> 850 Alarm Problem, resetting alarm
tivyvolvo
post Apr 21 2010, 02:38 PM
Drives: 850 estate
Hi i need help with my 850 est Yesterday i locked my 850 with the remote and all was fine untill i returned and the remote would not work.I used the key to unlock and the alarm went off ! and it would not start. i think the batts in the remote may have been low i have put new batts in but still wont work? any ideas what has happend and what i can do to sort it im thinking maybe the alarm ect needs resetting so does anyone know how to do it ? many thanks...
SeaMike
post Apr 21 2010, 10:12 PM
Senior Veteran
QUOTE (tivyvolvo @ Apr 21 2010, 02:38 PM)
tivyvolvo
post Apr 22 2010, 05:49 AM
Drives: 850 estate
cant reprograme remote as alarm is still active some how need to reset alarm somehow? any ideas welcome
SeaMike
post Apr 22 2010, 11:25 AM
Senior Veteran
QUOTE (tivyvolvo @ Apr 22 2010, 05:49 AM)
cant reprogram remote as alarm is still active some how need to reset alarm somehow? any ideas welcome
This is how it is done. I called a dealer.
How many remotes do you have? if more than one, you MUST have ALL remotes with you when you do this process.
1. Collect all remotes for the car, have them with you in the car.
2. Put the key in the ignition switch.
3. Get in car car, DOORS MUST BE CLOSED.
4. Turn the key from OFF position to the On position (II position) 5 times times, on the 5th time leave the key in the On position, then you press any button on the remotes you have. They should at that point be reset.
That is it.
tivyvolvo
post Apr 22 2010, 11:32 AM
Drives: 850 estate
QUOTE (SeaMike @ Apr 22 2010, 05:25 PM)
That is it.
cant get to that stage,cant as yet get into car without alarm going off key wont stop it or remote. remote is working ok as far as i know as i hear a chirp from it when buttons are pressed but not turning alarm off.My only other thought is that the black relay under the steering wheel has packed up ? its a pain.....
SeaMike
post Apr 22 2010, 12:13 PM
Senior Veteran
QUOTE (tivyvolvo @ Apr 22 2010, 11:32 AM)
Hey,
So you using the key won't by pass the alarm? It should.
Have you called a dealer there yet?
SeaMike
post Apr 22 2010, 12:16 PM
Senior Veteran
Disconnect the battery for like 10 min...then try and reset it.
tivyvolvo
post Apr 22 2010, 12:41 PM
Drives: 850 estate
QUOTE (SeaMike @ Apr 22 2010, 06:16 PM)
not contacted dealer yet was going to call them after the weekend.Will try disconecting battery and see what happens,thanks for your tips .. (IMG:style_emoticons/default/liebe011.gif)
tivyvolvo
post Apr 22 2010, 02:17 PM
Drives: 850 estate
QUOTE (tivyvolvo @ Apr 22 2010, 06:41 PM)
no luck with disconecting battery,however i have just found another alarm relay box its a different colour but just pluged it in under dash and took other one out and no alarm going off now ! downside is no remote locking just working on the key guess i will have to keep an eye out for a replacement relay that maches my old one thanks for all help on here
odinterimon
post Jan 5 2011, 04:27 PM
Drives: 1997 volvo 850 cd t5
Hi guys,
I came on here but like you guys didn't find the answer to the actual question, " how to reset alarm once it's armed if your door switches won't work? "
Now although the central locking still worked once the door is open the alarm goes off and then your in trouble cos you can't drive it even with the key in, as its suposed to its immobilised, the old on off with the key will not work , but if you put the key in within 10 seconds and turn ignition on and hold in the start position after a few seconds the alarm resets, now program your alarm fob, With new batteries fitted first, as it appears if your unlucky enough for batteries to fail once alarm is set you get this senario we have just been through. I have just done this last night as my batteries failed while I was at work, lucky I had a spare set, but then the above problem started . Took 2 hrs to find solution but he it is, hope it helps someone.
No New Posts Problem With Radio
1 tofinis 237 8th November 2016 - 09:05 PM
No New Posts Problem With 2002 Volvo S80 T6?
1 qingqin 183 1st September 2016 - 02:59 AM
No New Posts Topic has attachmentsProblematic Lights
Front lights only work on "0" mode
0 petertjeehh 159 29th August 2016 - 04:42 PM
Last post by: petertjeehh
No New Posts Problem With Climate Control
2 LenCT 367 22nd August 2016 - 07:09 PM
Last post by: LenCT
No new Pinned: 850 Seat Back Cable Repair
49 Tech 29,277 5th July 2016 - 08:41 AM
Last post by: john21wall
Time is now: 26th February 2017 - 11:24 PM
