> '97 940 Cd Lpt Fuel Consumption And Idle Troubles
robinjhorn
post Feb 13 2011, 09:43 AM
Drives: 1997 940 CD
Hi there,
I've got a 1997 Volvo 940 CD LPT 2.3 petrol(as far as i can tell making it a B230FK lump) and have got some serious fuel consumption woes. I bought the car in Newcastle and made it back to Edinburgh on £30 fuel which is pretty much exactly what i expected.
The cars done 196,000 miles with a dealer service history up to 100,000 and 80,000 gap in service history from there onwards. The previous owner had fitted a new lambda sensor and a second hand MAF (assured it was a good one) within the year before me buying the car and also replaced all the ancilliary belts. The Lambda light was on but as he had said this is a common problem as the ECU is often not disconnected long enough to wipe the fault codes.
So when i got back to Edinburgh i was having a good look at the engine as it had begun to idle erraticly (spluttery and stalling or up at 1500-2000rpm) not long after buying it. The exhaust was only held on to the Turbo by one bolt and was gaping open..(!) tightened that up got plenty crappy black smoke out of the exhaust, filled the tank and put some injector cleaner in with it. fitted new air filter as old one was filthy, one of the HT leads was loose on the plug so got a new set of those too.
Still idling badly so checked this forum, saw that throttle assembly gets clogged up and struggles to breathe on idle so i took that apart and sure enough cleaned out the filth from assembly.
I noticed at this point that the intake hoses were coated in oil but didnt know if this was the normal amount for the mileage. Adjusted the throttle position switch properly, tweaked the idle adjustment screw right back and this surely made things better but still idling at 900 (at cold start only) or usually 1200-1500rpm.
Turbo was very oily on outside so just took all the hoses off to clean out today and the inside of the turbo is very oily. cleaned up as best i could with turbo still in place, cleaned out the air idle control valve too and took it out for a run. felt a little better but when i got back and re- checked the turbo (after it had cooled) the inside was already quite oily and the what looks like the water inlet thingy was leaking oil from the side.
According to the haynes manual, when adjusting the idle, clamping the idle air control feed pipe to restrict it should take the idle from 750 to 500rpm and you should THEN tweak the idle adjust screw until its at a steady 500. Crucially, before cleaning out the hoses and turbo doing this didnt affect the idle at all but did (however only momentarily) afterwards.
I've recently changed the MAF and Lambda sensors for new units which got rid of the lambda light and i'd fitted new ht leads and air filter put an injector flush through it when id discovered the loose exhaust.
I drove to aberdeen at xmas Same distance as Newcastle-Edinburgh and it cost me £45 when i was really driving economically. By my calculations i'm getting about 13mpg which is making me very very poor and sad.
It looks like im going to have to rebuild the turbo (that or sell it) which is going to cost at least £80 but i think the intercooler, inlet manifold and all associated hoses will need a good clean out (hopefully the exhaust isn't in need of a flush too...)
I bought this car for £500 have already spent bout £250 (what i'd expected i'd need to spend) and at this point am unsure whether i want to tackle the turbo problem or just get shot of it. I cant afford to really spend the time on it and not get the fuel economy closer to 20mpg as im using this car for work. Does anyone have any experience of Turbo overhauls, flushing out intercoolers (i have no idea about this) and the effect on fuel economy this may have?
Bit of an epic there but i figured the more info the better.
On a side note my fuel gauge is running back to front (with a new sender unit) and only covering a third of the tanks capacity. Any ideas on that one?
Still love this car and dont want to let it go...
Robin.
danielm85948
post Feb 13 2011, 09:58 AM
Senior Veteran
QUOTE (robinjhorn @ Feb 13 2011, 10:43 AM)
Hi there,
Robin.
it cost me £55 to get the kit to rebuild my turbo,about 4 hours work.i got my kit from turbo place in blackpool.
robinjhorn
post Feb 14 2011, 07:42 AM
Drives: 1997 940 CD
Hi daniel,
thanks for the reply ive gotten a quote of £59.00 and free postage online which i think i may have to try.
I reckon im also gonna have to clean out the inlet manifold which im not sure if it will need a new gasket or if i could get away with being careful...
Couple of questions for you tho:
Did you have to flush out the intercooler (or exhaust?) and if so how did you do it?
Also what kind of milage were you getting before and after the rebuild or did you notice a marked improvement.
I need about at least a 2/3rds improvement on mpg ( from 13 to hopefully nearer 20) for this to be worth my while. Obviously this is dependant on the individual car and so on...
eternalstudent
post Feb 14 2011, 11:35 AM
Drives: 960 - 3.0i 24V 1991
QUOTE (robinjhorn @ Feb 14 2011, 08:42 AM)
Hi daniel,
Yes you will need to flush out the intercooler, if the turbo has been pushing oil out you will find a lot of it in their. It is not a hard job. I used a light spirit to clean it all out. You will be amazed at the amount of oil they can collect.
I have a turbo refurb kit that I never put on my 940 (not only the turbo had been screwed but so had the piston seals so I gave up on it) if you want to buy it (I ain't looking for much but and it would be nice to have it used) send me a PM.
As for mpg, mine did 26 mpg on the run between newcastle and dundee on a regular basis driving at sensible speeds. If I went the whole way at 60 (very hard) I could get about 28. Around town it was more like 18 - 22.
hope this is
danielm85948
post Feb 14 2011, 12:28 PM
Senior Veteran
Hi daniel,
you need to flush out the inter-cooler,remove the two hoses,remove the two brackets,on the top,of it ,push the radiator back,and lift out the inter cooler,flush with power wash cleaner,let it sit,for an hour ,then shake it about ,let the cleaner do the work,as for MPG i get about 28 ,but car is faster,and runs better,it runs like a new car,put a fuel cleaner in the tank,clean your hoses with calb cleaner and the air flow meter,or the dirt will make it stick,when you take off the hose for the inlet manifold,clean there with calb cleaner,and check the turbo boast diaphagm for holes and replace cost £7 from same place as turbo repair kit,replace the seal,on the oil return pipe ,you must push the seal in to the crankcase while it is fitted to the return pipe,and check and clean your spark plugs,go on google for view of turbo repair,it will help you do the work.cost of the seal is £4.50 must get it from volvo dealer only part.you will not need to take off the inlet manifold,the tank cleaner will do that,watch when you remove the turbo,this is why i say go on google to see what you need to do,message me if you need more information on removing the turbo.
No New Posts Fuel Filter Removal Tool
Removing line from filter towards engine
0 Richie2248 99 28th April 2013 - 09:12 PM
Last post by: Richie2248
No New Posts 940 Gl Performance
getting more umph from 940 GL
1 cossy 215 17th April 2013 - 03:04 AM
Last post by: johnny5212
No New Posts Topic has attachmentsIdle
idle rises and falls at the wrong times?
11 Reevo 358 17th April 2013 - 01:56 AM
Last post by: Reevo
No New Posts 940 Non-turbo Late Gear Change When Cold
0 Albert Neil 132 14th April 2013 - 06:06 PM
Last post by: Albert Neil
No New Posts Fuel Pump Whine
6 tjwebb24 179 3rd April 2013 - 11:27 AM
Last post by: dolindo
Time is now: 23rd May 2013 - 08:58 AM
