> Bad Oil Leak From Cap, Oil Leak 940 Turbo
Dave Dyer
post May 10 2011, 07:07 PM
Drives: 1988 245 B230FT M90
Replaced the breather box and o-ring due to oil leaking from box. Now have very bad leak from cap even though the cap seal was also replaced. Any ideas?
ed7
post May 10 2011, 09:44 PM
Drives: 2001 V70 2.4T
Check all your vacuum lines, flame trap, and the entire PCV system.
Ed
danielm85948
post May 10 2011, 10:36 PM
Expert Veteran
QUOTE (Dave Dyer @ May 10 2011, 08:07 PM)
you must remove the small rubber hose,from the back of the inlet manifold first,now remove the black rubber hose from the top of your breather box, over the top of your engine it goes over the camshaft cover,just pull this up to remove ,clean all of those hoses ,they will be blocked with carbon.
Dave Dyer
post May 15 2011, 09:48 AM
QUOTE (danielm85948 @ May 10 2011, 11:36 PM)
Did that after spotting the new leak. Any other ideas?
ed7
post May 15 2011, 11:34 AM
Make sure the nipple at the intake manifold is clear. If you sense pressure at the hose at the manifold, the system is not clear at that point, otherwise track the pressure back to its source.
... rather the system is clear to that point and there's no vacuum at the manifold tap.
If there is no pressure, work forward.
Ed
danielm85948
post May 16 2011, 05:19 PM
Expert Veteran
check the oil level ,take it you have not over filled it.
Dave Dyer
post May 20 2011, 06:59 PM
QUOTE (danielm85948 @ May 16 2011, 06:19 PM)
Checked that first......Pulease....anyone have the solution for this? I'm hearing it could be rings:(
danielm85948
post May 20 2011, 07:48 PM
Expert Veteran
QUOTE (Dave Dyer @ May 20 2011, 07:59 PM)
use an engine oil flush, to clean oil ways,drain and refill and change oil filter,what colour is your oil,is there smell of burning,take off the oil cap,look in,can you see black carbon on your cams in the cam cover,the flush will remove that,you may have blocked oil ways and dirty filter on the oil pump,so oil flush will remove that.
No New Posts Oil Loss From Radiator Replacement
3 idainc 38 8th February 2017 - 09:30 AM
No New Posts Oil Loss Mystery Volvo?
1 qingqin 257 7th September 2016 - 09:57 PM
Last post by: highvoltj
No New Posts Topic has attachmentsBad Ignition Switch Or Other Wiring?
4 MaineErik 139 7th September 2016 - 12:14 PM
Last post by: MaineErik
No New Posts Topic has attachmentsOil Leak
Where is it coming from?
0 Alex89 262 18th June 2016 - 04:28 PM
Last post by: Alex89
No New Posts Oil Pan Hanging - What Do I Need To Fix It?
5 Alisa 285 2nd May 2016 - 09:18 PM
Last post by: Platypup
Time is now: 26th February 2017 - 09:34 AM
