> Howto: Reset Service Reminder Indicator
Shoyuuuu
post Jan 16 2011, 02:19 PM
Drives: 2010 Volvo XC 60 T6 AWD
2008-2010 Volvos with starter push button on dashboard
* The trip odometer must have at least 0.1 mile on it or the light will not reset.
* Get in vehicle and do not push down on the brake pedal
* Put the key in the slot and push the starter button once
* Press and hold down the odometer reset button
* While doing this, push the starter button again and hold for 2 seconds
* Keep the odometer reset button held in and watch the instrument cluster for the general warning indicator (I) to illuminate. When this happens, release the button.
* Turn the vehicle off then back on and verify the message is now out.
2002-2007 All Volvo Models
* The service reminder indicator lamp illuminates for 120 seconds when the ignition is first switched on
* Insert key and turn Ignition Switch to position I
* Press and hold in the reset button for the trip odometer
* Turn the Ignition switch to position II (within 2 seconds)
* Hold the reset button for the trip meter pressed in until the original trip counter value blinks and is redisplayed
(For all vehicles 2003- a general yellow lamp will light when the reset button must be released.)
* Release the reset button for the trip odometer within 4 seconds. The instrument gives an audible signal when resetting has succeeded
* If the trip meter is already reset the reset button should be held in for a minimum of 10 seconds and a maximum of 14 seconds.
* If the reset button for the trip odometer is not released within 4 seconds, the service reminder indicator (SRI) is not reset.
2001 Volvo S80 / V70 / S60 Models (May apply to S40/V40 also)
* The service reminder indicator lamp illuminates for 120 seconds when the ignition is first switched on.
* Turn the Ignition switch to position II (within 5 seconds)
* The service reminder indicator starts flashing when the reset button for the trip odometer has been pressed for 10 seconds
* Release the reset button for the trip odometer within 5 seconds. The instrument gives an audible signal when resetting has succeeded.
* If the trip meter reset button is not released within 5 seconds the indicator is not reset, but the indicator will stop flashing.
1999-2000 Volvo S70 / V70 / C70 Models
* Insert key in to ignition but don't turn it yet
* Press and Hold the odometer trip counter reset button
* Turn ignition switch to "run" position (Position II)
* After Service light flashes, release odometer reset button
* Turn ignition off
* Turn ignition back on to confirm reset
1999-2000 Volvo S80 Models
* Insert key and turn ignition switch to position I
* Press and hold odometer trip counter reset button
* Turn ignition switch to position II
* Continue holding odometer trip counter reset button for about 10 seconds
* Should hear "beep-beep" to confirm command accepted
Some 1998 and older models require a OBDII service light reset tool. You can probably have it reset for a marginal cost by a local Volvo dealership or Volvo specialty shop that has one of these tools.
1998 Volvo S80 Models
* Press and hold the odometer reset button
* Turn ignition off
I hope this helps. Your comments are welcomed.
(IMG:style_emoticons/default/grin.gif)
« Next Oldest Volvo XC60 Forum Next Newest »
No New Posts Reset Car So It Will Start
passenger side air bag curtain deployed
0 docwho4 268 8th June 2016 - 03:59 PM
Last post by: docwho4
No New Posts Reset Maintenance Light 2015.5
2 metropical 537 21st March 2016 - 07:47 AM
Last post by: metropical
No new Pinned: Reseting the Service required message.
59 brianf 157,052 14th September 2015 - 12:53 PM
Last post by: Phixion
No New Posts Howto Install Grom Into Volvo S40 2005-2012
step by step install video
0 GROM Audio 735 27th April 2015 - 12:06 PM
Last post by: GROM Audio
No New Posts Howto: Install Subwoofer And Fm Modulator In S40
8 DaveSA 22,880 22nd March 2015 - 03:25 PM
Last post by: DaveSA
Time is now: 27th May 2017 - 12:21 PM
