> Troubleshooting Guide To Volvo 240 No-starts And Stalls
post Jul 28 2009, 02:36 PM
Troubleshooting guide to Volvo 240 no-starts and stalls.
This guide covers the common reasons as to why a 240 won't start. Please contact me if you find something missing or incorrect. This is a brief overview, I highly recommend the "Volvo 240 Service Manual" from Bentley Publishers for more detailed information:
http://www.bentleypublishers.com/volvo/Volvo-240-1983-1993-Repair-Manual.html
Starter turns the engine but the car won't run or stalls.
Determine if the problem is due to a lack of compression, fuel or spark.
Compression view the camshaft with the oil cap removed while cranking to make sure it turns, this will verify the timing belt hasn't broke. Perform a compression test if needed.
Spark hold a spark plug wire close to the fender while cranking (away from the battery) to verify a strong orange spark. If no spark:
With the key on, verify that battery voltage is present on the blue coil wire (terminal #15). Take resistance measurements on the coil. Inspect the distributor cap, rotor, spark plugs and wires.
For 89-93 EZ-116K: Check for ignition trouble codes using socket 6. See http://www.brickboard.com/FAQ/700-900/EngineOBDCodes.htm
For 89-93 Inspect/replace the crank position sensor. Add dielectric grease to the heat sink of the power stage. Verify power to the ignition ECU. Verify the operation of the temperature sender and throttle switch.
For 83-88 Volvo/Chrysler system: Verify power, ground, and the output signal from the Hall Effect sender contained inside the distributor. Be careful with the connector, it will break easy. Verify battery voltage is present on the blue ECU wire (#2). Verify the operation of the throttle switch. A 83-88 diagnostic flow chart can be found here: http://www.volvo-forums.com/index.php?act=...ost&id=5403
Fuel 1989-1993 LH2.4-LH3.1: Check for fuel trouble codes using socket 2. See http://www.brickboard.com/FAQ/700-900/EngineOBDCodes.htm
For 75-90 inspect and clean the 25A blade fuse on the fender by the coil, fuse 4, and the holders. For 91-93 the underhood blade fuse was replaced by fuse #6.
For 75-84 place a jumper wire on the left side of fuses 5 and 7. For 85-93 place a jumper wire on the left side of fuses 4 and 6. Both the in-tank and main pumps will now run constantly, listen for them. If the car starts with the jumper installed then most likely the fuel pump relay is bad. For 85-93 the system and fuel pump relays are combined into one package, clipped on the firewall above the passenger's feet. As a safety feature the pumps won't run unless spark is present.
AMM The air mass meter can be placed in a "limp-home" mode by unplugging it while the battery is disconnected. If the car starts with it unplugged (but still runs rough) then most likely the AMM is bad. Make sure it is being powered by the system relay.
O2 sensor inspect the fuse that powers the sensor heater. A wire from the sensor will connect with a thick green wire on the firewall, peel back the rubber boot during a warm idle. Measure the voltage, it should cycle quickly between .2 (lean) and .8 VDC (rich).
Coolant Temp sensor a coolant temp of 180 deg. F should have a resistance of ~300 ohms. Resistance will increase as temperature decreases.
For 1975-1982 CI/K-jet fuel injection see: www.k-jet.org
The LH2.2 (85-88) wire diagram can be found here: http://www.volvo-forums.com/index.php?act=...ost&id=4435
The LH2.4 (89-93) wire diagram can be found here: http://www.volvo-forums.com/index.php?act=...ost&id=6138
Links:
Parts, FCP Groton: http://www.fcpgroton.com/
Parts, IPD USA: http://www.ipdusa.com/
Art Bernstein's 240 repair site: http://www.cleanflametrap.com/
The Brickboard FAQ/forums:
Dave Shannon: http://volvo2.homestead.com/
ECU/AMM matrix: http://www.nuceng.ca/bill/volvo/database/ecu.htm
Greaser
post Oct 1 2010, 12:00 AM
Drives: '87 245 "Lucille" '88 245 "Caroline"
As a rule of thumb, if you have one of the 240's from 75-90, keep a spare 25 amp blade fuse and hold in your glove box, along with a piece of emery cloth. You never know when its gonna blow, and when it does you'll be pissed and stranded if you dont have these on hand. Trust me, I speak from experience on this one. >.<
MTturnedhomemech...
