> Ignition Switch Problems
EVRose
post Aug 24 2011, 09:37 AM
Drives: '06 S40
Hello, new here.
I have an '06 S40 and it would not start. All power was on but no crank. I started to jiggle the key in the ignition while holding it in the start position and got it started. I'm thinking the ignition switch is worn. Is there a procedure available to replace it?
danielm85948
post Aug 24 2011, 12:11 PM
Expert Veteran
QUOTE (EVRose @ Aug 24 2011, 10:37 AM)
Hello, new here.
check the switch first,you will need a torch for this,remove the cover ,above your knee in the drivers footwell,on your back look up ,to see the ignition switch,or if switch under the steering wheel,remove the cover above it,you will see the plug with wiring to the switch,just pull it off,now you can see the electrical part of your ignition switch,held on by two screws,remove it,note how it is fitted,clean it with electrical cleaner,but before doing this check the screws are not loose,you may only need to tighten them,it is very rare for a switch to go ,at that age.
EVRose
post Aug 24 2011, 12:50 PM
Drives: '06 S40
Thank you sir! Will check that out.
Platypup
post Aug 24 2011, 11:04 PM
Drives: Volvo V50 T5 AWD, Toyota RAV4, MG TC, Jaguar E-type
EVRose, you seem to have developed a problem with the internal contacts in the ignition switch. Getting the engine to crank over by jiggling the key indicates the battery and starter are OK. The ignition switch on earlier (before 2007) S40/V50 Volvos was prone to giving trouble together with the steering lock mechanism as can be seen in the following links to other areas of the forum.
Because the ignition switch is on the dashboard with the steering lock disengaging electrically (when the ignition switch senses the transponder chip in the key as it is inserted) the mechanism is more complex than the older integrated ignition switch/steering lock on the steering column and hence more difficult and expensive to fix. It seems most likely only the switch will need replacing (others have had problems with the steering lock mechanism jamming and needing replacement also).
http://www.volvo-forums.com/index.php?show...ignition+switch
EVRose
post Sep 3 2011, 08:10 PM
Drives: '06 S40
QUOTE (Platypup @ Aug 24 2011, 11:04 PM)
Thanks for the links. Interesting stuff. I actually got an ignition switch from ebay and installed it myself. Everything is back to normal.
chart97
post Oct 23 2011, 11:22 AM
Drives: 2004+ S40
QUOTE (EVRose @ Sep 3 2011, 08:10 PM)
how'd you get your key fobs to work with the new ignition switch? specifically do you need special tools/equipment to get the key fobs in the ignition switch to recognize each other?
I have a 2004+ S40 With a key that is stuck in the ignition.
Curt
No New Posts Ignition Coil Leaking Oil
Causes of an OBDII Code P0303
9 Vermont 117 22nd March 2017 - 08:25 AM
Last post by: grendel1960
No New Posts Ignition Coil Part #s
trying to figure out what coils to get
0 jeff werner 343 7th March 2016 - 11:18 PM
Last post by: jeff werner
No New Posts Problems After Drain Cleaning
Errors and door open chime
0 RosemaryB 479 2nd January 2016 - 05:41 PM
Last post by: RosemaryB
Key will not turn
3 rlv 474 22nd December 2015 - 01:04 PM
Last post by: rlv
No New Posts Problems With Swm, Possibly?
No turn signal, no cruise control, no high beam.
8 murta 605 20th October 2015 - 02:16 AM
Last post by: murta
Time is now: 30th March 2017 - 05:47 AM
