> 96 Volvo 850glt A/c, A/C does not work...
hoit666
post Sep 5 2008, 08:55 PM
Drives: 96 850 glt
When i purchased my car (96 850 GLT) the A/c worked, which was about 10 months ago... didnt try using it again until after winter, now it doesnt work, it can be a tiny bit cooler than outside air is, by a degree or two intermittently.
when i start the car the two red dots on the A/C and heater button blink for a minute or two... is this normal? whenever the heater or A/C is on there is a loud click in the engine every minute or so, kindof like the sound of a breaker from an electrical box when you turn it off or on. What could this be? could this be the problem?
thanks alot for any help or advice
sincerily,
A man to fix his A/C just in time for winter :P
swedseed850
post Sep 5 2008, 09:16 PM
Drives: 1994 volvo 850 turbo
well, first of all, you must have warm winters! anyhow, the ac control box is going out. the blinking lights is showing faults in your control box. First off, recharge your ac system, the clicks you hear under the hood is the compressor. it has a clutch that ingages to "compress" the freon in your system, it helps to make it colder and without it, no ac at all. now, if you have access to a replacement ac/heat control box the you can take the box out of the dash, like a radio, matter of fact take the radio out, reach under the ac box, pull towards you, wala, its out, now look on the back of the box you should see the green connectors, unplug them, plug in the replacement box. go thru the motions with the controls, see ifyou get the same performance. some of the ac boxes go bad at times, they short out on the boards. simple replacement, about 50 to 75 dollars used, 165 to 350 new. :haha:
i had this issue last year, i ran without ac during a 100+ hot summer, then had to go without heat. but if you plugged in a good control box you could set the system on the desired temp and it would setup to run, then i plugged up the old one and used the good fan control. i know dumb move, but i had other intrest.
just try that, and im goin to shut up now. :clap:
good luck! :57:
hoit666
post Sep 5 2008, 09:40 PM
Drives: 96 850 glt
awesome easy enough, thank you kind sir...
thanks again sincerily,
swedseed850
post Sep 5 2008, 10:37 PM
glad to help! anytime! :57:
woodsytf
post Sep 6 2008, 06:53 AM
Drives: 1995 Volvo 850 Wagon
i found this text doc when is a trouble shooting my 850 A/C issue.
lots of info and diagnostics...
good luck!
Attached File  Volvo_850_CRUISE_CONTROL_SYSTEM.pdf ( 46.11K ) Number of downloads: 21
swedseed850
post Sep 6 2008, 01:29 PM
that didnt say anything about the A/C control unit. yes, the ac is vac assisted, but, when that board burns out you will smell that sweet electrical fume, then you will not have complete control of the ac/heat. once the lights start to blink its a indication that the ac/heat will go into default, only producing defrost settings.SELF-DIAGNOSTICS
The Electronic Climate Control (ECC) control module can
detect faults in the system and store Diagnostic Trouble Codes (DTCs).
If a fault is present, system informs driver by flashing AC OFF and
REC switch LEDs for 20 seconds.
A fault warning is given when a fault is discovered or
present each time ignition is turned on or engine started. DTCs will
remain stored until cleared by an input code.
NOTE: Test Unit (981 3190) and Adapter (981 3194) are required for
DTC diagnosis. The Volvo Diagnostic Key (998 8670) may be
used to perform self-diagnostics. Follow tool manufacturer’s
instructions.
There are 3 different test modes/settings which can be
selected for reading off DTCs. TEST MODE 1 may be used for reading off
DTCs detected by control unit (up to 47 codes can be stored). TEST
MODE 2 checks signals from speedometer and solar sensor.
TEST MODE 4 is used to check electrical circuits in A/C
system, reset information on damper motor limit positions and change
data transmission speed from ECC control module to on-board diagnostic
unit.
NOTE: Ignition must be turned off before switching from one test
mode to another.
ENTERING SELF-DIAGNOSTICS
1) Connect selector cable from diagnostic unit "A" to
terminal No. 1 of diagnostic unit "B", located behind right headlight.
See Fig. 2.
2) Turn ignition on. LED on diagnostic unit "A" should start
flashing. Each DTC (3-digits) consists of a series of flashes with a
short break between each series. DTCs are displayed in ascending
order. See AUTOMATIC A/C-HEATER SYSTEM DIAGNOSTIC TROUBLE CODES table.
Fig. 2: Identifying Diagnostic Units
Courtesy of Volvo Cars of North America.
