> Heater/ac-fan/blower Problems
joshmadmytim
post Aug 12 2009, 02:42 PM
Drives: 2001 Volvo S40 Turbo
I have a 2001 Volvo S40 Turbo and have been having problems with the heater/AC Fan/Blower for about a year or so. The first problem is that no matter what setting I have the fan set to (off or 1-5) it will randomly turn onto full blast for a few seconds and then turn back to wherever it was originally set. This happens every time I drive the car - multiple times. Second problem is that sometimes the AC will not get cold and the heater will not get hot. This happens sporadically, but sometimes it works perfectly... The most recent problem has happened twice in the last week - The fan/blower will not turn on at all, but after i get to wherever I was going and restart the car it will work fine. Any ideas....??
brn14me
post Sep 1 2009, 04:29 AM
Drives: 2001 s40
my air conditioning does the exact same thing
2001 s40 as well
i've only had the car for 5 months but it's always done it
i had a buddy of mine in the car thought my a/c worked great because it was blowing full blast on 1/2 -- it doesn't bother me so much since it does work but it's interesting others have the same issue
sillyusername
post Jan 13 2010, 09:42 AM
Drives: 2001 volvo S40
my a/c and heat do the same thing too - especially when i have the fan in the AUT position. i've asked my mechanic to check it out and after some preliminary digging around, he couldn't find anything wrong.
has anyone found the root of this problem? (it's disappointing and cold when the heater doesn't work as well as one would like in these frigid temps these days.)
little tommy
post Jan 30 2010, 07:56 AM
Drives: 2002 S40
You are not the only one with this problem.
http://s40concepts.net/forum/index.php?t=m...e93ca27061b0bb7
raookc
post Jul 1 2010, 03:51 AM
Drives: 2003 Volvo S40 BiFuel
QUOTE (little tommy @ Jan 30 2010, 08:56 AM)
I have a problem in the A/C of my 2003 Volvo S40.
The a/c does not start when I turn the knob. But in the middle of a journey when I hit a bump, it suddenly turns on and turns off after a while.
Any ideas as to what could be the problem?
tam85
post Jul 26 2010, 05:38 PM
Drives: 2000 volvo
my 2003 volvo heater fan stoppped working, i already checked the fuse and it looks ok. i tried to look at the wiring diagram in the manual but i cant find the relay. can somebody help me to find this relay? thanks.
_____________________
car parts | -tammy beede-
RodJoe
post Sep 28 2010, 10:56 AM
Drives: 2001 Volvo S40 1.9T SE
I have a 2001 Volvo S40 SE and just noticed I have no HEAT. The fan motor blows on all settings, but all that comes out is Cold Air. Also noticed my seat heaters are not working. I see many post for heater problems, but none that match my specific problem.
Can anyone please help?
EddyS40
post Nov 13 2010, 11:27 PM
Drives: S40 2.0T
Hi, I had the same problem and my mech told me is the AC controller problem....need to change the whole AC controller panel. Which cost me a bomb. Still considering to change or not since is working fine sometimes...hehehe
Da Vince
post Oct 11 2011, 12:54 PM
QUOTE (EddyS40 @ Nov 14 2010, 06:27 AM)
Been a while since you guys posted your problems, but I hope you all managed. But it seems like you all had a Power Transistor problem. It is used for controlling the cabin fan speed, one some mechanics call a Resistor, which is very wrong, because if can't tell a difference between a transistor and a resistor you probably shouldn't be opening people's cars engine hood anyways. It's located somewhere behind the glove compartment, passenger 'side, more like hidden rather. It's a shiny electronic device, on a heat sink because it uses PWM and gets very hot at high fan speeds. The common one is a 2N3055, it's a PNP, and it should cost you less than a dollar at an electronic component shop, not a garage! You can google 2N3055, then you'd know exactly what you looking for. All you need to do next is to solder out the old one and the new one in.Careful, just becareful that you put it the right way in, note positioning when removing the old one. One leg is an emmiter, the other is called a base, and the body is a collector, so careful they go the right way in. Good luck!
keder
post Dec 22 2012, 09:34 AM
Drives: 2001 Volvo V4 T4
QUOTE (Da Vince @ Oct 11 2011, 06:54 PM)
First Hi to all.
In my case with 2001 V40 T4 it is not 2N3055, it is MJ 802 and it is not PNP it is NPN, but your post helpt a lot and now I have a 2N3055 in car and it is working, but wit first 2 gears of vent I have a problem with radio, strange noise is coming with music, so it is better with MJ 802.
By and thanks one more time
volvo-xc90-2005
post May 18 2015, 12:16 PM
Drives: 2005 Volvo XC 90 T5 AWD
QUOTE (Da Vince @ Oct 11 2011, 01:54 PM)
My other car 2003 Volvo V-40 had the same problem as is the topic of this thread. I have followed the advice from this forum (and others) and bought a 2N3055 NPN transistor from Radio Shack. Installed it. The AC worked well for about a week. Then, it did work with interruptions, then, it did not work at all. After some research, I realized what the mistake was. 2N3055 has Max of 15A, but a higher maximum collector current was needed for it. Therefore, I have purchased a new transistor - MJ802 that has max 30A. It has the same specification as 2N3055 - NPN - and has the same casing: TO-3. Replaced the 2N3055 with MJ802. Case solved. The AC unit is operating now as it should be.
relayer77
post Jan 10 2016, 05:51 PM
Drives: 2001 V40
I had the problem where the fan was always blowing on high no matter which setting was on the dial. I replaced the fan blower transistor, and that fixed it. The fan now works according to the setting for the knob on the dash.
But the heater is still intermittent, and it fails a lot more than it works. The fan only blows cold air, no matter what temp setting I select with the knob on the dashboard. Any ideas? Thanks!
John
danielm85948
post Jan 11 2016, 03:49 AM
Expert Veteran
QUOTE (joshmadmytim @ Aug 12 2009, 03:42 PM)
to each of you with this it is very common for the relay to fail,so try change it.
No New Posts Problems After Drain Cleaning
Errors and door open chime
0 RosemaryB 454 2nd January 2016 - 05:41 PM
Last post by: RosemaryB
No New Posts Problems With Swm, Possibly?
No turn signal, no cruise control, no high beam.
8 murta 587 20th October 2015 - 02:16 AM
Last post by: murta
No New Posts Problems With A Volvo C70 Stuck In Park!?
1 bemshawn 678 21st August 2015 - 10:33 PM
No New Posts Problems Starting 2006 Volvo After Changing Battery
1 geoloog 2,027 3rd December 2014 - 07:42 PM
Last post by: Vermont
No New Posts Topic has attachmentsProblems With Dashboard Air Ducts
One has a fin loose and the other has foam and a yellow-white thing
0 qwertie64982 991 28th August 2014 - 05:07 PM
Last post by: qwertie64982
Time is now: 22nd February 2017 - 05:05 PM
