> Idle Air Bleed
post Aug 7 2008, 12:01 AM
Drives: 1988 240 GL
I was trying to set my idle air bleed adjustment screw, for which I need the air valve closed and adjust the screw to get 700rpm???
My 88 B230F (RHD!) is supposed to have a red/white wire coming out in a test point near the RIGHT tower to ground out and close the idle air valve- the only such wire is at the LEFT tower, and it's in a connector into the wiring form- breaking the connection does stop the motor-cannot restart without re-joining the connector. the air valve can be heard adjusting after connection broken.
There is a different 'free' connector on the outside rear of the Left tower, which does NOT have a red/white wire, just red, and a blue. A red/white wire is secured to the coil on the forward side, with the red wire-looks factory assembled? Can't see other spare wires/connectors with similar colours anywhere, and red/white not present in connector block at Left firewall. (?)
Anyone????
nice86
post Aug 7 2008, 02:11 AM
Drives: 1986 Volvo 245
On my North American '86 with LH-2.2 ('85-'88), there is a test connector for idle speed and Lambda-sond. Two wires in a blue connector, a blue/white and a red. That test connector is near the ignition coil.
The procedure is to first warm up the engine, drive around for 20 minutes or so. Then ground the blue/white wire to close the idle air control valve. A/C turned off. Adjust engine speed using idle adjustment screw to 700 rpm. Disconnect ground wire from test point. Engine speed should increase to 750 rpm.
post Aug 7 2008, 06:38 PM
Drives: 1988 240 GL
Thank you, I knew I should have re-read that. Those are the wires I was thinking of, but my memory is failing so I got cornfused. Now I know what the test connector looks like. Again, thanks.
mike_281 20 2 Today, 03:59 PM
By: sargesvs
Rough Idle, And Intermittently Mulish
mike_281 116 9 Oct 4 2008, 02:33 PM
By: sargesvs
Mass Air Flow Sensor
Vertigoing 56 4 Oct 3 2008, 09:58 AM
By: manxman
1998 S70 Turbo Idle Problem
wgsa13 51 2 Sep 29 2008, 10:17 PM
By: wgsa13
Idle?
nc_volvo 62 2 Sep 26 2008, 02:39 PM
By: Dandle
Time is now: 6th October 2008 - 06:05 PM