post Nov 7 2010, 05:22 PM
Drives: 1990 Vovlo 240 DL Wagon
Thanks! I lucked out on that bit, my new car, 1990 Volvo 240 DL Wagon came with fuses in the glove compartment.
drewdle
post Jan 11 2011, 02:45 PM
Drives: 1989 240 DL
I have a pack of 1156 and 1157 bulbs and half a pack of 25A blade fuses in my dash cubby for just such occasions.
New240
post Aug 31 2011, 07:52 AM
Drives: 1992 Volvo 240 sedan
I have only had my 240 about a week and use it daily for about 50 miles daily start and stop 10 miles in between each stop. Yesterday and the day before it did not start up right away. When i turned the key it was dead, no engine turning or clicking, battery is new and was not the problem, after 2 -3 attempts of turning the key it cranked right up, seems to be a starter or ignition problem, any ideas on where a layman like myself can start?
UPDATE: Took my car in to our mechanic and he found out it was an issue with the bushings that connect the shifter rod to the transmission (IMG:style_emoticons/default/smile.gif) All fixed and thankfully not expensive! Parts and labor less then 80.00
K'Volvo
post Jan 10 2013, 02:11 PM
Drives: 1985 240 dl
Hi there
My 1985 volvo dl wont start. it ran perfect last night. Im not sure what the issue is. it wants to start but it dont.im sure its not a battery.
On a side note. i fill up the tank and decide to add fuel injection cleaner to the my tank. did that cause the issue?
D'artagnan
post Jun 15 2013, 08:28 PM
Drives: 1990 Volvo 240dl
Hey guys,
My 1990 240 dl quit running on me in the middle of the road the other day. A couple buddys helped me push it to a gas station because we thought the gauge might have broken, but that didn't help. Determined I wasn't getting spark out of the coil so I replaced that and still won't start. Any advice on what next. I've driven the car probably 8000 miles since November when I bought it and this is the first issue.
Thanks in advance!
danielm85948
post Jun 16 2013, 06:13 AM
Expert Veteran
QUOTE (D'artagnan @ Jun 15 2013, 08:28 PM)
Hey guys,
Thanks in advance!
it sounds like the ECU has failed, but tests are needed first,check the camshaft is turning in case the belt has gone ,take off your oil cap on the engine get someone to turn the engine over.you will see if your camshaft is turning if ok, next test check your distributor cap ,the centre brush is ok not badly worn if so change it clean the contacts and check your rotor arm then check for spark ,if no spark check you are getting power to the lead from your ignition switch, then check your fuses and fuse contacts for rust if no spark it can be an ignition control module has failed you have to check the electrics first.
EdWallace
post Mar 20 2014, 12:50 PM
Drives: 1983 245 DL
I have a 1983 245 DL with no spark at the HT wire on the coil. I followed the flow chart, turned on the ignition with out turning over the engine and jumped the b and c wires on the plug side not the distributer side on my chrysler ignition and did not see a spark at the end of the HT wire and ground. Is that where the spark is supposed to be? The cap was on the distributer. I had 11 volts at the #2 terminal on the control unit. I didn't notice the caution about disconnecting the plug into the control unit, but it appears that I wasn't the first one to disconnect the plug. Any thoughts?
Thanks, Ed
danielm85948
post Mar 20 2014, 04:59 PM
Expert Veteran
QUOTE (EdWallace @ Mar 20 2014, 01:50 PM)
Thanks, Ed
the fact you do not have a spark at the coil, means change the coil.
EdWallace
post Mar 21 2014, 12:24 AM
Drives: 1983 245 DL
Sorry I didn't mention that the coil is brand new and checks out by the two resistance tests. The HT wire and spark plug wires are new as well. I have 12 volts at terminal 15 (+) on the coil. Any other thoughts?
