> Timing Belt Change
Volvitup
post Sep 4 2008, 01:46 PM
Drives: 1987 240 DL
Hi, my timing belt recently broke and I am going to change it myself. The guys at Kragen said that I should replace the water pump when i'm in there. Is this necessary?
Volvitup
post Sep 4 2008, 02:58 PM
Drives: 1987 240 DL
Also I keep reading that my valves will not have been damaged, but I see in the Chilton manual as well as the parts database at Kragen that it is an interference engine. I did try to crank the engine over after th belt broke, will my engine be ok?
I have an 87 240 DL.
nice86
post Sep 4 2008, 04:26 PM
Drives: 1986 Volvo 245
The B230F is a non-interference engine.
I would not change the water pump unless it was leaking or noisy.
post Sep 4 2008, 05:41 PM
Also see:
http://www.volvo-forums.com/t23328-timing-belt.htm
Its not necessary to replace the pump, but you might consider changing the tensioner and seals if they are leaking.
post Sep 4 2008, 06:46 PM
if pump is old, now is a good time, as you'll have the same work to do again just to get at it. It's cheap insurance IMO. Mine looks old, not leaking, but I'm replacing it now with my new radiator so I prevent later troubles. I live in a climbate of extremes-from very hot (>40deg C for at least 3 consecutive weeks) to nearly freezing for 6 weeks. it's not wise to wait until it starts leaking to replace it, as the consequences of lost coolant are significant if you're not one to watch your gauges. (Most of us don't.) My thermostat was reasonably ok, but my housing was not the best, so I'm slowly doing the job. new radiator hoses are a wise fitting. I'll also replace the front main seal and the cam seals which are leaking at this time, and the aircon pump & rubber mounts which are all dead. A new dryer will be mandatory as I'm changing gases. Soon, I'll have the transmission out and I'll fit a ear main seal & a reconned T50 man 5 speed Toyota box. It should handle all the power and torque I use, and get me better mileage. I'll prob use a manual bellhousing from a B20, or B23, and adapt it, as that will be cheaper than buying a new custom housing (~$500-) and shipping it here (3,000mi, $200-). a manual B230 housing/M47 is just too rare & $$ to get from a wrecker, and they're prob. cactus anyway. I'll replace cam belt and tensioner as needed-they are overdue, unless they've been done recently. I was encouraged by the good thermostat.
jsinton
post Sep 5 2008, 09:25 AM
Drives: Volvo 240
My Gates brochure indicates that these are interference motors.
http://www.gates.com/brochure.cfm?brochure...ocation_id=3487
I wouldn't change the water pump unless it's leaking or noisy... It's just too damn easy to do. You don't have to pull the timing belt when you do the water pump.
If you broke the timing belt, there's a good chance you didn't ruin the motor, but the only way to be sure is to put a new timing belt on and try it.
post Sep 5 2008, 10:39 AM
Many different engine/cam profiles existed any given year, all around the world. A B230F which Volvo calls the "USA version" is a non-interference engine.
No New Posts Change Cupholder In 2003 S60
0 gilbreen 11 18th November 2008 - 06:42 PM
Last post by: gilbreen
No New Posts Timing Belt Help
p0012 after new belt
5 mikehenya 171 24th October 2008 - 06:40 AM
Last post by: Pentheos
No New Posts Timing Belt Snapped
**** belt snapped!!!!
1 jonvolvo440/2.0 175 16th October 2008 - 04:40 PM
Last post by: bkf_uk
No New Posts Timing Belt Replacement
850 turbo 1996 wagon
6 vcar 333 8th October 2008 - 10:27 PM
Last post by: Volgrrr
No New Posts Belt Woes
There's a trick to this I need to know w
4 Tinkerbell 110 21st September 2008 - 06:05 PM
Last post by: manxman
Time is now: 22nd November 2008 - 08:17 AM
