> Abs Light On And Off - Can't Figure Out Why
bobthebuilder
post Feb 12 2011, 10:40 PM
Drives: 95 Volvo 850 GLT
I have a 1997 Volvo 850 non-turbo that I just bought from a friend. Car is in great shape with less than 100K on it. The ABS light was on when I got it, and the friend had been driving it that way for a while. Two days after taking delivery, the speedo and odometer went out. I ordered a rebuilt ABS from Matt. That fixed the speedo and the odometer, and for about 30 minutes, the ABS light stayed off after initial start up. But now, while the ABS light goes off after start up, if you press the throttle aggressively, the light comes on and stays on until the next restart. If you are real easy on the throttle it will mostly stay off. I swapped the front sensors with a donor 1995 850GLT that I know had good sensors - made no difference. I have not yet swapped the rear sensors.
I happened to notice that the 1997 has 205/60R15 tires, which is one size larger than what's on the sticker on the gas flap. Would that cause the ABS to come on? I'm thinking it wouldn't affect the ABS if all 4 tires are the same size, which they are. I hate to change tires as the car has brand new Kumho's on it. I could as a test swap the rims and tires off the 1995 donor (195/60R15), but don't want to do that unless it is a likely cause of my ABS problem.
Any thoughts on where I should go next?
Thanks for your feedback.
SeaMike
post Feb 12 2011, 11:05 PM
Senior Veteran
QUOTE (bobthebuilder @ Feb 12 2011, 09:40 PM)
So you need to pull the codes.
No, swapping the tires will not cause the ABS light to come on if you swap them.
Tell me what you mean by "aggressively" Are you doing BURN out? Smoking the front tires?
If so, then yes the abs light will come on.
If the front tires are moving, and the back tires are NOT them it triggers the ABS that something is acting up...because the computer can't figure out why the back tires are NOT moving.
bobthebuilder
post Feb 12 2011, 11:12 PM
QUOTE (SeaMike @ Feb 13 2011, 12:05 AM)
The check engine light is not on and my OBDII scanner says no codes. No, I'm not doing a burn out! I'm pressing the accelerator may half way or so, going in a straight line on dry pavement. No wheel spin. Similar to what you'd do on a freeway entrance ramp. It didn't take much for the ABS light to come on.
SeaMike
post Feb 12 2011, 11:41 PM
Senior Veteran
QUOTE (bobthebuilder @ Feb 12 2011, 10:12 PM)
Okay,
That is weird, no codes show up. Does your scanner pull OBD II codes?
Check the connector for the speedometer....if it is acting up....that may confuse the computer. See PFD for Vehicle Speed Sensor.
Take the sensor out, clean it, look at it for any damage signs, heck you may even want to check the Ohm's on it.... it may be off enough to mess with the ABS, but not off enough to throw a code.
Attached File  AutoTransDiagnosis_1995_850.pdf ( 306.5K ) Number of downloads: 46
bobthebuilder
post Feb 13 2011, 09:30 PM
QUOTE (SeaMike @ Feb 12 2011, 11:41 PM)
Okay,
I have an Actron ODBII scanner than does pull those codes. I noticed today that the check engine light does not come on momentarily when you first turn the key. All the other lights come on. It is probably just a burned out bulb, but I wonder, since it's odd that no codes show, could something else prevent the check engine light and code capture to not work?
The connector for the speedometer - are you referring to the vehicle speed sensor? I did take it out, clean and inspect it, and reinstall, checking the connection. I did this several days ago, so the ohms were not checked. I can go back and do this if needed. The speedo seems to be working as it should.
SeaMike
post Feb 13 2011, 10:35 PM
Senior Veteran
QUOTE (bobthebuilder @ Feb 13 2011, 08:30 PM)
Hey, I would change all the bulbs in the dash.
I have a Actron OBD II scanner myself.
Not all things throw codes....and something must mess up very frequent for a code to be thrown.
I would still check the Ohm's on all those items. Better to be safe...than to spend months looking for something that can drive you crazy.
grendel1960
post Feb 15 2011, 06:14 PM
Drives: 2000 volvo v70
I had a problem with my ABS light coming on after 15mins driving, replaced the front sensors, ok on the test drive next drive light on again, eventually tried something I read somewhere, two thicknesses of corrugated card between the abs pump housing and the connector - lights off and not appeared again since.
Grendel
bobthebuilder
post Feb 15 2011, 09:25 PM
QUOTE (grendel1960 @ Feb 15 2011, 06:14 PM)
Grendel
I'm game to try it, but I'm not quite sure where the cardboard goes. Is it between the ABS controller and bottom of the brake unit where all the little piston things are?
grendel1960
post Feb 16 2011, 02:22 PM
No, its to the side where the connector firts, it just wedges between the pump housing and the connector, if it takes longer than 5 seconds to fit its in the wrong place- if you hang on I will try and get a photo.
Grendel
grendel1960
post Feb 16 2011, 02:37 PM
here you go
bobthebuilder
post Feb 24 2011, 10:14 PM
QUOTE (grendel1960 @ Feb 16 2011, 02:37 PM)
here you go
Okay, now it makes sense. Strange, but the light no longer comes on, so for now I am assuming it is fixed. Gonna take it out one rainy day and slam the brakes on to make sure the ABS is in fact working.
srlockyer
post Jul 4 2011, 06:41 PM
Drives: 1998 Volvo S70 T5
QUOTE (grendel1960 @ Feb 16 2011, 03:22 PM)
Grendel
I have had this ABS light on for almost 5 years, I tried the fix and now the light is off and the ABS is working! Thanks for saving me $600!
RedDevil850R97
post Jul 13 2011, 05:05 PM
Drives: Volvo 850 R 1997
Grendel
Mr.
I'm really grateful for your advice, I directed and led at least two days with the ABS well (IMG:style_emoticons/default/57.gif)
(IMG:style_emoticons/default/haha.gif) thank you very much (IMG:style_emoticons/default/haha.gif)
Greetings from Chile (IMG:style_emoticons/default/grin.gif)
SeaMike
post Jul 13 2011, 06:36 PM
Senior Veteran
QUOTE (RedDevil850R97 @ Jul 13 2011, 05:05 PM)
Mr.
Hey Chile,
Did you pull the codes yet? If so, what code came up?
Look at this guy... in case your ABS is the issue.
http://home.earthlink.net/~vicrocha/Volvo_...atIsTheShipping
No New Posts Pinned: Topic has attachmentsOn-board Diagnostics 2 (obd Ii)
Learn about it...
23 ampangbear 60,135 14th April 2017 - 06:50 AM
Last post by: roundbout
0 HRPOWER 325 19th October 2016 - 06:22 PM
Last post by: HRPOWER
No New Posts Abs And Tracs Light On
1996 volvo 850 t
6 Drunkenrich 2,825 23rd May 2016 - 06:34 AM
Last post by: Shim Stock Metals
No New Posts Why Did Ford Motor Company Buy Volvo?
Why did Ford Motor company buy Volvo?
2 qingqin 1,178 27th March 2016 - 03:33 PM
No New Posts Off Side Parking (emergency) Brake Not Working
2 andyh69 303 19th March 2016 - 02:36 PM
Last post by: andyh69
Time is now: 24th April 2017 - 10:09 AM
