> Help! Engine Just Shut-off While Driving Down The Highway- Not Timing Belt
sugardoo
post Jun 10 2011, 10:52 PM
Drives: 2004 S80
Man, I LOVE this car but so disappointed (and a little embarrassed) that it left me stranded on the side of the highway.
2004 2.9 with 90k.
I was just cruising down the highway and it just started hesitating and then completely lost power- I put it in neutral and coasted off the highway and now it sits on a side street. Right before I put it in neutral I tried to give it gas put the rpms just kept going lower and lower. Once in neutral, engine just died and coasted to a stop.
I popped open the hood- nothing unusual, no smells, nothing loose... I checked the fuel pump fuse-ok. Checked the battery connection- tight.
I let it rest for a few minutes and tried to start it up- cranked over and ran for about 1 second and suddenly died.
Here is all I know
1/2 tank of gas
engine temp was fine
no computer warning or check engine lights came on
not the timing belt as I would have heard a violent noise
I took the fuel filler cap loose and re-tightened it.
Batter is only 9 months old
fuel pump replaced by dealer 9 months ago under recall
One thing I should mention- I doubt it has anything to do with it, but my darn computer keeps saying bulb position failure and just for the hell of it i held down the reset button to see if it would go away- then the car died right after that- I'm sure its just coincidental but thought I'd mention it anyway in-case i somehow messed with the computer.
I lost my job and would like to ride my scooter to it with my tools and see if I can check/test/repair it.
Please let me know where to start at least.
Thanks!
sugardoo
post Jun 11 2011, 02:54 PM
Drives: 2004 S80
Update:
Well, I was going to do a fuel pressure check but decided to go over there on my scooter with a handful of tools first to see about doing simple things like disconnect/reconnect the battery. The first thing I did was to crank it over. It turned over normal speed and after a few seconds it wasn't starting, so I kept cranking it but now I mashed down on the accelerator and not only did it start but it kept going! It seemed to idle faster than normal for a bit then gradually went down to normal speed.
I took it for a slow test drive. It didn't idle funny and it drove fine. After the engine was at normal operating temp I gunned it a few times- no hesitation at all. Drove perfectly normal. What the ???
I'm happy I don't have to have it towed into a shop (where I feel I'm at shop's mercy) but now I obviously have an intermittent problem which are a PITA to diagnose. There are no display messages on the dash and all seems fine.
Now what should I do? take it somewhere to have it hooked up to a computer? I would think that there is a short or a sensor that is going out but not at all sure..
danielm85948
post Jun 11 2011, 08:12 PM
Expert Veteran
QUOTE (sugardoo @ Jun 11 2011, 03:54 PM)
Update:
change the bulb failure warning relay,it is breaking down,tripping the immobilizer,a round relay.
sugardoo
post Jun 12 2011, 07:23 PM
Drives: 2004 S80
Wow Daniel, good call- thanks!
Do you think this is because I stupidly was holding the reset button right before it stalled or do you think it would have occurred anyway as long as that light was on?
I tried to do a search to see where that relay is located but not sure yet- is it under the hood?
danielm85948
post Jun 12 2011, 08:44 PM
Expert Veteran
QUOTE (sugardoo @ Jun 12 2011, 08:23 PM)
as i drive the volvo 940 turbo,mine is behind the front ash tray,yours i think ,may be under the steering wheel,or side panel left or right,the positions keep changing,google bulb warning sensor,then click on relay locations,so it is a round relay,you are looking for,as for you holding the reset button would not help,but the fact your dash light is on shows the need to change it,the relay i mean.i take it you have checked ,all the bulbs are working,and more so ,your indicator bulbs,if the other lights are working,and not them,then your indicator relay is breaking down,fooling the bulb failure relay,and then tripping the mobilizer.so check all the bulbs are working first.and check the fuses.
sugardoo
post Jun 13 2011, 02:11 PM
Drives: 2004 S80
Update:
I wanted to go around to see if I could find that relay plus
I wanted to see if I could get the computer code read. Auto part stores said if the check engine didn't come on then there will be no codes to read. Later I noticed my turn signals stopped working, and the lights on the dash are very dim. The a/c blower is stilling fine, head lights fine (brights now not working). Now I'm thinking it might be something other than the relay.