Thanks, Ed
danielm85948
post Mar 21 2014, 05:35 AM
Expert Veteran
QUOTE (EdWallace @ Mar 21 2014, 01:24 AM)
Thanks, Ed
trouble then is a failed ignition module, or your ignition switch the electrical part of it has failed. Google how to test your ignition switch on you tube.
EdWallace
post Mar 21 2014, 12:23 PM
Drives: 1983 245 DL
Thanks for answering. By ignition module do you mean the ignition control unit or the Hall effect switch on the distributor?
Ed
danielm85948
post Mar 22 2014, 04:20 AM
Expert Veteran
QUOTE (EdWallace @ Mar 21 2014, 01:23 PM)
Ed
you check for rust on the wiring of the ignition control unit ,in this country it is the ignition control module .you will find that unit by standing at the front of the car,look inside the engine bay.on the right inner wing.behind your headlight is a small black box that is the cover for the unit remove the cover .now you see the control unit,check for rust ,clean if rust found.take it you have checked all the fuses for rust ,and have cleaned them.and replaced all of the fuses.things fail due to rust ,that is why you check the fuses first ,then the wiring ,you may only need to clean the unit contacts. it may not have a cover some of them have one and some do not have it.
This post has been edited by danielm85948: Mar 22 2014, 04:24 AM
mariausman
post Aug 11 2015, 05:52 PM
Drives: toyota camry
BUY FAKE PASSPORT (mariausman1010@gmail.com) FAKE DRIVING LICENSE (DRIVING LICENSE), FALSE IDENTITY CARD (ID CARD), FALSE VISA, FALSE BIRTH CERTIFICATE.
We are a team of professionals with many years of experience in producing fake passports
and other identity documents, best quality producers of fake documents. With
more than 10 million documents circulating in the world.
We offer only original high qualities of true-false passports, driver
driving, ID cards, stamps, birth certificates, fake diplomas international
and other products for a number of countries like: USA, Australia, Belgium, Brazil, Norway
Canada, Italy, Finland, France, Germany, Israel, Mexico, Netherlands, South Africa, Spain, United Kingdom.
This list is not complete.
For additional information and place the order just
contact us by email or phone.
BUY BRITISH FAKE PASSPORTS (United Kingdom), AMERICAN, CANADIAN
FALSE IDENTITY CARDS ONLINE IN UNITED STATES, DRIVING LICENCE.
BUY FAKE BIRTH CERTIFICATES
BUY FAKE DRIVING LICENCE
Contact: mariausman1010@gmail.com
General Support: mariausman1010@gmail.com
Do not hesitate to contact us by email or call at any time and in any discretion.
TOPICS:
BUY FAKE PASSPORTS
Buy fake passports USA (United States)
Buy fake Australian passports (Australia)
Buy fake Belgian passports (Belgium)
Buy fake passports of Brazil (Brazil)
Buy Canadian fake passports (Canada)
Buy fake passports of Finland (Finland)
Buy fake passports French (France)
Buy fake German passports (Germany)
Buy fake passports Dutch (Netherlands)
Buy fake Israeli passports (Israel)
Buy fake passports UK (United Kingdom)
Buy fake passports Spanish (Spain)
Buy fake passports (Mexico)
Buy fake South African passports (South Africa)
Buy fake passports Swiss (Switzerland)
Buy fake passports of German (Germany)
Buy fake passports of China (China)
Buy fake passports of Austria (Austria)
Buy fake passports of Japan (Japan)
Buy fake passports of Ukraine (Ukraine)
Buy fake passports cambodiens (Cambodia)
Buy fake passports Romanian (Romania)
Buy fake passports Polish (Poland)
