> Temp./pressure Sensors For E/fan
melter65
post May 18 2005, 11:49 AM
Drives: '94 Volvo 940
I was losing coolant (empty exp. tank after a 5 mile journey) Originally I thought this was an e/fan problem as it wasn't cutting in at idle after a journey. But after finding a small amount of coolant on the garage floor, I traced it to a split pipe coming out of Oil Filter base. Pipe replaced, problem solved.
Trying to find the source of the leak threw up a number of puzzles. According to the Haynes comicbook, the sensor for the e/fan is either in the sidetank of the radiator or fits into the top hose. On my 940 it isn't in either place. I traced it to a plastic covered brass unit, bolted to the engine block!
Neither does the Haynes comicbook cover the 2 (or 3) pressure switches fitted low in the rad. front. I found out (by shorting across) that the e/fan is two-speed, presumeably depending on cooling system pressure to increase or decrease fan speed?
My local dealer wasn't very helpful. After all, I wasn't wanting a new car, just advice on an 11yr old one! But the dealers chief-mechanic said he'd heard of my type e/fan sensor, but didn't say where.
Reading other posts on this forum has raised suspicions that my 940 may have a 240 engine fitted? Is this possible?
post May 18 2005, 11:55 AM
Look over by the over flow bottle and see if you have 2 black relays that are exactly the same.If so one is for the fan and the other is for the fuel pump.
I think the engine computer reads the temp and tell it when to turn on with your car.
melter65
post May 18 2005, 11:57 AM
Thanks Tech :)
I'll take a look at that tomorrow.
post May 18 2005, 02:21 PM
Ok let me know how you make out.
melter65
post May 28 2005, 02:52 PM
Sorry for the delay in replying, Tech, work commitments have kept me away from the forum.
I looked all round the Overflow Bottle (Expansion Tank) but there's no sign of any relays whatsoever.
Should a partial loss of coolant, say half the Overflow Bottle, result in a notable rise in coolant temp on the dashboard gauge?
I ask this because all through my particular problem, the temp gauge needle has never risen above the middle of the gauge.
Is there a simple way of testing the temp gauge, just to make sure it is reading properly?
Thanks in advance,
melter65
post May 29 2005, 12:11 PM
It usually takes more than a half of the bottle loss to make the temp rise.
There is a way to OHM out the sensor and compair it to a chart and see what the temp is but I don't have the chart with the spec's.
The relay might be on the other side under the hood.It is a black relay with a square plug on it.
The relay looks like the one in the pictures.
Attached thumbnail(s)
Attached Image Attached Image
melter65
post Jun 1 2005, 02:28 PM
Thanks for the pictures of the relays, Tech. I'll look on the other side of the engine bay when I get a chance.
Good news is that because of the warm weather, combined with getting stuck in traffic, my e/fan actually cut in this afternoon! At least I know it's working now!
Having said that, the temp gauge never rose above the middle before, and it never dropped below the middle when the e/fan came in. This is why I'm worried that the dashboard gauge isn't working properly.
post Jun 1 2005, 08:23 PM
One more quiestion have you replaced the thermostat lately?
They sometimes break and will make the guage read funny.
melter65
post Jun 3 2005, 02:24 PM
Good call, Tech! I'll see about changing the 'stat this w/end.
I know the 'stat is opening (because of the sudden temp rise in the top hose) but I don't know if it's opening fully, or at the correct temp.
post Jun 3 2005, 11:26 PM
Let me know if itis broke once you get in there.
melter65
post Jun 7 2005, 03:48 PM
Haven't had chance to get the 'stat out yet (work again!)
Back to the pics of the relays, Tech. Are they back-to-back in a bracket on top of the wheel arch? If so, they are on the (British) passenger side of my engine bay.
This is the opposite side to the overflow bottle, so I may be wrong!
post Jun 7 2005, 07:10 PM
They might be.If they look exactly like the picture I posted then yes it will be them.
melter65
post Jul 26 2005, 03:42 PM
Just to bring this up to date and close this thread :)
Since my last post, I've replaced all the hose clips with new jubilee clips, replaced a couple of the smaller hoses that were fraying at the ends, replaced the thermostat (sorry Tech, I binned it, forgot to test it!) Removed, cleaned and replaced the pressure switches in the rad, completely flushed the cooling system through and replaced the expansion tank (overflow bottle) lid :blink:
Something worked! During the recent spell of hot weather the e/fan kicked in whenever I pulled up in traffic, or I was parking the car. Just as it did when I bought the car last August :grin:
Thanks to Tech, for all his ideas and suggestions :clap:
The beers are on me :beer:
post Jul 27 2005, 08:12 PM
Glad I could help :banana:
Oil Pressure Sender
SykO 10 1 Today, 07:33 AM
Reversing Sensors
sinbad_36 33 1 Yesterday, 10:29 AM
By: MKC70
Turbo Pressure Gauge Or Turbo?
paulsendavidj 58 8 Aug 24 2008, 11:04 PM
Coolant Temp Gauge
Wufpack 26 0 Aug 22 2008, 09:18 PM
By: Wufpack
A/c Fan/blower Filled With Water
rmtworks 29 1 Aug 21 2008, 05:45 AM
Time is now: 30th August 2008 - 08:24 AM
