> Volvo 740 Overdrive Issue
jmd
post Dec 6 2010, 10:08 AM
Drives: volvo 740
I just had my solenoid changed and I changed the OD relay and my car still doesn't shift into 4th gear. Could the garage have put the solenoid on backwards? my switch on the shifter was replaced with a toggle switch from autozone. My volvo has 230K miles and it is a 1990. Any help??? Thanks
jmd
post Dec 8 2010, 09:14 AM
Drives: volvo 740
I brought my car back to the garage and told them the overdrive was still not working even with new relay and solenoid. They looked at it again and said the new solenoid they put on was faulty/leaking. They ordered a new one and will install tomorrow. The only thing that stinks is the old solenoid was put on again because the new one broke, works fine now. hmmm. I wish I knew about the Overdrive bypass kit before a purchased a new solenoid for $185.
Jose D
post Jun 6 2011, 09:41 PM
Drives: 1991 Volvo 740 Non-turbo
I have the same problem on mines, its a 1991 740 non-turbo, 1st, 2nd, 3rd shift fine, but to get to 4th, I have to go over 60 miles in order for the transmission to shift to 4th.
danielm85948
post Jun 6 2011, 10:19 PM
Expert Veteran
QUOTE (jmd @ Dec 6 2010, 11:08 AM)
check the linkage and kick down cable at the throttle ,the cable may be loose or tight.
Maxy
post Jun 15 2011, 01:37 AM
Drives: Volvo V40
When the overdrive functioned properly, how often did you unlock and off overdrive? If the answer is very rare, so just skip completely electric and do it yourself ... in a few hours, you'll never have to worry again.
HenrikB
post Sep 9 2011, 09:29 PM
Drives: 1989 740 GLE, 1990 240 DL
I had the same issue a few years ago. If you don't care whether you have the overdrive option, the simplest solution is to buy a smal plate and cap it off the port where the solenoid normally goes. Your 4th gear will work but you don't have the option to switch it of. The plates are sold at IPDUSA.COM. About $20. I never had the problem after I did it.
GalaxyHorse
post Sep 17 2011, 10:21 PM
Drives: 1989 16v 740GLE Volvo
QUOTE (jmd @ Dec 6 2010, 11:08 PM)
Greetings , i had a persistent issue with my 740 GLE overdrive relay, the warning light would come on
erratically and i would not have a 4th gear; the mechanics fitted a second-hand one for $60, but the problem came back
a few weeks later. I removed the relay from behind the ashtray area and got my soldering Iron on to it, just re-soldered the points and have not had a problem since then about 12 months ago.
redcowboysox14
post Sep 20 2011, 01:04 PM
Drives: 1989 740 GL
yup ipdusa sells the bypass plate 4 $40.i put it on few months ago n no problems since.
savmedoc
post Oct 2 2011, 03:38 PM
Drives: 1990 Volvo 740 GL non turbo
QUOTE (HenrikB @ Sep 9 2011, 09:29 PM)
savmedoc
post Oct 2 2011, 03:55 PM
I had the same problem on my '90 740GL. I got the OD solenoid bypass plate from IPDUSA.com, and the car shifts fine now.
mummywagon
post Oct 29 2011, 11:20 AM
Drives: 1988 740 GLE Wagon
add 1 more to having success with Overdrive Relay replacement. $15 free shipping from ebay and now I have 4th gear!
It does seem I need to let off the gas for a sec every time I want the car to shift up, especially between 2nd and 3rd,is that normal for and 88 with 150,000?
rickspringfield
post Nov 28 2011, 02:01 PM
Drives: 1992 Volvo 740 Turbo Wagon
QUOTE (mummywagon @ Oct 29 2011, 12:20 PM)
Have someone check the "detent" cable- it may be out of adjustment. It is supposed to "catch" just before "wide open throttle". If it catches too early it can keep your car from upshifting as you've described.
neworleand
post Dec 19 2011, 01:50 PM
Drives: 2000 Volvo S80 T6
Hello mates,
When you had this shifting problem from 3rd to 4th gear, did you have the overdrive arrow light on?
I have the same problem but the light isn't on, but it comes on when i press the button.
After reading your messages here i ordered that plate from IPD but now not sure if that is the problem I have...
any advice?
thanks..
DotCarroll
post Jan 22 2012, 02:16 PM
Drives: 1993 Volvo 940 Sedan
QUOTE (neworleand @ Dec 19 2011, 01:50 PM)
Hello mates,
any advice?
thanks..
I have the same issue as described by neworleand, but with a 93 940. My overdrive light functions properly when pushing the button on the shifter (the OD light turns on / off when pushing the button). I can hear the relay click behind the dash, but no 4th gear when the OD is not engaged (OD arrow light off).
Had the Volvo shop replace the solenoid, adjust kick-down cable, etc. - still no 4th gear. I too ordered a bypass kit from ipd this weekend - hoping that will work as I'm thinking it's an electrical problem between the relay and the solenoidn as I believe the solenoid needs to be charged to actuate 4th gear, and in the default state is uncharged?
Any advice?
Diesel85
post Jul 11 2012, 07:09 AM
Drives: 85 Diesel 740 GLE
QUOTE (DotCarroll @ Jan 22 2012, 03:16 PM)
Any advice?
What do you mean by the solenoid needs to be charged? On my car the overdrive does not work until about 10 or 15 minutes of the car running. until that 15 minutes passed the over drive relay does not click and the light does not come on.
danielm85948
post Jul 11 2012, 09:39 AM
Expert Veteran
QUOTE (Diesel85 @ Jul 11 2012, 07:09 AM)
just change the the overdrive relay.
Diesel85
post Jul 17 2012, 02:19 PM
QUOTE (danielm85948 @ Jul 11 2012, 10:39 AM)
I have changed out the relay with another used one and it had the same symptoms. Is the not working for 10 minutes a common problem with bad relays? I might have got another bad relay.
Anybody have any input on charging the solenoid?
danielm85948
post Jul 17 2012, 08:53 PM
Post #18
Expert Veteran
QUOTE (Diesel85 @ Jul 17 2012, 02:19 PM)
check the wires on the solenoid ,for rust or dirt, and clean, try that first,you only need to twist it with the wires off ,note were the wires go ,it is about a 13mm spanner to remove it.
This post has been edited by danielm85948: Jul 17 2012, 08:54 PM
Oil leak in the Turbo pipes
0 Nazih Mihamed 12 18th February 2017 - 02:40 PM
Last post by: Nazih Mihamed
No New Posts Volvo Is Dead
0 Matblowen 118 5th February 2017 - 08:23 AM
Last post by: Matblowen
No New Posts Topic has attachmentsVolvo Car Show Is Almost Here
Sunday, April 28 at the Davis Park, Davis California
2 GROM Audio 1,062 3rd February 2017 - 01:10 AM
Last post by: Stven
No New Posts Volvo 240 Bad Maf Sensor/oil In Vacuum Line
MAF sensor/oil in vacuum line
2 railkat 1,966 1st February 2017 - 07:28 PM
Last post by: Jan Berg
No New Posts Volvo Car Fault Codes List
1 igor2009 279 1st February 2017 - 11:26 AM
Last post by: ALineCanine
Time is now: 26th February 2017 - 11:26 PM
