> 92 Volvo 240, Brake lights
92volvoguy
post Sep 13 2008, 07:26 PM
Drives: 92 volvo 240 wagon
92 volvo 240 wagon brake lights do not work. Switch is good bulbs are good the bulb out light is on. Could it be the bulb failure sensor,can you test it? Or something else? Any suggestions would be appreciated!
post Sep 14 2008, 01:06 AM
bad bulbholders, corrosion-common prob. replace seems best option.
sargesvs
post Sep 14 2008, 11:19 AM
Drives: 1992 Volvo 240
QUOTE(92volvoguy @ Sep 13 2008, 08:26 PM)
[right][snapback]91679[/snapback][/right]
Just went through the same problem. The bulb warning sensor is about 150 bucks at the dealer, or you can just bypass it.(I later found used ones on ebay for 15 bucks) I actually wrote down color of wires and what the come from/go to if you are interested. Of course, if you loose a light, you won't know until someone tells you...........This will allow you to use a simple 12 volt tester(a light bulb tester). Also, you can tell right away if it's cooked good by smelling it. Mine was crispy in the inside, and smelled horrible.............
92volvoguy
post Sep 14 2008, 11:46 AM
Thanks for the info took mine apart yesterday smells fine. The bypass sounds fine to me if you would give me the info. I think that the blue/red wire comes from the switch and further investigation tells me that the two yellow wires nexed in sequence clockwise are the feeds for the brakelights. The bypass info would be helpful.
sargesvs
post Sep 14 2008, 03:53 PM
OK, heres what I have:
Thick Gray to thick blue wires(one to two)............................Headlights
White to red(one to one)..........................................................Turn signal
Grey to Brown/White(one to one).............................................Turn Signal
Blue/red to yellow, yellow/grey, brown/black(one to three)..........3 brake lights
Hope this helps. I didn't rip my plug off, but found some suitable pins at radioshack, and jumpered that way in case I decide to pull one at a yard
HAVE FUN
jpjpurcell33
post Oct 23 2008, 02:39 PM
Drives: 1987 Volvo 240 GL Wagon
I have the same problem. Where is the bulb failure sensor located on the vehicle?
92volvoguy
post Oct 23 2008, 09:46 PM
the bulb out sensor is located beheind the lower dash remove it and it is on the left side of the steering wheel a round (mine is red) sensor with i think 9 wires
jpjpurcell33
post Oct 24 2008, 09:00 AM
Does the whole dash board need to be removed to access the sensor?
post Oct 24 2008, 09:24 AM
QUOTE(,Oct 23 2008, 07:46 PM)
[right][snapback]94626[/snapback][/right]
No. If you look up (under) the dash you'll see it. They are expensive new so I would replace it with a cheap used one.
nice86
post Oct 24 2008, 11:31 AM
Drives: 1986 Volvo 245
jpj, remove the fiber panel above the driver's legs. The BFWS should be to the left of the steering column. Fat, round, red one.
No New Posts Topic has attachmentsVolvo Fun
Papercraft
19 xpiecemealx 111 Yesterday, 08:13 PM
No New Posts 92 960 Sunroof Leaking
1 yamarx1 17 1st December 2008 - 04:08 PM
I'm new
10 sfpacman 135 1st December 2008 - 03:56 PM
5 panthertracy 199 30th November 2008 - 06:49 PM
Last post by: Burgess kab
No New Posts Topic has attachmentsVolvo Oil Filter
Authentic or Fake?
11 ampangbear2 71 28th November 2008 - 05:07 AM
Time is now: 4th December 2008 - 02:38 PM
