> What Is The Sensor Above The Fuel Line.
nmodlin
post Jun 19 2009, 10:58 AM
Drives: 95 Volvo 850 Turbo
My 95 850 turbo has been randomly shutting itself off while driving so I replaced the fuel filter today. While doing the i noticed the hoses (I am assuming vacuum lines) conecting top a Sensor above the fuel filter are broken. Could this be the culprit of why it is shutting off and also what is that sensor. Thank you in advance
SeaMike
post Jun 19 2009, 09:13 PM
Group: Moderator
Drives: 1995 Volvo 850 GLE (Canada Car)
QUOTE (nmodlin @ Jun 19 2009, 08:58 AM)
That should be a fuel pressure regulator. Get it reconnected asap.
nmodlin
post Jun 19 2009, 09:47 PM
QUOTE (nmodlin @ Jun 19 2009, 11:58 AM)
DO ing it at 8 am tommorrow morning would that cause the problem i am having. It sounds like it owuld
SeaMike
post Jun 29 2009, 03:54 PM
Group: Moderator
QUOTE (nmodlin @ Jun 19 2009, 07:47 PM)
Doing it at 8 am tomorrow morning would that cause the problem I am having. It sounds like it would
Did it solve the issue?
nmodlin
post Jun 29 2009, 04:01 PM
Sorry i forgot to reply. It seem to have for a few days but than it did the same thing again . Far as i know it hasnt repeated the problem but I the car shut off when i was making a turn at an intersection luckily it was a slow road cause i had to get out and push it out of the way. One thing i noticed was right before it happened i smelled something funny almost like burnt plastic.
SeaMike
post Jun 29 2009, 04:08 PM
Group: Moderator
QUOTE (nmodlin @ Jun 29 2009, 01:01 PM)
Look around for melted plastic. I am going to change my fuel system relay tomorrow when it come in. Then the fuel pump relay next week... I just don't want any issues later.
How many miles do you have on your 850? What have you don't to it as far as tune ups etc in the last 6 months to a year?
Do you have Triple AAAA?
SeaMike
post Jun 29 2009, 04:09 PM
Group: Moderator
some-beach!
post Jun 30 2009, 10:03 PM
Drives: '96 Jeep Cherokee Country ~ '98 Jaguar XJ6 ~ '96 Volvo 850 Turbo wagon Platinum Edition
The fuel pressure regulator is located on the fuel rail. The "hoses" you're seeing are likely a fuel return line or a tank vapor release hose??
To check your fuel pressure regulator, remove the hose from the end. If you see fuel coming out, replace it. Your problem could be numerous things, weak fuel pressure, ignition problems, vacuum leaks, etc...
nmodlin
post Jul 1 2009, 07:01 AM
We think we have around 250,000 miles on it. IT stopped counting at 176,000. besides this problem the darn thing has been running like a champ.
nmodlin
post Jul 21 2009, 05:40 PM
ok so it was fine for a month or 2 and now it satrted shutting off again. COuld it be the fuel pump and relay?
post Jul 22 2009, 11:16 AM
when you place the key in the ignition, turn it to the first stop, do you hear a whirring like sound? if so, your fuel pump is working. if you don't then it might be the relay (most likely) or the fuel pump itself (also most likely according to the mileage you quoted) i don't think it is either one. have you pulled any codes from the ecu? as an aside, you didnt' say if the car was hard to start after it shuts off? does it crank and crank? when you first start the car in the morning, does it take longer than usual to start, or does it start as quick as it always did?
nmodlin
post Jul 22 2009, 12:07 PM
1)when you place the key in the ignition, turn it to the first stop, do you hear a whirring like sound? Yes
2)have you pulled any codes from the ecu? No i have not had that checked. i guess i would have to go to a repair place to have this done correct?
3)you didnt' say if the car was hard to start after it shuts off? NO
4)does it crank and crank? No It starts up completely fine but as soon as you give it gas to drive it shuts back off.
5)when you first start the car in the morning, does it take longer than usual to start, or does it start as quick as it always did? Starts like it always did.
post Jul 22 2009, 01:22 PM
for the codes, autozone does it for free. i think pepboys charges like $25. or, you can do it yourself. if you check the 850 forum, it'll tell you how to get the codes out of the black box that is located by the washer fluid bottle under the hood. if you hear the fuel pump, it might be the relay, but they run around $100. if you have a junkyard near you, see if they have one. it'll be a pinkish color. the relay is located under the fuse panel, under the hood, back near the windshield, drivers side. open her up, and lift off the fuse panel, the relay is located beneath that panel. middle one, it's the biggest one. most likely with a number 121 on it (i think, it has been a long time since i've replaced mine.) other than that, it could be the fuel rail, or, when the filter was done maybe the line was pinched.
nmodlin
post Jul 22 2009, 04:26 PM
I looked all over the forums for directions but couldnt find them luckily my local pepboys will check it for free but they cant until this weekend. Should i go ahead and order a fuel pump relay?
post Jul 23 2009, 03:23 PM
always good to have one handy, especially if it has never been replaced. you can try this also, if and when it dies on you again, and you are safely on the side of the road, open the fuse tray, and tap the relay, either with your knuckles or the handle of a screwdriver. sometimes this will let it live a little longer. but either way, a new relay is good to have in your glovebox that way, you can change it over and see if it does it again, if it does, at least you have taken this off the list of suspected culprits and you won't have to worry about the relay for another 150K miles.
nmodlin
post Jul 23 2009, 04:15 PM
Well thasnks for the help i am ordering a new relay now so hopefully that will fix it
No New Posts Fuel Pump Installation
wire colour
2 Benmac 17 Yesterday, 01:46 PM
Last post by: Benmac
No New Posts Is Every One Here "pro Volvo"
General
1 shakey 54 23rd July 2010 - 09:27 PM
Last post by: poopbunny
No new Topic has attachmentsWhat Was Your 1st Car?
55 volvoz 4,042 23rd July 2010 - 03:21 PM
Last post by: johnal
No New Posts What Happened?
Car is starting to fall apart!!!
1 tileking13 71 16th July 2010 - 10:17 PM
Last post by: tileking13
No New Posts Topic has attachmentsIs Your Hood Stuck Closed?
How I fixed mine.
5 xpiecemealx 57 8th July 2010 - 03:04 PM
Last post by: FCPGroton
Time is now: 29th July 2010 - 08:36 AM
