> Transmission In Limp Mode, Flashing arrows and CEL
txt00
post Aug 14 2008, 09:18 PM
Drives: 98 S70 T5, 00 V70XC SE
Here is the description of the problem (2000 V70 XC with 130kmi):
Flashing arrow and CEL came on the other day. I think the car is currently in limp mode and stuck in 3rd gear. I drove home for about 20 miles at 55+ mph without any problem. While stopping that the light, the car kept lurching forward even though brake was applied.
Here are the problems:
1. At stop light, keep lurching forward even though brake was applied. Engine will stall (not stall in N or P).
2. OBDII scan reported codes P0740 (TCC circuit malfunction), P1618 (Manufacturer Contrl, Aux. Inputs, Aux. Outputs), and P0422 (Main catalyst below threshold)
3. The next day, restarted engine, clunk noise when shifted to R, and stalled when put in any gears (R, D, 3, 2, 1)
4. Can be driven sometimes and gear changing could only be done manually (i.e. manually shifted to 1, 2, 3, or D gear) but will shake and lurch upon applying brake to slow down to a stop.
5. Some AT fluid leaked at tranny/engine mating surface with AT fluid smelled like burnt fluid
Troubleshooting Performed:
1. Cycled PNP switch 15-20 times with shifter while engine was on and brake applied
2. Checked solenoid resistance with digital multimeter at gearbox connector at leads 21 (S1 solenoid), 22 (S2 solenoid) and 23 (SL solenoid). All came back about 15 ohms (specs 10-15 ohms). Is this a correct method for checking resistance?
Per this link (http://www.volvo-forums.com/t9850-transmission-aw50-42.htm), code P0740 is for a lock-up solenoid SL. Any ideas to troubleshoot further?
I am thinking about removing the valve body cover to physically check the solenoids. Is this really necessary? There is a slight chance changing AT fluid will fix the problem. Any other ideas out there before replacing the transmission? I will post this in other Volvo forum.
Volvoagain
post Aug 16 2008, 09:01 AM
Drives: 1999 Volvo XC70
Had same issue. Replaced spped sensor and resolved the problem...
txt00
post Aug 16 2008, 03:54 PM
What lead you to believe that something was wrong with the speed sensor? Did you performed to see if the speed sensor was bad?
QUOTE(Volvoagain @ Aug 16 2008, 10:01 AM)
[right][snapback]89417[/snapback][/right]
Volvoagain
post Aug 17 2008, 07:56 PM
I stopped into the Volvo service department and started talking to a few of the mechanics...explained what was happening and they all said Speed Sensor or module. Start with SS. It took me ten minutes to replace it, reset the code and trans was shifting great again
soca2
post Aug 31 2008, 08:00 PM
Drives: 1998 v70xc
Did you replace the front or rear speed sensors?
Volvoagain
post Sep 1 2008, 09:00 AM
Wasnt aware of rear sensor, replaced the sensor on the transmission (located under airbox)
Also ended up replacing transmission module and flushing transmission fluid as it appeared burnt. Seems ok now, shifting clean
39 188mad 9,590 Yesterday, 01:18 PM
Last post by: deadfan50
No New Posts Topic has attachmentsInstalling Body Kit
IM trying to install a front lip.
20 The.Great.Khan.90 159 19th November 2008 - 12:04 AM
Last post by: swedseed850
No New Posts Interior Light Question?
1994 940 dome lighting. Need help
3 chuck5330 23 12th November 2008 - 10:09 AM
Last post by: chuck5330
No New Posts Info Centre Cold Oil
help needed
1 pieman 43 7th November 2008 - 07:09 AM
Last post by: pieman
No New Posts Intermittent Speedometer Issue 95 960
2 Kevin5000 46 6th November 2008 - 09:57 PM
Last post by: fupabox
Time is now: 22nd November 2008 - 03:53 AM
