> Uh Oh Long Crank, driveability issues 1990 Volvo 240
Greek73
post Aug 25 2008, 02:41 PM
Drives: 1990 Volvo 240 DL
I have a 1990 Volvo 240. I just purchased it this month. When I start it cold or hot, it cranks for a while. The only way to get it to start, is to give it just a little gas. I know with fuel injection, you shouldn't touch the accelerator while starting, but that is the only way it starts. Is this the long crank problem that signifies that i need a new fuel pump?
It also runs just a little rough when first started. it clears up in seconds.
post Aug 25 2008, 03:45 PM
Status: Online
I would look for split vacuum lines and leaks. Also look for holes in the large hose that goes from the throttle body to the air mass meter. Clean the throttle body - especially where the plate closes against the inside of the housing - usually their will be a build-up of nasty stuff in it.
My car has had both pumps and filter replaced, decent tune-up, etc - and it still has to be cranked for a second or two before it will run, unlike other fuel injected cars that start instantly.
One that I haven't tried yet is cleaning the idle control valve, I'm hoping doing so will help a little.
post Aug 25 2008, 06:38 PM
Status: Online
Check your fuel pressure with a guage-36psi at injector gallery. Old regulators can cause trouble-check your fuel mileage if you can, it will indicate fuel probs.if excessive.
Greek73
post Aug 26 2008, 08:15 AM
what kind of mileage should I be getting?
post Aug 26 2008, 09:52 AM
Status: Online
I average around 25 mpg.
volvoyankee
post Aug 26 2008, 12:45 PM
Drives: 89 240 estate 93 240 volvo classic wagon
My 89 245 has a long crank too, plus when it starts I have to keep my foot on the gas or it will die.after a bit it idles quieter than my 93.Is this a vac hose or fuel pump prob?
post Aug 26 2008, 07:45 PM
Status: Online
Vacuum/fuel prob? either, can't tell without further data. you'll have to look and measure.
Greek73
post Sep 2 2008, 11:25 AM
I used some Thottle Body cleaner and cleaned out the TB. It was not really that bad -- not even half as bad as my Ford Expedtion with is 11 years newer and has fewer miles. But, it does seem to start a little easier. I took it on a trip this weekend. I drove it about 650 miles and I got 26.3 mpg driving at 70-75. So, I am very pleased with the mileage.
post Sep 2 2008, 07:54 PM
Status: Online
Well, I guess it has to be decided what a 'long crank' really is. Mine takes a second or two too, but I'm not concerned by that, if it took 20 secs regularly, then I'd be much more worried. V's seem not to start 'immediately', so I might not panic just yet, if I were you. Perfection in the automotive world, is non- existent-ultimately, everything is a compromise between ideals and cost, and some things are just there to keep the dealers' cash registers ticking. Sorry, but it's so, & it makes me mad as hell too. I don't have the resources to build it myself, so I have to put up with other peoples' ideas of what makes a good car. As yet, none have been perfect. Some have been suitable. The present is adequate to the requirements-if expensive to run and repair.
Rob_245
post Sep 3 2008, 02:17 AM
Drives: '65 122S / '92 245GLE / '02 V70D5
I experienced the same problems (long cranking) and I did do the following:
- new sparkplugs
- new ignition wires / Coil wire
- new distributor cap
- new rotor
- Cleaned the throttle body (took it out)
and never had crank-problem anymore.
(used orignal Volvo-parts).
post Sep 3 2008, 11:11 AM
Status: Online
By design, an LH V must rotate at least 300 degrees before it can fire, and possibly much more.
No New Posts Oh .. My .. God.
fuel economy
7 pandamonium 353 13th November 2008 - 03:18 PM
Last post by: inception
No New Posts Long Crank/rough Running Problems
240 advice
4 Greek73 48 7th November 2008 - 10:18 AM
Last post by: robert240
No New Posts Crankshaft Pos Sensor Fault P0336
1996 / 850Turbo
5 Alextoo 150 17th October 2008 - 06:12 PM
Last post by: swedseed850
No New Posts Crank, Crank, Crank, Buzzzzzzzzzzz
Starter Dead?
4 sargesvs 97 27th September 2008 - 05:58 PM
Last post by: sargesvs
No New Posts Long Time Volvo Owner And Volvo-forums Noob
2 garlinto 30 9th September 2008 - 09:25 PM
Time is now: 22nd November 2008 - 12:51 AM
