> Blinking Lights On My Climate Control Area, Do I have a fault in my climate control
94-850
post Oct 23 2011, 07:46 AM
Drives: 1994 850 no turbo
I read in the owners manual that blinking light indicate a problem with the climate control. This happens when I start the car. The control that directs the air has no affect on the air.
any suggestions?
SeaMike
post Oct 23 2011, 12:17 PM
Senior Veteran
QUOTE (94-850 @ Oct 23 2011, 07:46 AM)
any suggestions?
Pull the codes.
http://volvospeed.com/volvo_repairs_how_to...?p2_articleid=6
Test:
A7: Instrument Cluster
B1: Climate Control
B5: SRS
Let us know what you find.
94-850
post Oct 23 2011, 07:11 PM
ok I will pull the ocdes tomorrow and let you know!
wyattp92
post Nov 6 2011, 10:00 AM
Drives: 1993 Volvo 850 GLT
I had this same problem with my 1993 850. I got in one day, cranked him up and the lights were blinking for about 20 seconds. Every now and again the ECC (electronic climate control) wouldn't control the airflow, and finally it lost all control. In my case it was the ECC, I took it out and replaced it with one from a salvage yard ($30) and it worked fine. To get the ECC out, first remove you radio, and then push the ECC out from behind. Also IF your fan will not turn off, even when you have killed the engine and removed the key, it is most likely your PowerStage. The transistor most likely went bad. Those are about $180 for an OEM, or you could get one used, but remember the risk of the used ones transistor failing soon as well.
Hope it helps!
(IMG:style_emoticons/default/thumbsup.gif)
grendel1960
post Nov 6 2011, 10:49 AM
Drives: 2000 volvo v70
could also be just low pressure in the aircon and just need a top up.
Grendel
bobbygrady
post Dec 30 2012, 02:18 PM
Drives: 1993 850 glt
I have the same problem with the lights blinking. I pulled the codes and it pulled B1 1-3-1. The driver's side air duct sensor short? I have air blowing good but it's ALL cold. I can't get any HEAT whatsoever. A buddy of mine said the code is the problem. But I just don't know how to fix it. ANY IDEAS OR SUGGESTIONS?
grendel1960
post Dec 30 2012, 04:26 PM
I believe the valves that control the air are motorised so my guess is there is a fault on a motor.
Grendel
SeaMike
post Dec 31 2012, 12:50 AM
Senior Veteran
QUOTE (bobbygrady @ Dec 30 2012, 01:18 PM)
If you car has the Automatic Climate Control, this may help.
B1 -131 IS Duct Temperature sensor driver side; short circuit to ground
Check to see if the rheostat is connected, and maybe replace it.
http://www.tascaparts.com/parts/1993/VOLVO...agramCallOut=14
Check Items: 17, 14 and 12
12 - Opens and closes the FLAP that causes air to recirculate in the cabin.
14 - The is the Temp sensor - If it can't sense the correct temp, the system will dumb out.
17 - This relay may have a effect of the Temp Sensor, but I'm not sure what it does.
No New Posts My "new" 88 240 Wagon Won't Start
0 jnoble 60 3rd October 2016 - 12:27 PM
Last post by: jnoble
No New Posts My Front Passanger Right Door
child lock is not activated. but I can only open the door from the ou
1 bquilla21 155 1st June 2016 - 02:01 PM
Last post by: grendel1960
No New Posts My 1994 960 Volvo Is Leaking Gas As I Pump It. Why?
0 zxx870838557 122 24th April 2016 - 08:23 PM
Last post by: zxx870838557
No New Posts My 240 And I Need Help
Car falls flat on its face when throttle is opened fast.
11 Rich Geister 1,929 4th November 2015 - 10:11 PM
Last post by: Rich Geister
No New Posts Once Again Into The Fray.
0 57gretsch 199 19th October 2015 - 08:19 PM
Last post by: 57gretsch
Time is now: 18th January 2017 - 11:09 AM
