> Repair Of The Volvo 940 Turbo 1991, repairing the turbo on a volvo 940 se turbo 91 ,do this for any turbo
danielm85948
post May 26 2011, 03:18 AM
Expert Veteran
to all of those having trouble with the turbo,so lots of white smoke ,out the rear of the car,so next step,get a turbo repair kit,cost in the uk,58 be sure to get a new oil return seal for the pipe ,going to the crankcase,be sure to check the hose is in the hole,push the seal down in the hole on the crankcase, when you refit,on my 940 se turbo i have a clamp in the centre ,with a 10mm nut,remove it,now the fun starts, soak the join there with WD 40,leave overnight to do the job,now you need a rubber mallet ,before you do this remove the rubber hoses from there first,now try to hit the top of the turbo ,to work it out,do not use metal to do this,now you have it off ,you must clean it,remove all the carbon build up ,found on the wheel,before taking the both wheels ,front and rear,you must mark both nut shaft and wheel ,both of them ,due to balance needed,now go on you tube to watch how you remove ,and fit each part,car needed ,do not damage ,those wheels,you need large large pair of cir-clip pliers ,with gap of about 2,to 3 inches and a 10mm spanner,for the front wheel ,and a 18 sided 13 mm spanner for the back one,now to see each part as you remove it,line up ,in a row, each part as it comes off,now line up the new parts above that,clean the body of the turbo with cleaner,now you are ready to rebuild,i take it you have a copy showing each part,goes in,and you have seen and understand the you tube film on there,i did the repair in 4 hours,just taken my time doing so,you must note the pin holding the shaft from the actuator on the part of the turbo that stays on ,must be removed you have to do that first,before removing the turbo,and you must coat each part with engine oil as you replace,so you do not need a new turbo ,just get the kit and repair it,but when doing all this work change the turbo bypass valve , it will have pin holes in the diaphragm.or spilts,so replace it, cost in the UK, 7 cost of the seal ,for return pipe seal to the crankcase from volvo 4.so total cost to repair 69.
MattCS
post Sep 29 2011, 09:38 AM
Drives: 760 & 960 & S90
QUOTE (danielm85948 @ May 26 2011, 09:18 AM)
to all of those having trouble with the turbo,so lots of white smoke ,out the rear of the car,so next step,get a turbo repair kit,cost in the uk,�58 be sure to get a new oil return seal for the pipe ,going to the crankcase,be sure to check the hose is in the hole,push the seal down in the hole on the crankcase, when you refit,on my 940 se turbo i have a clamp in the centre ,with a 10mm nut,remove it,now the fun starts, soak the join there with WD 40,leave overnight to do the job,now you need a rubber mallet ,before you do this remove the rubber hoses from there first,now try to hit the top of the turbo ,to work it out,do not use metal to do this,now you have it off ,you must clean it,remove all the carbon build up ,found on the wheel,before taking the both wheels ,front and rear,you must mark both nut shaft and wheel ,both of them ,due to balance needed,now go on you tube to watch how you remove ,and fit each part,car needed ,do not damage ,those wheels,you need large large pair of cir-clip pliers ,with gap of about 2,to 3 inches and a 10mm spanner,for the front wheel ,and a 18 sided 13 mm spanner for the back one,now to see each part as you remove it,line up ,in a row, each part as it comes off,now line up the new parts above that,clean the body of the turbo with cleaner,now you are ready to rebuild,i take it you have a copy showing each part,goes in,and you have seen and understand the you tube film on there,i did the repair in 4 hours,just taken my time doing so,you must note the pin holding the shaft from the actuator on the part of the turbo that stays on ,must be removed you have to do that first,before removing the turbo,and you must coat each part with engine oil as you replace,so you do not need a new turbo ,just get the kit and repair it,but when doing all this work change the turbo bypass valve , it will have pin holes in the diaphragm.or spilts,so replace it, cost in the UK, �7 cost of the seal ,for return pipe seal to the crankcase from volvo �4.so total cost to repair �69.
Hi danielm85948,
Also use only fully synthetic oil in the engine if you value your turbo, as mineral-based engine oil can glue up the bearings in the turbo, especially after having switched off the engine when the engine was hot, such after a fast motorway journey.
Good luck
danielm85948
post Sep 29 2011, 02:22 PM
Expert Veteran
QUOTE (MattCS @ Sep 29 2011, 10:38 AM)
Hi danielm85948,
Good luck
I do use only synthetic oil,not mineral based as you say ,do not use cheap oil,and due to being a turbo,it runs very hot,so I like to check the oil and water every day,and on a long trip,check the oil and water,after 250 miles, I travelled,down to Bristol from Glasgow, I found I had to add oil,being one Lt of oil,after doing 70 mph none stop for 6hours,till 45 miles from Bristol, I had to add 1 Lt of oil,and you should change the cap on the expansion bottle , I put in £70 in petrol ,full tank,so I had used £35 of petrol being half a tank,she run like a new car,that is what a repair kit for your turbo can do for you.
No New Posts Volvo 240 Transmission Knocking Noise
2 Cuffman 68 15th January 2017 - 02:20 PM
Last post by: Cuffman
No New Posts Volvo V40 Isofix Anchors
2 starman1970 688 31st December 2016 - 07:53 AM
Last post by: Olaf V40
No New Posts Volvo Truck Fault Codes List
0 igor2009 50 21st December 2016 - 04:43 AM
Last post by: igor2009
No New Posts Volvo Car Fault Codes List
0 igor2009 111 21st December 2016 - 04:39 AM
No New Posts Volvo Gps System
seems really out dated
2 bobnphred 173 14th December 2016 - 04:31 PM
Last post by: ericy
Time is now: 19th January 2017 - 10:49 PM