Found a volvo shop near and took it over. They said first off, the alternator is only putting out 12.5 volts. They then said they would need to keep it and do more research to see if that doesn't solve the other problems what else could be the cause.
Stay tuned..
danielm85948
post Jun 13 2011, 03:59 PM
Expert Veteran
QUOTE (sugardoo @ Jun 13 2011, 03:11 PM)
Update:
Stay tuned..
if it is only giving out 12.5 volts,the bushes will be gone in the alternator.
sugardoo
post Jun 14 2011, 05:41 PM
Drives: 2004 S80
You still think it might be the alternator? The battery isn't being discharged plus wouldn't I get a check engine light?
summary of facts so far:
1. car has died twice now while going a steady speed.
2. when car stalls, it "shudders" briefly then engine cuts-off. No warning lights at all.
3. First time this happened car sat over-night then restarted and drove fine.
4. Later while driving several of the electrical features were not working but car could still drive.
5. mechanic did something behind fuse block and replaced fuses- car drove fine home then next day (today) same thing happened- stalled on highway at exactly the same location as before- weird!!
MAF problem or ETM malfunctioning?
My plan now is to take it to the dealer and just pay them a diagnostic fee to see what the problem is (I would like to request any stored codes on the computer) and hopefully fix myself- I'm unemployed
danielm85948
post Jun 14 2011, 06:14 PM
Expert Veteran
QUOTE (sugardoo @ Jun 14 2011, 06:41 PM)
when you get stalling,that points to fuel pump relay,but when you have only 12.5 volts,from the alternator,with radio on ,lights on,air con,all that is a drain in power,so at only 12.5 volts,it can drop to about 9.5 volts with every thing on,you can fool each of the relays,so i think change the bushes,for your alternator,you need power from there,bushes in this country cost 10,so in your country,i do not know,you get bushes from the people that do alternator rebuild.
sugardoo
post Jun 14 2011, 10:52 PM
Drives: 2004 S80
plot thickens...
Although the gas gauge reads over half tank I decided to take a couple gallons of fuel over to it. I crank it up- no dice. Pour in the fuel and sure enough- it starts!
So I don't know what to say about the previous electrical issues- maybe that mechanic did fix that part and it was just coincidental that happened at the same time as this apparent fuel delivery problem.
So now I guess the thing to do is measure the output from the alternator, then as you say it could be fuel pump relay. Maybe bad fuel filter?
I just had the fuel pump replaced as a recall by the dealer 3 months ago.
sugardoo
post Jun 16 2011, 06:31 PM
Drives: 2004 S80
Dealer diagnosis- "fuel tank level float stuck on a wire giving false reading"
So my gauge was saying half full but was on empty...
Not sure if this occurred because of the fuel pump recall service a few months back or not.
They didn't charge me for the diagnosis/service.
No New Posts The Volvo 240 Electrical Gremlins Have Put The Bite On Me
My 1990 240 dl Wagon Isn't Charging
2 Myhat50 83 9th April 2017 - 03:03 AM
Last post by: Myhat50
No New Posts The Car's Motor
The car's motor vehicle consists of a collection of mechanical par
0 mohamedsameer 28 31st March 2017 - 03:44 AM
Last post by: mohamedsameer
No New Posts Topic has attachmentsThe Black Friday Auto Parts Rock Bottom Price
1 Jimkansa 294 3rd February 2017 - 01:14 AM
Last post by: Stven
No New Posts Driving Lights
Help with wiring Driving Lights on 1989 240 DL
1 Surfechoes 188 4th January 2017 - 10:33 AM
Last post by: Flanne
1 namz 327 21st August 2016 - 03:09 AM
Time is now: 26th April 2017 - 04:51 AM
