> S60 Smokes, Alot, Lots of troubleshooting done already
speeder2000
post Sep 28 2008, 11:32 AM
Drives: 2002 Volvo S60 2.4t
Trying to troubleshoot a 2002 S60 with 2.4t (us made), 130k thousand miles
Car used to smoke a bit sometimes on startup, also you'd get a low oil light sometimes (i guess from the oil sump seals), one day it started smoking a lot and making a ton of weird noises - all pointed to turbo
took the turbo out, it was done. one bearing was cracked, the hot side piston seal was totally worn out and the piston ring wouldn't even hold. Got parts from a similar TD04HL-13T, a rebuild kit, and combined the 2 to put together a solid turbo (it is not professionally balanced, but still)
Put the turbo back in the car, refilled coolant. Started car - it heats up and smokes lightly - giving it gas yeilds in billowing smoke out of the tailpipe, white, no obvious smell. Drove around - same ***. Some coolant also disappeared - now I am not sure if it is disappearing or if there was air since alot of it came out with removing turbo lines.
I also at some point did a compression test on a COLD engine, and it was all within spec (even though on a cold engine, the compression should be lower since the piston rings aren't sealing) so I don't know....
History of the car: I don't know what was replaced or not replaced. I replaced the timing belt myself, don't know anything else, really.
Edit: also, the engine is very gunky... There is stuff baked on the oil fill baffle for example.
Edit2: Coolant looks clean, Oil looks clean (ie no mixing)
Thoughs?
islandS60Owner
post Oct 4 2008, 03:02 PM
Drives: 2001 S60
You might want to check your air flow sensor. This can make the exhaust smoke, although the smoke won't smell like burning oil.
raydar
post Oct 5 2008, 05:10 PM
Drives: 2007 s80 d5
could just be oil deposited in intercooler being burnt off and eventually will clear or could be further damage to engine has occured. (presuming smoke is white)
No New Posts Topic has attachmentsS60r Tranny Leak
coming from the AWD unit
5 Doogwhan 149 20th December 2008 - 09:28 PM
Last post by: S60 R
No New Posts S60 Hid Bulb Temps?
1 ItzHerz 34 13th December 2008 - 11:14 AM
Last post by: S60 R
No New Posts S60 Premium Sound System?
0 ItzHerz 19 10th December 2008 - 10:14 AM
Last post by: ItzHerz
No New Posts S60r Photosynth Attempt
I don't think the R ever looked so good...
3 Doogwhan 92 24th November 2008 - 04:33 PM
No New Posts S60 Headlight Issue - Why Do They Burn Out So Frequently?
3 clashed 118 22nd November 2008 - 05:14 PM
Last post by: raydar
Time is now: 9th January 2009 - 08:12 AM
