> No Spark, Engien Turns Over But Not On, not turning on
jlucas85
post Aug 24 2008, 11:44 PM
Drives: 1995 volvo gtl 850
just bought a 1995 gtl 850, when i got it i had a problem with the mas air flow sensor, there was white smoke coming out of the exaughst and it made my car reek of gas so i changed it and the white smoke stopped. the next day i brought it to aamco to have a oil leak checked out. turns out it was some oil sensor on the block it had broken loose and oil was coming out pretty decently, they got a new one and fixed that problem. when i went to pick it up i was told that they went to start it up and the car wouldnt turn on. and that there was no spark at the plugs, they diagnosted it and told me it was my ignition coil and plug wires.
now that i ve sunk 600 bucks into it it still wont start. im trying not to get angry with the techs there, they ve gone through and deturmined it s not the ignition, plugs, distributor, theres just no spark
any ideas?
post Aug 25 2008, 12:29 AM
You changed the coil, too, right?
woodsytf
post Aug 25 2008, 09:11 AM
Drives: 1995 Volvo 850 Wagon
i have heard about several coil deaths/failures for 850's that have left the owner and mechanic stumped for a day or two.
i recommend you swap or replace the coil and check fuel pressure at the injector rail too. fuel pump failure is not uncomon at this age.
its a good idea to replace the plugs/wires/rotor and cap at the same time too.
good luck!
jlucas85
post Aug 25 2008, 10:18 AM
i have replaced
--the coil
--spark plugs
--plug wires
is there any kind of relay ??? that mite be the problem?
volvo spec
post Aug 25 2008, 10:23 AM
Drives: series 900, 780, 850, S70 Models.
Change camshaft position sensor.
Your tech guys not reading a computer codes. Go to volvo spec.
Thak you for asking Volvo spec.
:00000732:
:thumbsup:
woodsytf
post Aug 25 2008, 10:55 AM
cam sensor?.. expensive part. i would try the cheap ones first?... :thumbsup: but i usually try a used/swapped part first (I'm a cheapskate) :blush:
but... you should check your car for trouble codes.
this link can help you get the codes from your 850. http://www.troublecodes.net/Volvo/
write them all down and check in here or look them up at this link
http://www.actron.com/code_lookup.php
i would recommend that you try to find a local independant volvo shop, not a chain/franchise shop.
there is a relay for the fuel pump too.
jlucas85
post Aug 25 2008, 01:53 PM
it was the ecm :) which i got outa a junker for 50 bucks
post Aug 26 2008, 01:47 AM
The ECU?
Wow, that would probably be the last in my list to look at.
Congrats.
Cheers.
Volgrrr
post Aug 30 2008, 02:30 AM
QUOTE(jlucas85 @ Aug 26 2008, 05:53 AM)
[right][snapback]90135[/snapback][/right]
It is most unusual for an ECM to suddenly just up and pack it in for no apparent reason.
I suspect the garage has inadvertently caused a voltage spike by shorting something out while they were checking out your vehicle. Doing this can easily damage the ECU and the annoying part is, it is impossible to prove this might have happened.
volvo spec
post Aug 30 2008, 09:43 AM
This place have tested used original volvo parts for a great prices.
http://stores.ebay.com/A-Z-Volvo-Used-Parts
e-mail: volvousedparts@yahoo.com
Thank you for asking Volvo Spec
:thumbsup:
post Aug 30 2008, 12:10 PM
hey volvo spec, are you advertising your services on the forum? and i like your little line of "thanks for asking volvo spec"
post Sep 1 2008, 08:03 PM
QUOTE(TheGreekMason @ Aug 31 2008, 01:10 AM)
[right][snapback]90523[/snapback][/right]
Yeah, bro. And we go like, "eh? asking Volvo spec? I thought they're asking volvo-forums.com?"
:haha: :haha: :haha:
Volgrrr
post Sep 1 2008, 10:15 PM
QUOTE(volvo spec @ Aug 31 2008, 01:43 AM)
:thumbsup:
[right][snapback]90519[/snapback][/right]
Probably a not-so-subtle piece of self-promotion and has most likely been listed on other forums where Volvos are involved.
However, I did have a quick peek at this particular sight and found it somewhat disappointing because it doesn't many things of interest on offer.
No New Posts Overheating Problem
22 alanshark 616 19th November 2008 - 06:30 PM
Last post by: forty2
No New Posts Norcal 2008 Charity Toy Drive & Exotic Rally
0 m3dragon 5 19th November 2008 - 02:54 PM
Last post by: m3dragon
5 elmwoodblues 24 18th November 2008 - 09:56 PM
Last post by: elmwoodblues
5 dlm423 51 17th November 2008 - 02:49 AM
No New Posts Normal Temp Gauge Behaviour?
1 CJT156 256 10th November 2008 - 08:37 PM
Last post by: gobies
Time is now: 22nd November 2008 - 04:50 AM
