> S60 Door Lock/window Control Module, Cabin Temperature Sensitivity
Vermont
post Oct 15 2010, 04:43 PM
Drives: 2002 Volvo S60
I've searched the topics here to see if my problem has been covered before, and it doesn't appear to have been . . . . yet.
My S60 Door Lock/Window Control Module "chatters" and ceases to function anytime the cabin temperature drops below roughly 50F. When the cabin warms up, it quiets down and functions fine.
This started acting up late last Spring, and then went away completely for the Summer. Now it's back, and seems to require more warmth as time progresses.
I tried the re-set function described in other threads (holding the front window controls in the closed position for 5-8 seconds, etc), and that doesn't appear to do anything. The Module continues to "chatter" I have yet to try it while the cabin temperature is above 50F, an will try to do that tomorrow.
Someone else suggested that maybe removing the Control Module and cleaning the connector might give me some relief; but I doubt that any dirt/grease alone would be behaving the way this is.
The Car itself has 186,000 miles on it; but the windows are rarely activated, and the Car is typically securely locked up just one or twice per day. The fact that this fixes itself with the mere change in temperature leads me to believe that it's the Control Module itself which is compromised.
As I will soon be experiencing outdoor temperatures that are routinely below -20F, and often below -50F, I thought I'd have to deal with this very soon. And before purchasing a new Control Module from Volvo, I wanted to ask if anyone else has experienced similar symptoms and solved the problem in a less expensive manner ?
Thanks for your help. This is my first post and the sole reason for my searching out and registering on this Forum. I may be able to contribute some insights as well, if I can solve this "chattering" issue inside the Driver's door (left hand American set-up).
Thanks again.
jpit
post Oct 16 2010, 04:57 PM
Drives: 2001 S60
QUOTE (Vermont @ Oct 15 2010, 04:43 PM)
Thanks again.
I have had issues with my window switch pack not working intermittently and it also appears to be more evident in the colder weather but also happens occasionally happens in warm weather as well. I haven't ever experienced any chattering. I know that if I remove the switch pack and just unplug and plug in the 2 connectors it appears to function okay for a while.
ikey
post Oct 16 2010, 05:58 PM
Drives: 2002 Volvo S60 T5
I experienced a similar problem with my passenger door module a couple of winters ago. Nothing worked until the temp was over 40F. It worked like that for about a month before it stopped working all together. Had to take it to the dealer since the new module needs a software load from Volvo.
Vermont
post Oct 17 2010, 07:30 AM
Thanks to both of you, ikey and jpit, for considering this.
I've talked to quite a few people who know more about auto electronics than I do, and no one has acknowledged any experience with this kind of problem with any other vehicle.
I did the re-set yesterday with the cabin temperature above 50F, and will go out today to see if that could miraculously have fixed it.
I doubt that cleaning the connectors will do anything, unless I have somehow collected some kind of dirt bearing the attributes of a thermistor . . . . which is quite un-likely.
My next step will be to see about buying a new Control Module. I buy everything over the Internet or by Mail Order through Tasca Volvo in Rhode Island/Massachusetts. I would hope that they would be able to program the Module remotely using my VIN and the Key Codes for the vehicle.
The Volvo MSRP for that Module is about $250; but my price is $137. That probably doesn't include the programming of it for my vehicle; but I haven't asked yet. Does that sound reasonable ?
I thought the Swedes built these cars for cold weather . . . . but maybe not this cold.
ikey
post Oct 18 2010, 09:11 PM
The price you have been quoted is quite good. I attempted to fix the door myself and replaced the module with one from a salvage yard, which cost me $80. Unfortunately, without the software, only the remote lock/unlock worked. The dealer charged me $797 for the repair: $483 for the module, $279 for labor, $90 for the software and the rest was tax. I asked them if they could reload the module I put in, but they stated they can't work with "aftermarket" parts. Hopefully your dealer is more understanding.
Vermont
post Oct 19 2010, 08:17 AM
That sound's like your being held up for a ransom !
QUOTE (ikey @ Oct 18 2010, 10:11 PM)
The one and only Volvo dealer in Vermont is over 100 miles from me . . . . and is not very understanding at all . . . . everything they do is MSRP and they only give other servicers 5% off those prices.
So I've taken to using Tasca for all my parts that must be OEM, and ordering parts by mail order on-line or by phone from their retail parts department. The entire parts inventory is accessible on-line for research. They've been very good to me; and the Parts Department personnel are pretty knowledgeable. Being a Volvo Dealer, we'll see how they deal with the cost of burning in the programming of this Control Module. I'll report back.
No New Posts Door Locking
1 spennycfc 405 13th March 2016 - 01:47 PM
Last post by: grendel1960
No New Posts S60 T5 Dashbord
5 luban 2,000 1st March 2016 - 03:54 PM
Last post by: revvie
No New Posts Door Mirror
How do I dismantle the door mirrors?
3 bazzac30 3,276 19th January 2016 - 11:14 AM
Last post by: hunt
No New Posts S60
Reduced Engine Performance
6 beboop 4,278 12th January 2016 - 01:22 PM
Last post by: hunt
No New Posts Door Open Chime On All Time Help!
1 Voljoe 308 14th December 2015 - 03:30 PM
Time is now: 23rd January 2017 - 01:25 AM
