> 1990 740gl Keys In Ignition Warning Beep, THE BEEP WONT STOP
Dshourt
post Aug 9 2005, 08:04 PM
Drives: 1990 740 GL
Okay, So, I'm driving down the road, and my Volvo 740 GL starts beeping at me. No warning lights turn on, and im thoroughly confused. It's running fantastic with 250k miles on it. But now, the beep wont stop. I'm guessing its the Beep that comes on when you leave your keys in the ignition and open the door, perhaps one of the door sensors is broken. What's the easiest fix to STOP the beep?
-Dash Shourt
deadken
post Aug 9 2005, 09:01 PM
I am not sure if it is the same as the seat belt beeper, but look HERE for the location of the seat belt beeper. Take out the ashtray to access the fuse panel and then remove the cover around the cigarette lighter. Take out the two philips head screws and remove the storage bin. Now you should have clear access to the relay panel. See if one is beeping and remove it.
This is by no means a fix, but I couldn't not say anything and have that annoying the heck out of you. Good luck and let us know if that stops it.
The next step is to see what is causing the beeping in the first place and correct that.
Dshourt
post Aug 11 2005, 06:42 PM
Drives: 1990 740 GL
So, I took out the relay, afterward the car wouldnt start. I looked over the fuse box more thuroughly and found that the fuse controling the power antenna was blown. I replaced it, and it blew again, obviously a short circuit. I open all the access panels and inspected for bad wiring to anything on that fuse. I found none. I put another fuse in and watched for smoke from each access panel. and under the hood. I saw none. I realized I had 2 options, Pull out my voltometer, and inspect each circuit untill I found the loss in conectivity, Or I could do what I ended up doing: putting a 30a fuse in. And look for smoke. The 30 didnt blow as the circuit was of low amperage, and the wires began melting. It became apparent the short was in some wiring on the glove box, as blue smoke flooded into the car. I quickly disconected the battery and found the wire: our culprit, The Courtesy Mirror Lamp. The wiring was burnt out all the way from the joint where the shade swivles, to a connector behind the dash. I disconected it, replaced the fuse, and now, everything is great.
-Dash Shourt
deadken
post Aug 13 2005, 01:00 PM
:haha: I have heard of that method of 'tracing shorts', but I haven't used it myself :haha: .
I am glad that the you got it to stop chiming and nothing major was needed.
No New Posts Intercooler Pipes
7 rob_russ 37 Today, 07:40 AM
Last post by: rob_russ
No New Posts Ignition Switch
Help with changing my ignition switch
0 SeaMike 10 1st December 2008 - 04:57 PM
Last post by: SeaMike
No New Posts Independent Mechanic
0 Adam Morris 4 30th November 2008 - 12:26 PM
Last post by: Adam Morris
No New Posts Ignition Spinning Around! & Lgi.
0 Burgess kab 7 29th November 2008 - 06:57 PM
Last post by: Burgess kab
No New Posts Ignition Switch, Abs Light And Shift Lock Button
2 reneedalady 34 29th November 2008 - 12:20 PM
Last post by: Sparky4688
Time is now: 3rd December 2008 - 07:18 PM