Buy fake passports Bulgarian (Bulgaria)
Buy fake passports of Morocco (Morocco)
Buy fake passports cyprus (Cyprus)
Buy fake passports Norwegian (Norway)
Buy fake passports Portuguese (Portugal)
Buy fake passports Lithuanian (Lithuania)
Buy fake passports Russian (Russia)
Buy fake passports of Hungary (Hungary)
Buy fake passports of Australia (Australia)
Buy fake passports Brazilian (Brazil)
Buy fake passports Italian (Italy)
Buy fake passports of Jamaica (Jamaica)
Buy fake South Korean passport (Korah South)
Buy fake passports Croatian (Croatia)
Buy fake passports of Denmark (Denmark)
Buy fake passports of Malta (Malta)
Buy fake passports Swedish (Sweden)
BUY FAKE IDENTITY CARDS
Buy fake IDs USA (United States)
Buy fake IDs Australian (Australia)
Buy fake IDs Belgium (Belgium)
Buy fake IDs Brazilian (Brazil)
Buy Canadian fake IDs (Canada)
Buy fake IDs Finnish (Finland)
Buy fake IDs French (France)
Buy fake IDs German (Germany)
Buy fake IDs Dutch (Netherlands)
Buy fake IDs Israeli (Israel)
Buy fake IDs UK (United Kingdom)
Buy fake IDs Spanish (Spain)
Buy fake IDs (Mexico)
Buy fake ID cards South Africa (South Africa)
Buy fake IDs Switzerland (Switzerland)
Buy fake IDs Chinese (China)
Buy fake IDs Austria (Austria)
Buy fake ID cards Japanese (Japan)
Buy fake IDs Ukrainian (Ukraine)
Buy fake IDs cambodiens (Cambodia)
Buy fake IDs UK (United States)
Buy fake ID USA
Buy fake IDs Romanian (Romania)
Buy fake IDs Polish (Poland)
Buy fake IDs Bulgarian (Bulgaria)
Buy fake IDs Morocco (Morocco)
Buy fake ID cards cyprus (Cyprus)
Buy fake IDs Norwegian (Norway)
Buy fake IDs Portuguese (Portugal)
Buy fake IDs Lithuanian (Lithuania)
Buy fake IDs Russian (Russia)
Buy fake IDs Hungarian (Hungary)
Buy fake IDs Italian (Italy)
Buy fake IDs Jamaica (Jamaica)
Buy fake IDs South Korean (South Korea)
Buy fake IDs Croatian (Croatia)
Buy fake IDs Danish (Denmark)
Buy fake IDs Maltese (Malta)
Buy fake IDs Swedish (Sweden)
Buy fake driver's license in Australia (Australia)
Buy fake Canadian driver's licenses (Canada)
Buy fake French driving license (France)
Buy fake Dutch driving license (Netherlands / Holland)
Buy fake driving license German (Germany)
Buy fake UK driving license (United Kingdom)
Buy fake driving license Cameroon (Cameroon)
Buy fake driving license Chinese (China)
Buy fake driving license in Switzerland (Switzerland)
Buy fake driving license cambodiens (Cambodia)
Buy false Australian driver's license (Australia)
Buy fake driving license Russian (Russia)
Buy fake driving license French (France)
Buy fake international driving permits
Buy fake driver's license Japanese (Japan)
Buy fake driving license Ukrainian (Ukraine)
Buy fake driver's license from Austria (Austrian)
Buy fake driving license USA
Buy fake driving license Spanish (Spain)
Buy fake driving license Portuguese (Portugal)
Buy fake driving license Hungarian (Hungary)
Buy fake driving license (Mexico)
Buy fake driver's license in Belgium (Belgium)
Buy fake driving license Greek (Greece)
Buy fake driving license Romanian (Romania)
Buy fake driving license Lithuanian (Lithuania)
Buy fake driving license Polish (Poland)
Buy fake driving license Bulgarian (Bulgaria)
Buy false Australian driver's license (Australian)
Buy fake driving license Norwegian (Norway)
Buy fake Brazilian license (Brazil)
Buy fake drivers license Italian (Italy)
Buy fake driving license Jamaica (Jamaica)
Buy fake driving license South Korea (Korea)
Buy fake driving license Croatian (Croatia)
