS, and it picked back up, sounded healthy. No immediate hesitation. Sounds 10 x better? I am wondering if anyone have any experience with the TPS. Can I drive around with the TPS unplugged, to test drive it. will it damage the car. If I put a new one in will it, act the same, or is this the sign of a bad TPS? I hope I make sense. Like the TPS is working properly and that's how my car sounds, and when I unplug it, its false and running poorly, even though it sounds better? I hope I make sense. And also reading the bentleys, It kind of confusing the adjustment of the TPS, as there is no photos etc. and i am not sure of the "adjustment screw" etc. Any help would be appreciated, Pics, Etc?
Chris
sowsley
post Dec 4 2011, 10:46 PM
Drives: 1987 Volvo 240 DL
Chris,
I'm going through the same thing as you, but I think I know what the problem is. Cleaning the throttle body probably caused the TPS to be out of adjustment, so the computer doesn't know when the car should be idling. I had the chance to play with a couple of '87 / '88 240's today at the junkyard, and was checking to see if I could hear a click and at what point in the travel it occurred. You should hear a faint click just after you start to open the throttle. With the engine off, rotate the butterfly valve with the large wheel the throttle cable attaches to. If you don't hear a click immediately after you start to turn, or if it happens further in the travel, you will need to adjust it. Did you take the throttle body off the intake to clean it? Makes it much easier to do it right.
It's most likely your tps unit is fine, it just needs to be adjusted so that it is sending the proper information to the fuel injection computer.
sowsley
post Dec 4 2011, 11:09 PM
QUOTE (sowsley @ Dec 4 2011, 07:46 PM)
Chris,
It's most likely your tps unit is fine, it just needs to be adjusted so that it is sending the proper information to the fuel injection computer. Also, did you check to make sure your a/c switch is turned to the OFF position?
The reason I can't give a definitive answer today is because my car went into the body shop just after I cleaned the throttle body, so I'll do that next weekend. Just in case, Rock Auto has a good price on new TPS, check your part number, because I'm not sure the interchangeability between the years and they offer several.
danielm85948
post Dec 4 2011, 11:16 PM
Expert Veteran
QUOTE (damnyak @ Dec 4 2011, 07:18 PM)
-New MAF
Chris
do a compression test, in each of your cylinders, may be down in compression.
damnyak
post Dec 5 2011, 05:48 AM
Thanks for the tips, The TPS does Click, as soon as I start to move it. As for a compression test, wouldn't it start to bog as soon as I started the car. I can go driiving for 30 min or so and its fine then it will bog for 30 sec - 1 min, then I rev and ts fine.
I have had motor ike with bad compression, and you could not go over a certain speed. or it would die on teh spot. This issue I can get it to go over 130 KM/H up a hill, then when on a flat doing 80Km/H it bogs.
Like I was mentioning, can you drive with the TPS unplugged? safely? If unplugging it from the "Circuit", there for eliminating it does that mean it was the issue?
danielm85948
post Dec 5 2011, 07:07 AM
Expert Veteran
QUOTE (damnyak @ Dec 5 2011, 05:48 AM)
change the throttle position sensor just Google one on-line try eBay.but as for compression ,the car can still run just down on power,and will run rough.
damnyak
post Dec 5 2011, 08:29 AM
I found good price on ebay, $50. and plan to change it. But can I drive with it unplugged, till it arrives. Which seems safer than me bogging down on the highway. and I need to get to work. Can it damage the car aside from possibly less MPG.
Me unplugging it and it running better, is that indicative of a faulty switch? or is putting a new one on going to result in the same running conditions as now?
damnyak
post Dec 5 2011, 08:36 AM
Just another thought, Can the Throttle switch "Click" and be faulty ?, cause mine still clicks when I move it a tad.
danielm85948
post Dec 5 2011, 05:55 PM
Expert Veteran
QUOTE (damnyak @ Dec 5 2011, 08:36 AM)
the throttle position sensor , gives information to the ECU so controlling the fuel mix so yes it should still run, but just use more fuel, but it can make the plugs wet with more fuel, starting from cold, so you may have to take out each of the plugs and dry them, so take tools with you.
danielm85948
post Dec 5 2011, 05:57 PM
Expert Veteran
QUOTE (damnyak @ Dec 5 2011, 08:29 AM)
i think that shows the trouble is with your throttle position sensor.
post Dec 6 2011, 10:53 AM
QUOTE (damnyak @ Dec 5 2011, 06:36 AM)
You would need to test it with a ohm meter to be sure.
No New Posts Fueling Up
4 debbieolsen2000 89 11th February 2017 - 10:20 AM
Last post by: Vermont
No New Posts Fuel Door Not Locking
3 VOLVO XC 90 1,387 3rd February 2017 - 03:40 AM
Last post by: Robert Sain
No New Posts Possible Major 2.5t Engine Issues Any Advice Appreciated!
4 bosco80 155 1st January 2017 - 01:55 AM
No New Posts Fuel Injector Fault...again
CE light keeps coming on
5 johnj 302 25th August 2016 - 04:39 PM
No New Posts Fuel Pump Change Now Terrible Screeching On Startup
1 cackmuffin88 203 18th August 2016 - 06:48 AM
Last post by: grendel1960
Time is now: 30th March 2017 - 05:46 AM