Code # Condition/Affected Circuit
1-1-1 ..................... No Fault Found By Diagnostic System
1-2-1 .......... Outside Temp. Sensor Circuit Shorted To Ground
1-2-2 .................................... Outside Temp. Sensor
Circuit Open Or Shorted To Power
1-2-3 .... Driver’s Side Temp. Sensor Circuit Shorted To Ground
1-2-4 .............................. Driver’s Side Temp. Sensor
1-2-5 ....... Pass. Side Temp. Sensor Circuit Shorted To Ground
1-2-6 ................................. Pass. Side Temp. Sensor
1-3-1 ....... Driver’s Side Duct Temp. Sensor Shorted To Ground
1-3-2 ......................... Driver’s Side Duct Temp. Sensor
1-3-3 .......... Pass. Side Duct Temp. Sensor Shorted To Ground
1-3-4 ............................ Pass. Side Duct Temp. Sensor
1-3-5 ........................ No Engine Temp. Frequency Signal
1-4-1 ........ Driver’s Side Temp. Switch Faulty Control Signal
1-4-3 ........... Pass. Side Temp. Switch Faulty Control Signal
1-4-5 ........... Air Distribution Switch Faulty Control Signal
1-5-1 ..... Fan Speed Sensor Control Signal Missing Or Too High
1-5-2 ....... Fan Speed Sensor Control Signal Shorted to Ground
2-1-1 .............. Driver’s Side Damper Motor Position Sensor
2-1-2 .............. Driver’s Side Damper Motor Position Sensor
Shorted To Ground
2-2-1 ................. Pass. Side Damper Motor Position Sensor
2-2-2 ................. Pass. Side Damper Motor Position Sensor
Shorted To Ground
2-3-1 ................ Ventilation Damper Motor Position Sensor
2-3-2 ................ Ventilation Damper Motor Position Sensor
Shorted To Ground
2-3-3 .............. Floor/Defrost Damper Motor Position Sensor
Circuit Open Or Short To Power
2-3-4 .............. Floor/Defrost Damper Motor Position Sensor
Shorted To Ground
2-3-5 .............. Recirculation Damper Motor Position Sensor
2-3-6 ..................... Recirculation Damper Motor Position
3-1-1 ... Driver’s Side Damper Motor Shorted To Ground Or Power
3-1-2 ...... Pass. Side Damper Motor Shorted To Ground Or Power
3-1-3 ..... Ventilation Damper Motor Shorted To Ground Or Power
3-1-4 ... Floor/Defrost Damper Motor Shorted To Ground Or Power
3-1-5 ... Recirculation Damper Motor Shorted To Ground Or Power
3-2-1 .............. Driver’s Side Damper Motor Active Too Long
3-2-2 ................. Pass. Side Damper Motor Active Too Long
3-2-3 ................ Ventilation Damper Motor Active Too Long
3-2-4 .............. Floor/Defrost Damper Motor Active Too Long
3-2-5 .............. Recirculation Damper Motor Active Too Long
4-1-1 ......... Pass. Compartment Fan Overcurrent Or Seized Fan
4-1-2 .............................. Driver’s Side Temp. Sensor
Intake Fan Shorted To Ground
4-1-3 .............................. Driver’s Side Temp. Sensor
Intake Fan, No Control Voltage
4-1-4 ............ Driver’s Side Temp. Sensor Intake Fan Seized
4-1-5 .... Pass. Side Temp. Sensor Intake Fan Shorted To Ground
4-1-6 .. Pass. Side Temp. Sensor Intake Fan, No Control Voltage
4-1-7 ............... Pass. Side Temp. Sensor Intake Fan Seized
4-1-8 .................... No Control Signal To ECC Power Stage
4-1-9 ....... ECC Power Stage Emitting Faulty Diagnostic Signal
4-2-0 ................ ECC Control Module Fault, Program Memory
5-1-1 ......................... Self-Adjustment Of Damper Motor
Limit Positions Not Carried Out
TEST MODE 1
1) Turn ignition on. Press button on diagnostic unit "A" for
about one second. Read LED flashes. If LED does not illuminate, go to
ON-BOARD DIAGNOSTIC UNIT CHECK under TESTING.
2) If LED flashes DTC 1-1-1, no faults are stored. If LED
flashes other than DTC 1-1-1, display DTCs and perform appropriate DTC
trouble shooting. To erase code, see ERASING CODES.
TEST MODE 2
twice (for about one second each time). LED should start flashing
rapidly once TEST MODE 2 is activated. If LED does not start flashing
rapidly after button is pressed, go to ON-BOARD DIAGNOSTIC UNIT CHECK
under TESTING.