Buy fake driving license Danish (Denmark)
Buy fake driving license in Malta (Malta)
Buy fake driving license Swedish (Sweden)
DIPLOMATIC PASSPORTS BUY FAKE
Buy fake diplomatic passports Chinese
Buy fake diplomatic passports Greek
Buy fake diplomatic passports UK (United Kingdom)
Buy Lithuanian fake diplomatic passports
Buy fake Canadian diplomatic passports
Buy fake diplomatic passports Bulgarian
Buy fake diplomatic passports Portuguese
Buy fake diplomatic passports Polish
Buy fake diplomatic passports USA (United States)
Buy fake Australian passports, diplomatic
Buy fake diplomatic passports Belgian
Buy fake diplomatic passports Brazil (Brazil)
Buy fake Canadian diplomatic passports (Canada)
Buy fake diplomatic passports Finnish (Finland)
Buy fake diplomatic passports French (France)
Buy fake diplomatic passports German (Germany)
Buy fake diplomatic passports Dutch (Netherlands / Netherlands)
Buy fake Israeli diplomatic passports
Buy fake diplomatic passports Spanish (Spain)
Buy fake diplomatic passports (Mexico)
Buy fake South African diplomatic passports
Buy fake diplomatic passports Norwegian
Buy fake Brazilian diplomatic passports
Buy fake Italian diplomatic passports
Buy fake diplomatic passports Jamaican
Buy fake South Korean diplomatic passports
Buy fake diplomatic passports Croatian
Buy fake diplomatic passports Danish
Buy fake diplomatic passports Maltese
Buy fake diplomatic passports Swedish
Buy camouflage passports
Buy duplicate passport
Allowed false USA (United States) for sale
False Australian passports for sale
Belgian fake passports for sale
Brazilian fake passports (Brazil) for sale
Buy, obtain false passports, identity cards.
Sell ??Online, Canadian, British, new INFRINGEMENT
licenses, driving licenses, birth certificates, diplomas
BUY FAKE DEGREES INTERNATIONAL
Buy fake diplomas Cameroon
Buy fake diplomas Chinese
Buy fake diplomas Swiss
Buy fake diplomas cambodiens
Buy fake diplomas Australian
Buy fake diplomas Russian
Buy fake Canadian graduates
Buy fake diplomas French
Buy fake diplomas international
Buy fake diplomas Japanese
Buy fake diplomas Ukrainian
Buy fake diplomas Austrian
Buy fake diplomas UK
Buy fake diplomas USA
Buy fake diplomas Spanish
Buy fake diplomas Portuguese
Buy fake diplomas Hungarian
Buy fake diplomas Mexican
Buy fake diplomas Belgian
Buy fake diplomas Greek
Buy fake diplomas Romanian
Buy fake diplomas Lithuanian
Buy fake diplomas polonaiss
Buy fake diplomas Bulgarian
Buy fake diplomas Italian
Buy fake South African graduates
Buy fake diplomas Israeli
Buy fake diplomas Norwegian
Buy fake diplomas Brazilian
Buy fake diplomas Jamaican
Buy fake diplomas South Korean
Buy fake diplomas Croatian
Buy fake diplomas Danish
Buy fake diplomas Maltese
Buy fake diplomas Polish
Buy fake diplomas Swedish
CONTACT US VIA EMAIL ::::::::::::::::::: mariausman1010@gmail.com
No New Posts Volvo 240 Transmission Knocking Noise
2 Cuffman 71 15th January 2017 - 02:20 PM
Last post by: Cuffman
No New Posts Volvo V40 Isofix Anchors
2 starman1970 693 31st December 2016 - 07:53 AM
Last post by: Olaf V40
No New Posts Volvo Truck Fault Codes List
0 igor2009 52 21st December 2016 - 04:43 AM
Last post by: igor2009
No New Posts Volvo Car Fault Codes List
0 igor2009 120 21st December 2016 - 04:39 AM
No New Posts Volvo Gps System
seems really out dated
2 bobnphred 179 14th December 2016 - 04:31 PM
Last post by: ericy
Time is now: 21st January 2017 - 06:39 PM
