> Xc90 Radio Replacement, XC90 Radio Replacement Questions
sffrancoxc90
post Nov 29 2011, 10:10 PM
Drives: 2005 XC90 5cyl
I recently purchased a used 2005 XC90. The vehicle was purchased with the radio not functioning. When pressing power knob the display would briefly show (3 sec) "Premium Sound" then go blank. In last 2K miles driving, the radio suddenly turned on (about 3 seperate cases) and functioned fine (on/off, channel changing, audio controls, 6 CD changing, etc). It would remain functioning until car was turned off. Wierd part is if I turned ignition immediatly back on, the radio came back on, but if car sat for approx 5 minutes or more, then radio returned to its non-functioning state.
I was wondering if anyone had seen/fixed a similar issue ...could it be a cracked fiber optic cable ?
Looking to replace radio...was wondering what years are compatable. I am under impression that any change will require a s/w update.
Thanks in advance for all your inputs.
jmac2005XC9
post Nov 30 2011, 10:19 PM
Drives: 2005 VOLVO XC 90
I am in a similar situation. I also have a 2005 XC90 with a broken CD players. We have a few CDs in the player that we can't retrieve. The radio works, but the CDs won't play and as I stated are stuck. I'm told I will most likely need to replace the unit. I was quoted $575 for a used one that may or may not need a software update and $900+ for a new one that will need a software update.
For that money though I would rather buy a new unit from Best Buy or some other car stereo retailer and get iPod connections, DVD playback, etc. The problem I am having is it appears no deck fits the XC90. bestbuy.com says this will work: Pioneer - 50W x 4 MOSFET AV H-P3300BT but Amazon says it isn't compatible.
Has anybody ever found an aftermarket cd unit that works in these cars?
Jandonskie
post Dec 10 2011, 06:17 PM
Drives: 2004 Volvo XC90 T6 AWD
QUOTE (jmac2005XC9 @ Nov 30 2011, 10:19 PM)
I changed out to the Pioneer AVH 3300BT set and new facial for a total of about $800 via soundgurus.co.uk
All the parts required to install the AVH 3300BT:
Pioneer AVH 3300BT £350.00
Double DIN Fascia & Locking Cage £100.00
Wiring Harness £15.00
Aerial Harness £10.00
Steering Control Harness £100.00
Total £575.00
The initial "module" for steering control did not work, but Sound Gurus sent another one that ensured my steering controls work with the new radio set.
BUT, Note that except the dealer "de-install" the OEM radio from the car, you must run a set of wires to connect the OEM radio even while the Pioneer is installed. I kept the OEM radio in the space under the Pax seat where the OEM Amplifier used to sit - until I get a dealer to de-install via software. If not done, the climate control and other functions will not work in the car!
VolvoDownunder
post Dec 12 2011, 02:07 AM
Drives: 2006 XC90 2.5 and 2008 S40LE
My daughter had a similar issue with the radio in their 2009 XC70. It was still under warranty and was replaced by the dealer. Appears more cost effective to replace than repair. Perhaps an alternate to purchasing a new radio is to try a breakers yard or seek out a good radio repairer who may do a replace/rufurbish service.
gustaf64
post Feb 9 2012, 02:19 AM
Drives: 2004 XC90 T6 AWD
Jandonskie, your system sounds more or less exactly what I want to do to my -04. A few questions;
Did you keep the OEM amp or does the Pioneer have one in-built and was this enough?
I assume you kept the OEM speakers. Did you manage to connect all of them? I have the High Performance system so 11 speakers in total.
Do you still hear the Reverse Warning? I assume you do, but does it mute your new stereo?
Did your setup include Bluetooth and did SoundGurus supply you with all of that kit too?
Did the harness for the steering wheel include the controls for the phone?
I imagine you did the install yourself.
If you have any pics it would be nice to see the finished install.
/g
spiker12345
post Jun 6 2012, 04:00 PM
Drives: 2005 Volvo XC 90 AWD
In reply to the above problem, I have a 2005 XC 90 too with this same problem. I just took it to the Volvo Dealer and they said I have a defective "Infotainment Control Module" at a cost of $1,500. Thats why I here to see what other owners have to say about this problem.
kmvolvoxc90
post Dec 23 2015, 09:19 PM
Drives: 2004 Vovo XC90 T6 AWD
Hello everyone that may be on, or not on this site , i have a volvo xc90 t6 and looked everywhere for information on the radio problem these all seem to have . Not much information on how to actually fix these as opposed to where someone can buy a replacement !!!! A simple reflow of the processor chip can fix these modules (I.C.M) with years of future listening pleasure. I tried used ( $300 ++++) and don't always last and the aftermarket is just too expensive for my liking,so I tried a reflow with a heat gun and a hand held digital thermometer ( laser pointer style, more accurate the better). With both the boards removed from the center portion of the stereo lay them on a flat heat resistant area , I chose a faux glass cutting board ,with processor chips facing up ( glass down on matrix display) heat the entire board closely watching the temp and constantly moving . The temp should eventually hit 200+C ( I hit 214 deg C ) pay close attention to the processor chip as it will hold heat more than the rest . after the temp is reached , let cool to at least 50 deg c before moving the unit, i let them cool to 30- 35 c before touching them, once the unit is cool reassemble and reinstall into vehicle .. note ; if temperature is not fully reached the repair may not last long or will not take at all !! if temp goes too high things will start to melt and board will be unusable !!!!! This repair technique can be applied to most automotive modules and just about anything with a processor chip including pc's laptops ETC...... ........................IF ANYBODY OUT THERE CARES TO SEE A VIDEO I CAN POST ONE, JUST ASK, THANKS FOR READING.....
JimMills96
post Jan 24 2016, 02:43 AM
Drives: 2004 XC 90 T6 AWD
kmvolvoxc90, thanks for your post. Please post video - I am also considering a reflow of my ICM. 2004 XC90.
Thanks.
No New Posts Xc90 "radio" Problem
2 OldCarGuy 434 5th March 2017 - 02:17 PM
Last post by: knightofthelight
No New Posts Radio Replacement Issue
replace radio with factory radio
0 Allynn35611 233 23rd February 2017 - 08:11 PM
Last post by: Allynn35611
No New Posts Radio Unplugged While Battery Connected Help!
I'M AN ****!!
1 Allynn35611 176 23rd February 2017 - 05:34 AM
No New Posts Xc90 2.9 T6 Gearbox Replacement From S80 ?
2 misiek_mati 157 21st February 2017 - 10:11 PM
No New Posts Xc90 Audio Display Not Working
1 Turbogirl7 333 17th December 2016 - 08:27 PM
Time is now: 29th May 2017 - 12:06 PM