2) If LED flashes DTC 1-1-2, signal from solar sensor is
okay. If LED flashes DTC 1-1-3, signal from speedometer is okay. If
neither DTC is present, go to next step.
3) If DTC 1-1-2 is not present, check solar sensor. Go to
SOLAR SENSOR under TESTING. If DTC 1-1-3 is not present, check speed
sensor signal. Go to SPEEDOMETER SIGNAL under TESTING. To exit TEST
MODE 2, turn ignition off.
TEST MODE 4
1) Turn ignition on. Press button on diagnostic unit "A" 4
times (for about one second each time). LED should illuminate. If LED
illuminates, go to next step. If LED does not illuminate, go to
2) Control codes must be entered one step at a time. See
TEST MODE 4 CONTROL CODES table. LED should go off after each digit is
entered. Entering each digit in a code must be made within 4 seconds,
as failure to do so will abort input and TEST MODE 4 must be
restarted.
C��o��d��e�� �� �� �� �� �� �� �� �� �� �� �� �� �� �� �� �� �� �� �� �� �� �� �� �� �� �� �� �� �� �� �� �� �� �� �� �� �� �� �� �� �� �� �� �� �� �� �� �� �� �� �� ��T��e��s��t��
1-1-1 .............................. Controlling A/C Relay
3-1-1 ................................... (1) Normal Speed
3-1-2 ....................................... (1) X2 Speed
3-1-3 .................................. (1) (2) X10 Speed
9-9-9 ................................. Self-Adjustment Of
Damper Motor Limit Positions
(1) - Changes data transmission speed/rate from ECC control
module to on-board diagnostic unit.
(2) - Used only with Volvo Diagnostic Key (998 8670).
Enter control code 1-1-1 by pressing button on diagnostic
unit 3 times, with a short pause in between to allow LED to come on
again. ECC control module will now switch A/C relay on and off 5 times
(10 seconds on, 10 seconds off), switch A/C compressor on and off, and
turn control panel A/C indicator on and off. If A/C relay does not
respond as indicated, check A/C relay. See A/C RELAY CHECK under
TESTING.
Self-Adjustment Of Damper Motor Limit Positions
1) Turn ignition on. Place fan (blower motor) lever in manual
mode. Turn function selector to AUT (automatic). Ensure system is in
TEST MODE 4.
2) Enter control code 9-9-9 by pressing button on diagnostic
unit 9 times in quick succession. Enter each of the 9 series 3 times,
with a short pause in-between to allow LED to come on again. ECC
control module is now ready to adjust damper motor limit positions
automatically.
3) Wait about 10 seconds for fan to start. Turn ignition off
to exit TEST MODE 4. Turn ignition on. AC OFF and REC indicator on A/C
control panel should flash. Drive car for a few minutes at speeds
greater than 20 MPH.
4) Stop car and turn engine off, but leave ignition on for at
least 2 minutes to enable ECC control module to store all values.
Start TEST MODE 1 and record DTCs. If DTC 1-1-1 appears, selfadjustment
is complete. If DTC 5-1-1 appears, self-adjustment is not
complete.
Changing Data Transmission Speed/Rate From ECC Control Module
To On-Board Diagnostic Unit
Enter desired control code (3-1-1 or 3-1-2) by pressing
button on diagnostic unit "A", with a short pause in-between to allow
LED to come on again. System always starts at normal speed unless
another option is selected. If another option was selected, system
will revert to normal speed each time ignition is turned off.
ERASING CODES
1) All codes must be displayed at least once before they can
be erased. To erase codes, ensure selector cable is connected to
terminal No. 1 of diagnostic unit "B". See Fig. 2. Press and hold
diagnostic button for at least 5 seconds. LED should illuminate 3
seconds after button is released.
2) Press and hold diagnostic button for a minimum of 5
seconds more. When button is released, LED should go out. Ensure codes
have been erased by pressing diagnostic button once. If display shows
1-1-1, codes have been erased/cleared. If a DTC will not erase/clear,
perform that particular code’s diagnosis again.
swedseed850
post Sep 6 2008, 01:32 PM
now you see why i just told him to get a replacement box? :haha:
No New Posts Volvo Coolant
where to buy
1 volvolover 246 19th November 2008 - 01:47 AM
volvo s 40 emission class
0 krlegorky 7 18th November 2008 - 12:17 PM
Last post by: krlegorky
Last post by: Matt Cramer
Strut mount bushings broken?
6 PrimerTC 257 12th November 2008 - 12:29 AM
Last post by: Dale71
I'm new
7 sfpacman 86 10th November 2008 - 04:51 PM
Time is now: 22nd November 2008 - 05:31 AM
