> Drive Shaft Noise?
srl123
post Oct 4 2011, 06:43 PM
Drives: 1994 volvo 960
I have a 1994 960 2.9 sedan. When first starting to move, there is a thumping noise and you can feel it under the seat. It stops as soon as you get to 15-20 mph. Just had the carrier bering replaced(whole assembly) and it didn't cure the noise. Now the mechanic says that the drive shaft must be bent/out of balance. Before going to the expense of another drive shaft, any suggestions? Thanks in advance.
danielm85948
post Oct 5 2011, 12:09 AM
Expert Veteran
QUOTE (srl123 @ Oct 4 2011, 06:43 PM)
worn UV joints check each of them ,more so at the rear of the shaft,if you can get under the car , safely,get hold of the shaft try to move it at each of the joints,the bearings in each of the caps may have worn out.
danr960
post Oct 5 2011, 08:02 AM
Drives: '94 964
Another thing that can cause this is a sagging rear suspension. Those expensive nivomat shocks prevent the rear from sagging. Drive shaft alignment to the differential is very important and any sagging of the springs will cause that rumble.
Also a worn tail shaft transmission mount can be the cause.
DanR '94 964 360,000 miles (126,000 on the new engine)
draser
post Oct 6 2011, 07:51 PM
Drives: 2005 S60
Can you tell if it's coming from the carrier bearing or from the front/rear wheels? Was it having the same noise before replacement? Can you actually take a look at what he did, and check drive shaft for bends, scratches, abuse?
No New Posts Drivers Side Mirror Replacement
3 moosehead 105 1st January 2017 - 04:26 PM
Last post by: grendel1960
No New Posts Driver Side Headlight
Poor design dangerous
4 mnwyld1 202 11th December 2016 - 06:53 PM
No New Posts Noise In Front Left Suspension
noise when damping
0 Omar-KW 201 3rd August 2016 - 02:11 PM
Last post by: Omar-KW
No New Posts Drivers Seat Memory
Memory is intermittent.
1 Roadcracks 101 31st July 2016 - 02:43 PM
No New Posts Noise And Vibration In Accelerator Pedal
1 Symas 225 24th May 2016 - 07:11 PM
Last post by: Platypup
Time is now: 20th February 2017 - 08:28 AM
