> E-code Headlights Fast Blinker, My turn signals blink rapidly
braddunagan
post Sep 22 2008, 03:24 PM
Drives: 1987 240 GL
Well I finally broke down and purchased the complete E-Code light and signal setup off eBay. It was a simple install and was completed in about two hours. Now my turn signals blink super fast and i am not sure why? I have checked everything. All connections appear good. All grounds appear good. All bulbs are working. Any thoughs as to why this is doing this?
IceBrick
post Sep 23 2008, 06:42 AM
Drives: 91 240, 98S70
Are you sure that your front signals are really blinking...if only one signal lamp blinks, it blinks fast. I can't off hand remember what wires I switched, but when I installed my e-codes I rewired the marker/signal connector to get power to the proper bulb. I will check my connectors this evening and post, or if you have a wiring diagram, trace the circuit at the signal bulb.
braddunagan
post Sep 25 2008, 09:26 AM
Drives: 1987 240 GL
The bulbs up front are blinking. I am not sure if it is the correct bulbs but I have blinkers on all four corners. They just blink too fast.
240on280
post Sep 25 2008, 09:41 AM
Are both front and rear blinking? It could be a bad ground wire.
braddunagan
post Sep 25 2008, 11:20 AM
Drives: 1987 240 GL
I just said I have blinkers on all four corners. Not trying to sound rude but my blinkers worked fine until I changed the front. The rear shouldn't have changed by swapping out the front.
IceBrick
post Sep 25 2008, 04:51 PM
QUOTE(IceBrick @ Sep 23 2008, 06:42 AM)
[right][snapback]92387[/snapback][/right]
Here is a pic of the way the connector had to be rewired to work properly. Good luck.
(IMG:http://i142.photobucket.com/albums/r111/icebrick/DSCF1737.jpg)
post Sep 25 2008, 10:56 PM
I'll bet that the 'new' bulbs are a different wattage, and the car has a thermal flasher can, rather than a relay type (which are constant rate, and load independent). Thermal cans are good because they're cheap AND they change rate if a globe blows/bad connection occurs. So you KNOW when the indicators are faulty!!!!! They are marked with the correct wattages they are designed to work with. Not the best for towing tho'.
No New Posts Fastest Engine For 240
9 duffy 298 16th November 2008 - 05:02 AM
Last post by: I have a nut leftover
No New Posts Headlights For 245 Series
8 Striper15 64 11th November 2008 - 08:06 PM
Last post by: Striper15
No New Posts Topic has attachmentsHeadlights Project At An Angle?
2 Frankie_lucky2002 115 29th October 2008 - 12:28 AM
Last post by: Frankie_lucky2002
No New Posts Fastest!
16 seanmc87 384 14th August 2008 - 04:17 PM
No New Posts Headlights Interchange?
2 gapimpin 117 11th March 2008 - 09:28 AM
Last post by: gapimpin
Time is now: 21st November 2008 - 09:55 AM
