> Running After Fix!, Replace FULL cooling system CANT find the bubble!
79gt
post Jun 14 2009, 02:53 PM
Drives: 1979 Volvo 242 GT
Thanks for Viewing my topic for starters!
To the problem at hand. I replace my FULL cooling system radiator,hoses,water pump, thermostat, res cap etc... all except for heater core. I got it all sealed up again without any leaks put a mix of 60/40 in it. Started it up ran it for a bit. Decided to take it down the road and it got HOT It never breaks over into the RED area but runs right under. It's becoming a big problem. I thought it might be head gasket but, tested not the problem. It's getting hot enough it caused my stock Ignition module to die. I replace it and drove it around some more and cause the new one to get hot and kill my car for a bit.
Long story to short can you please tell me how to get an air bubble out of a cooling system that is completely sealed?
Please if you have a heart send a reply!
nice86
post Jun 15 2009, 01:40 AM
Drives: 1986 Volvo 245
First, I hope the thermostat has a jiggle valve and it's installed so the valve is uppermost to allow air to escape into the upper radiator hose. With the engine running, turn on the heater control valve inside the car and remove the coolant reservoir cap. It may help to squeeze the upper radiator hose -- use gloves so you don't get burned.
There should be a burb or bubbles visible in the coolant reservoir after the thermostat opens up.
If still bad, I suspect a bad thermostat. Did you check it in a pan of hot water before installing it? Does the upper radiator hose get hot? Does the heater put out hot air?
79gt
post Jun 15 2009, 10:48 PM
QUOTE (nice86 @ Jun 15 2009, 01:40 AM)
That would be negative Mr. I didn't check the thermostat. I did however do the rest just as how I knew how to. The hose out of the motor gets warm but, I can still squeeze it with my hand and not get burned. The inlet line to the pump is almost luke warm. That is what is making me wonder. With what you have said to me sounds like a faulty thermostat or maybe bad sending unit?
nice86
post Jun 16 2009, 10:00 AM
My upper radiator hose is 190-200 degrees F at normal operating temp, according to my laser thermometer. Too hot to grab onto. I would double check the thermostat.
No New Posts After Market Stereo For V70
looking for an in dash receiver that works with steering wheel control
1 chrisvolvov70 26 7th March 2010 - 05:06 PM
Last post by: sailor1065
No New Posts Aftermarket Add Ons - Looking For Recommendations
2008 XC90 Aftermarket Recommendations
0 thevo711 38 21st February 2010 - 10:13 PM
Last post by: thevo711
No New Posts Aftermarket Turbo Manifolds
7 juzzy 85 12th February 2010 - 06:56 PM
Last post by: juzzy
No New Posts Aftermarket Wiper Blades As Good As Volvo Brand?
2 2007 XC70 Owner 129 10th February 2010 - 07:19 PM
Last post by: davidp158
No New Posts After Market Hid's Errors, Low Beam Failure Message, Possible Easy Fix?
4 Brians2001s60 370 5th January 2010 - 04:53 PM
Last post by: steveblezy
Time is now: 12th March 2010 - 12:11 PM
