> 1978 245 Cis Not Starting
Striper15
post Aug 17 2008, 09:11 PM
Drives: 245 series 1978 Volvo
Hey guys. Brand new to the forum. Have been reading the posts here for the past hour and almost feel like my problem has been discussed already, but I'm desperate! Car turns over and will sputter/start for 2 seconds and the dies (Check cold start injector and works fine - I assume that's what that 2 second sputter is). Will start and run with starting fluid fine. Will just crank and crank without catching and never smelling gas. Here's what I did:
*New outside fuel pump a year old (changed only as preventative seeing that the original was in there for 30 years)
Last 2 days:
* Changed fuel filter (had a lot of gas pressure/leakage when I did)
* Swapped out fuel pump relay and fuse in fuse panel to no avail
*Changed the fuse to the in-tank pump
*Changed fuel pressure regulator next to the fuel distributor
*Checked air flow sensor plate
*Swapped out coil; changed plugs and coil (plug wires are only about a year old)
** I am concerned that the spark I get when plug is grounded to block is white/yellow, not blue. But it runs with the starting fluid no problem??
It's like there is no fuel getting to the 4 main injectors for some reason; could that mean the fuel distributor?? Yet fuel is geting to the cold start injector just fine.
Sure do apprciate any input; thank you!
Eric
post Aug 18 2008, 11:21 AM
Status: Online
I know nothing about CIS other than fuse #13 is very important, clean and replace.
Make sure you have +12V on one of the fuel injector wires - maybe the injectors aren't opening?
The Doctor
post Aug 20 2008, 07:24 PM
Drives: Volvo 1976 264
study the circuit diag and there are 2 relays to the pumps, but one is double pole [rare] and one is single pole [normal] and if you replace with wrong one then no power to pumps when cranking
get someone to crank engine and you hold external pump in hand to see if it is pumping
the starts for 2 seconds tells it all
I did a full video on this cis but sorry, it has gone missing just now so I will try to find
5 elmwoodblues 24 18th November 2008 - 09:56 PM
Last post by: elmwoodblues
7 CastleCW 139 27th October 2008 - 09:58 PM
No New Posts Not Sure If This Is Normal.
4 schaffee 89 4th October 2008 - 09:36 PM
Last post by: schaffee
No New Posts Starting Issue
1 chopper666 162 13th September 2008 - 10:03 AM
Last post by: eric237
No New Posts Not Trendy
Volvo 264 for Daughter
4 james filipavicius 53 22nd August 2008 - 10:56 PM
Last post by: aevril
Time is now: 21st November 2008 - 11:53 PM
