QUOTE (qsaghar @ Oct 10 2011, 02:25 PM)
<{POST_SNAPBACK}>
Have a very frustrating problem with a 96 850 sedan. The headlights and running lights stay on after the ignition is turned off and the light switch is on off. I thought it was a defective headlight relay and replaced it with an original part, but the problem continued. I tried unplugging the headlight switch, ignition switch, fog light relay and the blinker/flasher switch, but the headlights stayed on!!! Unplugging the main headlight relay turned off the headlights, but the running lights still stayed on. The only action that turns all the lights off is unhooking the batthery! HELP, I'm really stymied and frustrated!
Hey,
Welcome to the forum.
Well either you have a bunch of wire melted together, or the electrical portion of the ignition switch maybe/is gone bad. It controls a the electricity to in entire car.
How many miles on the car?
Do this test.... with the car running very very slowly turn the ignition key forward (do not turn to the point of engaging the starter), then very slowly to the back, do you see any lights on the dash coming on or off?
http://volvospeed.com/volvo_repairs_how_to...ion_switch.html
Also, check the connection to the starter to ensure there is no short across the starter solenoid.
