> 1995 Volvo 850 Turbo Overheating, overheating
kiakid2007
post Mar 27 2009, 11:08 PM
Drives: 1995 volvo 850 turbo
i just bought a 95 volvo 850 turbo, thats overheating was told the thermostat was taken out and for whatever reason coolant is being pushed out of the coolant bottle after 15-20 minutes of driving. someone please help
some-beach!
post Mar 28 2009, 06:44 AM
Drives: '96 Jeep Cherokee Country ~ '98 Jaguar XJ6 ~ '96 Volvo 850 Turbo wagon Platinum Edition
QUOTE (kiakid2007 @ Mar 27 2009, 11:08 PM)
Check the thermostat. Perform a compression check. Sounds like you've got a blown head gasket (IMG:style_emoticons/default/sad.gif)
post Mar 29 2009, 10:47 PM
Expert Veteran
QUOTE (kiakid2007 @ Mar 28 2009, 12:08 PM)
KiaKid,
Is there a Lambda light (Check Engine Light, Malfunction Indicator Light)? If yes, read the codes first.
Is your fan kicking in at the right temperature? You may want to also check your ECT sensor - its located just underneath the thermostat cover. You cant miss it, its the only thing with cables jutting out from the back. Remove the thermostat (i usually use the "2-spanner cross technique" to achieve this, and inspect the sensor. Try cleaning the brass tip a little with a wire brush, especially if its covered with rust etc. Also inspect the cables to see if nothing is severed.
Acswitz
post Apr 8 2009, 02:31 PM
Drives: 740GL
So kiakid2007
I have the same thing going on.. and its losing fluid a bit everyday.. I think mine is a head gasket, but its getting back and forth to work right now.. just gets hot if I push on it and make the turbo work..
Just wondering what yours ended up being?
- note fan kicks in at what seems the right time and fluid is real small leak from back of engine some place above and to the right of the turbo.. cant quite tell, do you all agree that its probably the head gasket or is there something else up in there that could be leaking.. (<smile> looking for hope that its not a HG and I can fix it myself)
post Apr 8 2009, 08:22 PM
Expert Veteran
QUOTE (Acswitz @ Apr 9 2009, 03:31 AM)
So kiakid2007
Please check 2 things:-
1) How long ago have you had your thermostat checked? Boil some hot water and drop the thermostat in it, and see if it 'opens'.
2) At the back of the engine block is a small 2-inch rubber hose, the diametric size of your finger. No bigger than that. To get it, trace the coolant line form the expansion tank, down to the rubber hose, and to the metal pipe behind the engine block, and you will find it. This is FAMOUS for being ignored, given the location. See if you have traces or residues of white stuff (dried coolant) at the hose. If it look bad, change it anyway.
kiakid2007
post Apr 9 2009, 09:34 AM
no check engine light on and brand new thermostat and ect sensor its a little better but still pushing coolant out of the bottle. its gotta be exhaust in the cooling system building up pressure and forcing it out of the bottle
some-beach!
post Apr 9 2009, 10:22 AM
QUOTE (kiakid2007 @ Apr 9 2009, 10:34 AM)
A compression check will tell you.
If the cooling system is sealed, clear of restrictions or air pockets and functioning properly, then you know the problem.
kiakid2007
post Apr 9 2009, 11:44 AM
im havent done a compression test yet but im going to sears to buy a compression tester later today ill let you know what i find
post Apr 9 2009, 09:15 PM
Expert Veteran
Ah, too bad.
Anyway, let's hope for the best!
(IMG:style_emoticons/default/smile.gif)
kiakid2007
post Apr 18 2009, 12:11 PM
ok here we go
cylinder 1 120
cylinder 2 110
cylinder 3 130
cylinder 4 120
cylinder 5 120
dont know if that little bit will cause a problem or not please help
post Apr 19 2009, 08:01 AM
Expert Veteran
If you ask ME, i'm not going to worry too much about it. But then again, i've been accused of letting things to go really bad (like really bad) before i lift a finger about it.
And in my defence, if its a major item, let it die totally, before you put the big $$$$ into it.
Oil leak in the Turbo pipes
0 Nazih Mihamed 12 18th February 2017 - 02:40 PM
Last post by: Nazih Mihamed
No New Posts Volvo Is Dead
0 Matblowen 118 5th February 2017 - 08:23 AM
Last post by: Matblowen
No New Posts Topic has attachmentsVolvo Car Show Is Almost Here
Sunday, April 28 at the Davis Park, Davis California
2 GROM Audio 1,062 3rd February 2017 - 01:10 AM
Last post by: Stven
No New Posts Volvo 240 Bad Maf Sensor/oil In Vacuum Line
MAF sensor/oil in vacuum line
2 railkat 1,966 1st February 2017 - 07:28 PM
Last post by: Jan Berg
No New Posts Volvo Car Fault Codes List
1 igor2009 279 1st February 2017 - 11:26 AM
Last post by: ALineCanine
Time is now: 26th February 2017 - 11:28 PM
