> What Have I Done Wrong, Pls?
post Sep 18 2008, 02:26 AM
B230F-top dead centre No#1, dizzy at No#1 slightly advanced,, red dots on cam sprocket and cover lined up-cam at natural stop point. Motor won't fire. Seems to have compression and spark-I may have flooded it-I'll leave it til tomorrow, charge the battery, and see if it'll fire.
Have I timed it properly is all I want to know for now?
BTW, I have a new radiator, with the electric fan thermal switch hole. There is an O ring and a plug, and a long black plastic tie-how do I fit the bung, since the tie won't allow fitting the bung (no tie holes, just 2 rear notches, wrap around doesn't fit either.) from inside the radiator and pulling thru'? I doubt it'll hold other way round. I don't plan on using the switch, as I'm told it's only aval. OEM== $$. The original rad didn't have this stuff. It's been a weeks' work to get to here, working between the the rains, and pains in my body. Now I'm tired & broke, & it doesn't want to go.---yet.
IceBrick
post Sep 18 2008, 11:03 AM
Drives: 91 240, 98S70
Here is a link to check your work against. I plan to change my cam belt in the next few days and plan to use this diagram
Turbo Member Post
..Don't know about the bung...post a pic?
nice86
post Sep 18 2008, 11:42 AM
Drives: 1986 Volvo 245
It's important for #1 piston to be at TDC on the compression stroke. Make sure it's compression.
What radiator do you have. Nissen?
post Sep 18 2008, 05:44 PM
Thanks for the pics. RE-crank mark-is that TDC? I obviously had that wrong, as when I assembled it the notch was vertical. Fortunately, It's not a big fix.--detension belts, remove front pulley. BTW My front crank pulley has no timing pin, it May have fallen out, but it sure ain't there-matters only if you're checking sparks I guess..... If cam markers are correct, It will have to be right there, but I think my crank is advanced somewhat. Anyone with a pic or a crank to check if timing keyway is at TDC No#1-they usually are, but maybe......
post Sep 18 2008, 09:05 PM
Got it right & to run briefly, with just cam belt on & no water, (very quiet!) but after re-assembling the other belts it won't start-suspect flat battery, OR (worst case) a modifying wire from AMM to the EMU was too close to the HT lead from the coil, & something is well fried. Cam belt ran with overhang on front of sprockets- very disturbing. New belt too. Odd warning lamp pattern on startup-something isn't right no oil lamp, alt works, p brake on, buzzer, but no seat belt light. That's all. Has been sitting for abt 1 mth. Someone was in car last night, I hope they weren't malicious. Perhaps water leak in car, as carpet damp next to "clutch" area [RHD] & I disturbed the water gallery pipe along the motor. I haven't replaced the hoses, just yet, & I'll hold back the coolant until I'm sure there's no leaks. I did fit a good used aircon pump (R134A), but haven't spun it yet. Battery on charge for a few hours, then I'll try again. Bung installed: smaller end inwards, largest end outwards, (smallest- shank) central in O ring. I hope it doesn't pop out. Could have reversed it IFF I could grip it and pull it into place from inside the radiator. No holes for pull string, too big for cable tie (supplied) around back & Pull. Radiator made in Oz I believe, can't remember to be sure, did have Volvo looking numbers on it tho', rather than Nissan. [VO prefix].
post Sep 21 2008, 06:31 PM
She's fixed! That leaves the motor mounts, the aircon recharge, the gearbox and the back axle to be sorted. Thanks to all contributors. Very quiet now-much better.
No New Posts Topic has attachmentsWhat I Use...
are probably not the best...
14 ampangbear2 25 Yesterday, 02:35 AM
Last post by: ampangbear2
No New Posts Topic has attachmentsWhat's Up! New Guy With S80! (pics)
4 Torque 204 11th November 2008 - 04:02 PM
Last post by: Torque
No New Posts What Is Normal Gas Mileage
For 1998 s70 t5
6 volvosb 367 6th November 2008 - 04:44 PM
No New Posts Have You Been To "c30 World"
1 C30Grant 80 3rd November 2008 - 01:18 AM
Last post by: S60 R
No New Posts Topic has attachmentsWhat Is This Switch For?
Never used in all the years............
7 sargesvs 141 2nd November 2008 - 02:16 AM
Last post by: Doogwhan
Time is now: 21st November 2008 - 09:21 AM
