> Initial Starting Problems
myfirstvolvos40
post Oct 15 2011, 10:50 PM
Drives: 2002 Volvo S40
Hello, hoping someone will have some insight to this problem I'm having. I just bought a 2002 Volvo S40 t1.9, if it sits for a while (30 mins?), it takes 3-4 attempts before it will start but once it starts, I can turn it off and on numerous times and it starts like it should. What could be the problem here? Thanks for any advice or help I can get!
danielm85948
post Oct 16 2011, 02:53 AM
Expert Veteran
QUOTE (myfirstvolvos40 @ Oct 15 2011, 11:50 PM)
change your fuel pump relay,but get your codes first.
myfirstvolvos40
post Oct 16 2011, 11:20 AM
QUOTE (danielm85948 @ Oct 16 2011, 12:53 AM)
Thanks for your reply! Do you know where this relay is located?? I looked under the hood fuse box but it wasn't there. Also, I don't have any check engine light on or anything, will there still be codes to retrieve?
SeaMike
post Oct 16 2011, 11:02 PM
Senior Veteran
QUOTE (myfirstvolvos40 @ Oct 15 2011, 10:50 PM)
Please pull the codes before spending money.
Check vacuum lines.
When was the fuel filter changed last at?
myfirstvolvos40
post Oct 20 2011, 01:17 PM
QUOTE (SeaMike @ Oct 16 2011, 09:02 PM)
Check vacuum lines.
I just bought this car off someone who had it for 2/3 months. I don't have much history on it but he said he just used reg unleaded but I read that Premium is best for it so the tank was half full and I filled it up with Premium and now it starts on the first try =). Kind of weird, would just premium gas make a difference in starting???
SeaMike
post Oct 20 2011, 03:41 PM
Senior Veteran
QUOTE (myfirstvolvos40 @ Oct 20 2011, 01:17 PM)
No it should not.
Unless you have water/moisture in your gas tank. Run a bottle of the moisture remover, also change the fuel filter and PULL THE CODES.
Mike
Jaegar23
post Oct 22 2011, 04:10 AM
Drives: 2004 Volvo XC 90 T6 AWD
it can be anything from battery corrosion, dead battery, bad ignition switch, bad starter connection...!it is not always important the relays are some sort of glitch...!
get it checked if you are unable to find the prob,,....
myfirstvolvos40
post Oct 23 2011, 06:47 PM
Well, It started doing it again so it wasn't the gas. I'm not driving it at all hardly because I can't get it registered til January but I did go to Autozone and had the battery charged up and have the starter and alternator checked. It was all OK. I'm probably going to just have it checked out at a shop. Thanks for the input!
mcoles
post Oct 24 2011, 12:55 PM
Do you have access to an OBD2 diagnostic reader and when you turm the key to position 2, have you confirmed that all the lights come up. Maybe there is a fault and a previous owner removed the bulb so no one would know if there was a fault.
The OBD2 with the right software will also tell you how the engine is running.
Worth getting one from ebay cheaply, will help in the future should you run into further problems.
myfirstvolvos40
post Nov 9 2011, 01:11 AM
Went to AutoZone to pull codes and everything is clear so I decided to just order a Fuel Pressure Regulator online and replaced it because it seemed to be the solution to a lot of the hard start problems but it did not fix my problem but I did notice some vacuum lines that were not originals, if the some of the lines are longer than the original or the diameter is different, could it cause this problem?
danielm85948
post Nov 9 2011, 07:03 AM
Expert Veteran
QUOTE (myfirstvolvos40 @ Nov 9 2011, 01:11 AM)
yes it can .
No New Posts Problems After Drain Cleaning
Errors and door open chime
0 RosemaryB 458 2nd January 2016 - 05:41 PM
Last post by: RosemaryB
No New Posts Problems With Swm, Possibly?
No turn signal, no cruise control, no high beam.
8 murta 589 20th October 2015 - 02:16 AM
Last post by: murta
No New Posts Problems With A Volvo C70 Stuck In Park!?
1 bemshawn 681 21st August 2015 - 10:33 PM
No New Posts Starting Problems In Hot Weather S60 2001
4 manofsteel05 2,805 18th March 2015 - 08:15 PM
No New Posts Problems Starting 2006 Volvo After Changing Battery
1 geoloog 2,028 3rd December 2014 - 07:42 PM
Last post by: Vermont
Time is now: 28th February 2017 - 07:20 AM
