> 440 Li Tempreture Gauge, 440 LI Tempreture Gauge
Norwich canary
post Feb 20 2009, 03:21 AM
Drives: volvo 440li
I have a 1994 1.8 440LI volvo. Abou 8 months ago i replaced radiator, water pump, thermostat and fan switch. All was fine. Recently my tempreture gauge has been going into red and the warning light comes on. However engine does not appear to be overheating. Replaced the tempreture sender unit on the front of the cylinder head and the gauge sensor on the back of the engine, Still going to red and warning light coming on. Car drives fine.
Can someone please help
grendel1960
post Feb 20 2009, 06:41 PM
my first guess would be thermostat, check, is the radiator getting warm, how warm are the hoses from thermostat to radiator, how hot are the hoses to the heater matrix - if you turn the heater on when it says its running hot, how hot is the air coming out, if its very hot then the temperature is high, leading to the thermostat as the main cause, if the radiator stays relatively cool, that would also point to the thermostat.
Grendel
inception
post Feb 23 2009, 03:38 AM
Drives: Volvo 460 95 2.0
I've heard that the temp gauge itself is subject to malfunction, you should take it out and ohm it. Should give 50 ohm on both fuel gauge and temp gauge. You should clean the brass nuts that acts as conections from the PCB to the gauge, they're a bit of a weak spot.
Clean them good and use some contact spray, refit carefully and see what happens! (IMG:style_emoticons/default/smile.gif)
Norwich canary
post Feb 24 2009, 07:05 AM
Drives: volvo 440li
QUOTE (inception @ Feb 23 2009, 08:38 AM)
I think it must be the gauge,Car happily drives, but gauge and red temp warning light saying car is over heating. Done 50 mile trip in the car all fine. for a few days gauge has been normal. now back to saying getting hot. Any ideas on how i get gauge out
inception
post Feb 24 2009, 07:45 AM
It should be some instructions around here. It's pretty much like in the haynes manual, but with some modifications.
BEFORE YOU DO THIS, DISCONNECT SPEEDO CABLE. It's at the rear of the block, all the way down there, and it has (atleast on mine) a protective silver hose, will make it easier to identify. Clean around the edges with some kind of thinner. Push it down while you pull the pin gently out, and cover the hole immediately, so that you don't get any dirt down there.
Back in the car:
1. Remove the plastic frame around the instrument panel. Should be pryed gently off somehow.. A friend of mine did that part, can't recall.
2. If you have left hand drive (like me), there will be two screws at the LEFT side of the instrument panel. Unscrew them!
3. Grab underneath the instrument panel module, pull it towards you while you push it to the LEFT. It's just tracked in place with some pins at the right side, will just slide out.
Disconnect the wires, disconnect the speedometer cable.
4. Take the whole thing out, and find the brass nuts and the bolts behind the temp and fuel gauge. Clean them, clean the bolts, use contact spray. Ohm the bolts, they should give you 50 ohm resistance.
Unfortuneately i don't remember the details in my head, but if you look around here or at volvoforums.org.uk's 400-section, there will be details!
Hope this helps!
No New Posts Gauge Problems On My Beloved 1994 940
Gas and Temp gauges are not working
1 DonnaLovesVolvos 59 27th February 2010 - 05:22 PM
Last post by: E$$volvo940
No New Posts 440 Stops Dead!
Intermittent problem- any suggestions?
2 hauxclaire 63 26th February 2010 - 12:38 PM
Last post by: hauxclaire
No New Posts Lights Won't Go Off.
Killing my battery.
1 talos1229 115 17th February 2010 - 01:04 PM
Last post by: vjck_uk
No New Posts 440 Gearbox Removal - Please Help Me!
Can't disengage drivers side driveshaft!
3 evansno1 217 9th February 2010 - 04:36 AM
Last post by: heavend
No New Posts Light Color Leather, How Tough To Keep Clean
4 lrdchaos 225 28th January 2010 - 01:17 PM
Last post by: roadbiker
Time is now: 19th March 2010 - 11:33 AM
