> C70 Oil Leak Need Help, its somthing plugged or is the engine shot?
MnC70Guy
post Apr 6 2011, 03:34 PM
Drives: 1999 Volvo C70 LT A CV 2dr Conv Auto
just got a 1999 c70 b5254t has a oil leak, brought to mechanic, said oik was blowing out of oil cap? read on for about oil trap, had him replace it along with 2 smaller hoses with it. he said it didnt look plugged, still leaded oil. read aout oil cap seal going bad , got new oil cap still leads, oil on top of manafold. thought it somthing was plugged? any ideas? oil appears to drop down on the passenger side of engine compartment. didnt replace the long hose in the front its around 200.00. mechnic didnt thing it was valve cover gasket. had electronic trodle modle cleaned and car runs great but has oil leak/blow by
MKC70
post Apr 6 2011, 04:30 PM
Drives: 1999 Volvo C70 coupe
QUOTE (MnC70Guy @ Apr 6 2011, 04:34 PM)
Always a possibility, though you need to clean oil off and see for certain where it is coming from.
http://www.ipdusa.com/Volvo-850/Engine/Eng...72-153-168-664/
Sar_Guy65
post Sep 19 2012, 06:58 PM
Drives: 1998 Volvo C70
Ran across same problem with my 98 C70 w/ 2.3. Found oil blowing out factory hole in head/ cover just to the right of PCV breather ( black rubber pipe ), I made a cover plate and gasket, ultra black silicones it down and no more leak. Have pictures if needed, can e-mail them. Hope it helps.
Will
danielm85948
post Sep 19 2012, 08:21 PM
Expert Veteran
sounds like your oil trap is blocked, it is a small black plastic box bolted on to the head that is part of your breather system try remove and clean.
V0LV0Steve
post Sep 21 2012, 07:58 PM
Drives: 2001 Volvo C70 HPT
QUOTE (Sar_Guy65 @ Sep 19 2012, 06:58 PM)
Will
I think that i have the same problem! I replaced the entire PCV system with the iPd PCV kit, and replaced the oil cap/seal but i still am dropping about a nickel sized drop in my driveway every day. It would really help to get those pictures. Main seal and cam seal are not leaking from what i can tell.
CPUNeck
post Nov 13 2012, 07:41 AM
Drives: 1999 C90
QUOTE (V0LV0Steve @ Sep 21 2012, 08:58 PM)
Well I'm new to this model (C70), had a 850 years ago... I have an oil leak similar to that described here. The PCV system was recently replaced, and the oil fill cap appears to have a servicable seal. To the OP, are you sure it's engine oil. I believe I have a leak in the power steering system (hose is swollen, w/oil weep on resivoir and lines). This could be getting "slung" around the engine by the fan belt, and blown toward the rear by air coming from the front grill. That's why it's imperitive to clean well for diagnosis.
Note, if you open the oil fill cap, there should be no "pressure" escaping... you'll have some oil spray from the rotating assemblies, but not pressure. If there's pressure when you remove the cap, there is a failure in the PCV system wheather it's just been replaced or not.
No New Posts Need Help! 2004 S40 T4 Weird Issues
2 Gadgeteer 40 13th April 2017 - 06:01 PM
Last post by: Gadgeteer
No New Posts Oil Loss From Radiator Replacement
3 idainc 92 8th February 2017 - 09:30 AM
No New Posts Help! Key Fob Stuck In Ignition
0 mathyou 179 30th December 2016 - 06:34 PM
Last post by: mathyou
No New Posts C70 Transmission
Transmission not going into Manual mode
0 toothpick 218 12th December 2016 - 09:52 AM
Last post by: toothpick
No New Posts Oil Loss Mystery Volvo?
1 qingqin 339 7th September 2016 - 09:57 PM
Last post by: highvoltj
Time is now: 26th April 2017 - 04:45 AM
