> Won't Shift Out Of Fist Gear When Cold, 740 GLE automatic transmission
widewilbur
post Sep 18 2008, 07:23 PM
Drives: 1990 740gle
I have a 1990 740 GLE wagon with an automatic transmission. It has started having a problem shifting out of 1st gear when the shifter is in drive. It is only when it has been sitting for a while. It appears that it is when the car is cold. If you drive it for a few minutes in drive, eventually it shifts. Once it makes the first shift, then it is fine and it will always shift normally until the next time you stop for a while. The transmission does not slip or anything else abnormal. Fluid is at the full mark. I have bought a transmission filter and a gasket and will be changing them this weekend. Any other ideas would be appreciated.
post Sep 21 2008, 10:58 PM
QUOTE(widewilbur @ Sep 19 2008, 08:23 AM)
...Fluid is at the full mark...
[right][snapback]92050[/snapback][/right]
Fluid colour?
Anyway, moved to the 740 Forum for better response.
Cheers,and Good Luck!
post Sep 26 2008, 04:38 PM
is it exactly at the full mark or is it over? i had no end of problems with mine, and it was over full, so i drained some out so it was just under and it was fine and behaved.
+1 with the colour, if its dark and brown then its burnt, you will need to replace it, if its pinky coloured then it should be fine.
widewilbur
post Sep 29 2008, 05:57 PM
Drives: 1990 740gle
I pulled the pan off of the transmission and replaced the filter (did not look plugged). Filter is probably a generous statement, it is really just a screen.The fluid that I drained out did not look or smell burned. I replaced the fluid and installed a pint of Sea Foam Transmission Cure. I've run the car about 100 miles since then, and I still have the same problem. Fluid is not over filled. It seems to be more of a problem when the car is cold. It is just refuses to make that first shift after the car has set awhile. Once it is driven around a bit and warms up? and makes the first 1 - 2 shift, it shifts just fine. There is no slippage and everything else seems to be just fine in the transmissions actions.
Any other ideas?
No New Posts Cold Weather And Auto Transmission Performance
my autobox is acting grumpy below freezing...
1 woodsytf 6 Today, 04:13 AM
No New Posts Shifter Sticking
0 tarollio 7 Yesterday, 04:25 PM
Last post by: tarollio
No New Posts Gear Selector Bulb
7 tlaws14 41 19th November 2008 - 09:57 PM
No New Posts Gearbox Oil?
0 440 bloke 2 19th November 2008 - 04:43 PM
Last post by: 440 bloke
No New Posts Cold Weather And When Heat On
0 jonaix 13 13th November 2008 - 11:03 AM
Last post by: jonaix
Time is now: 21st November 2008 - 09:27 AM
